Whole House Audio
Mon Oct 10, 2011 9:34 am
Re: Whole House Audio
That's rather Rube Goldbergish isn't it?
Why not just by some inexpensive powered speakers to put in the rooms where you want sound (with the Express)? I think it'd be cheaper and you'd likely get much better sound quality. I suspect the sound quality out of those Elk speakers is probably pretty poor given they're not really designed for music. Sure, mounting powered speakers on the ceiling probably wouldn't work, but do you really need them on the ceiling?
You could probably also find some wireless powered speakers that would work though they would probably be more expensive.
Mon Oct 10, 2011 9:55 am
Brandt offline
Yeah. Im using old computer speakers right now but it looks bad to me. I wanted a nice clean finished look with wiring hidden.
Indigo 7 w/ Dual-Band 2413U PLM
macOS High Sierra 10.13.x
2011 iMac 3.4 GHz Intel Core i7
Mon Oct 10, 2011 9:33 pm
hamw offline
I use a Vaux Vaux 1600A-LE-02 Audio Matrix switch with a home run WHA setup and central WHA amp. The Vaux is very nice and can be occasionally found on ebay for a few hundred bucks. The later models have a built in paging function which, when executed via an applescript, saves all levels and inputs then switches to whatever paging input is specified, makes the announcement and switched back. The whole thing is RS232 controllable. Very easy.
tell application "iTunes"
   pause
   pause
end tell
delay 1.5
--set Vaux to paging state. There are several states that can be called and do what ever is programmed re zones, volume, etc. This one plays a doorbell ring outside, so all zones are enabled. It just as easily plays a phrase via iTunes.
tell application "Serial Bridge"
   set connectionName to "Vaux"
   send to source connectionName string "*cw,91,1,0,0,1
end tell
--delay 1
--execute sound file; first get computer output volume so it can be restored
set original_volume to output volume of (get volume settings)
set volume output volume 100
do shell script "afplay '/Users/WilliamsEC/sounds/doorbell.wav' "
set volume output volume original_volume
--exit Paging State
   send to source connectionName string "*cw,91,1,0,0,0
end tell
delay 1
   play
end tell
The other way I did it is is to store the current values as variables in a script. Not as elegant as the preceding ones or as simple as paging but worked well:
   activate
end tell
   set currentAudioSourceZone1 to value of variable "audio_1_source"
   set currentAudioSourceZone2 to value of variable "audio_2_source"
   set currentAudioSourceZone3 to value of variable "audio_3_source"
   set currentAudioSourceZone4 to value of variable "audio_4_source"
   set currentAudioSourceZone5 to value of variable "audio_5_source"
   set currentAudioSourceZone6 to value of variable "audio_6_source"
   set currentAudioSourceZone7 to value of variable "audio_7_source"
   set currentAudioSourceZone8 to value of variable "audio_8_source"
   set currentAudioSourceVolume1 to value of variable "audio_1_volume"
   set currentAudioSourceVolume2 to value of variable "audio_2_volume"
   set currentAudioSourceVolume3 to value of variable "audio_3_volume"
   set currentAudioSourceVolume4 to value of variable "audio_4_volume"
   set currentAudioSourceVolume5 to value of variable "audio_5_volume"
   set currentAudioSourceVolume6 to value of variable "audio_6_volume"
   set currentAudioSourceVolume7 to value of variable "audio_7_volume"
   set currentAudioSourceVolume8 to value of variable "audio_8_volume"
   set iTunesCurrentState to value of variable "iTunes_CurrentlyPlaying" as string
   set currentGirlsAlarmAudio to value of variable "airfoilSpeaker3"
   set currentDaddysiMac to value of variable "airfoilSpeaker4"
end tell
tell application "Airfoil"
   connect to (every speaker whose name is "Girls' Alarm Audio")
   set aSource to first system source
   set current audio source to aSource
end tell
   set value of variable "KidsOutlets" to "true"
   set value of variable "airfoilSpeaker3" to "true"
   set value of variable "airfoilSpeaker4" to "true"
   iTunesPause()
   set value of variable "audio_1_source" to "2" as string
   set value of variable "audio_2_source" to "2" as string
   set value of variable "audio_3_source" to "2" as string
   set value of variable "audio_4_source" to "2" as string
   set value of variable "audio_5_source" to "2" as string
   set value of variable "audio_6_source" to "2" as string
   set value of variable "audio_7_source" to "2" as string
   set value of variable "audio_8_source" to "2" as string
   set value of variable "audio_1_volume" to "30" as string
   set value of variable "audio_2_volume" to "30" as string
   set value of variable "audio_3_volume" to "30" as string
   set value of variable "audio_4_volume" to "30" as string
   set value of variable "audio_5_volume" to "30" as string
   set value of variable "audio_6_volume" to "30" as string
   set value of variable "audio_7_volume" to "30" as string
   set value of variable "audio_8_volume" to "30" as string
   delay 3
   set iTunesSpeech to value of variable "TextToSpeech" as string
end tell
   pause
   say iTunesSpeech
end tell
delay 3
   set value of variable "audio_1_volume" to currentAudioSourceVolume1 as string
   set value of variable "audio_2_volume" to currentAudioSourceVolume1 as string
   set value of variable "audio_3_volume" to currentAudioSourceVolume1 as string
   set value of variable "audio_4_volume" to currentAudioSourceVolume1 as string
   set value of variable "audio_5_volume" to currentAudioSourceVolume1 as string
   set value of variable "audio_6_volume" to currentAudioSourceVolume1 as string
   set value of variable "audio_7_volume" to currentAudioSourceVolume1 as string
   set value of variable "audio_8_volume" to currentAudioSourceVolume1 as string
   set value of variable "audio_1_source" to currentAudioSourceZone1 as string
   set value of variable "audio_2_source" to currentAudioSourceZone2 as string
   set value of variable "audio_3_source" to currentAudioSourceZone3 as string
   set value of variable "audio_4_source" to currentAudioSourceZone4 as string
   set value of variable "audio_5_source" to currentAudioSourceZone5 as string
   set value of variable "audio_6_source" to currentAudioSourceZone6 as string
   set value of variable "audio_7_source" to currentAudioSourceZone7 as string
   set value of variable "audio_8_source" to currentAudioSourceZone8 as string
   set value of variable "airfoilSpeaker3" to currentGirlsAlarmAudio as string
   set value of variable "airfoilSpeaker4" to currentDaddysiMac as string
   delay 5
      if iTunesCurrentState is "true" then
            play
         end tell
      end if
   end tell
   --set value of variable "KidsOutlets" to "false"
   --execute group "KidsOutletsOFF Disconnect Airfoil"
end tell
Sun Dec 04, 2011 6:06 pm
T-Power offline
Insignia NS-DP8CH Infocast to connect to Control Page?
Hello All,
Is anyone using their Insignia NS-DP8CH Infocast to connect to their Control Page?
Was wondering if this device contains a web browser?
T.I.A.
MacMini 2.3 GHz Intel Core i7 16GB DDR3
Indigo Pro 2022.1 macOS Mojave 10.14.6
Thu Dec 08, 2011 7:20 pm
Brandt offline
I would really love to have the "turn on/off all speakers" added to the airfoil plugin.
Fri Dec 09, 2011 9:39 am
You've previously requested that feature - it's still on the request list.
Tue Nov 13, 2012 8:19 pm
Just for you, Indigo 6 beta 1 has actions to connect/disconnect all speakers.
Users browsing this forum: No registered users and 34 guests
