I have four EZFlora's and they all stopped responding to commands after about a day. Upon further investigation I discovered a simple manual sequence that produces the same effect on all four.
From the devices window select a EZFlora device. At the bottom of the window where the pop-up menu says "all zones off" select the first zone. This will function correctly. While the zone is on select the "all zones off" from the same pop-up. This would turn off the zone. Now go back and select the first zone again and you will find that from this time on no individual zones will start up via this pop-up.
Here's what the event log looks like:
Jun 5, 2009 5:23:46 PM
Sent INSTEON "Sprinkler Planter North - Circle East" on (ack: valve 1 on)
Received INSTEON "Sprinkler Planter North" status changed: valve 1 on
Jun 5, 2009 5:25:13 PM
Sent INSTEON "Sprinkler Planter North - Circle East" off (ack: all valves off)
Received INSTEON "Sprinkler Planter North" status changed: all valves off
Sent INSTEON "Sprinkler Planter North - Circle West" off (ack: all valves off)
Sent INSTEON "Sprinkler Planter North - Garage" off (ack: all valves off)
Sent INSTEON "Sprinkler Planter North - Sandbox" off (ack: all valves off)
Sent INSTEON "Sprinkler Planter North - PF5" off (ack: all valves off)
Sent INSTEON "Sprinkler Planter North - PF6" off (ack: all valves off)
Sent INSTEON "Sprinkler Planter North - PF7" off (ack: all valves off)
Sent INSTEON "Sprinkler Planter North - PF8" off (ack: all valves off)
Jun 5, 2009 5:25:45 PM
Sent INSTEON "Sprinkler Planter North - Circle East" on (ack: all valves off)
Jun 5, 2009 5:26:10 PM
I am using a "PowerLinc V2 Controller" and have plugged all four EZFlora's directly into it using the pass-through outlets.
I am missing something obvious and any pointers in the right direction would be greatly appreciated.
