can indigo email the activity log ?
Thu Jun 26, 2008 12:16 pm
boyakaa offline
Can indigo email the activity log. With any type of variables like file size, time of day, and most important of all "specific event"?
Sat Jun 28, 2008 9:31 am
Re: can indigo email the activity log ?
A script like this will email, presuming you have configured the SMTP settings int he Indigo Preferences dialog, the last 100 lines from the Event Log:
   set eventLogDump to build event log list line count 100
   send email to "foo@foo.com" with subject "Event Log" with body eventLogDump
end tell
Regards,
Matt
Mon Sep 21, 2009 8:29 pm
wi_pedaler offline
(No subject)
Matt,
HUGE THANKS for such a slick and effective solution!
Once again, the Indigo support forums come through with a robust solution that I had implemented in less than 2 minutes. [it took a while to decide how many lines to send]
Tue Jan 26, 2010 5:17 pm
sparker offline
Here's a "shell script" that I put in a cronjob when I was trying to debug temperature issues:
cd "/Library/Application Support/Perceptive Automation/Indigo 4/Logs"
cat *.txt | tr '\r' '\n' > all.log
grep 'homeTemperature' all.log > temps_only.log
rm all.log.gz ; gzip all.log
( cat temps_only.log ; uuencode all.log.gz all.log.gz )  | mail -s "Home Event Logs" me@mydomain.com
This would have the temperature records in the body of the email, and all the logs attached as a gzip file if I needed to know more.... :)
Steve
Steve Parker
X10 user from the early 80's
Fully converted to Insteon in 2013 (looking to migrate away now)
Proud Indigo owner since the beginning... :)
Sat Jul 30, 2011 4:53 pm
Matt offline
In the interest of skinning cats, I submit my method:
tell application "Finder"
   set pth to "MacMini HD:Library:Application Support:Perceptive Automation:Indigo 5:Logs:" as alias
   set filelist to files in pth
   set filelist to sort filelist by modification date
   set theText to name of first item in filelist
   set theText to (pth as string) & theText as alias
   set theContent to read theText
end tell
do shell script "echo " & quoted form of theContent & " |mail -s 'Indigo Log' emailaddress@gmail.com"
I have grown to hate scripting the Mail app. In my experience it often asks for the account password before it will check email or send it, which is a nasty hiccup for an automated system. The above code bypasses that problem altogether.
Thu Dec 29, 2011 6:15 pm
chrismoore offline
This is great! Does anyone know if there is a way to email a log of just the error messages?
Fri Dec 30, 2011 12:16 am
Not a particularly easy way. You can turn on SQL logging then write a python script to open the database, pull out the error messages, format them, and email them.
Interesting idea for a plugin...
Fri Dec 30, 2011 12:40 am
berkinet offline
I'm not sure if you'd call this easy... But, it's not too hard to run a shell script to grep the actual log file for the messages you want and then mail the result of the shell script. Pretty straight forward in AppleScript, something like:
    set errorLines to do shell script "/usr/bin/grep error <path to the log file>"
    send email to "me@foo.com" with subject "Error Lines "with body errorLines
Change "error" to the string or regular expression you want, and change the path. I'm on my iPad so I can't check it right now.
Fri Dec 30, 2011 6:50 pm
chrismoore offline
Thanks for the help. I'm not very good with Applescript, but I think I did what you suggested and the mail message I receive has not content. The applescript I used was:
set errorLines to do shell script "/usr/bin/grep error Server HD:Library:Application Support:Perceptive Automation:Indigo 5:Logs:"
send email to "my email" with subject "Error Lines " with body errorLines
If you get a chance to test it out and get it working I would really appreciate it!
Fri Dec 30, 2011 7:12 pm
berkinet offline
chrismoore wrote:
...If you get a chance to test it out and get it working I would really appreciate it!
Sure. Try this:
   set myAddress to "foo@bar.com"
   set mySubject to "Indigo Log Error Report"
   set logFile to "/Library/Application Support/Perceptive Automation/Indigo 5/Logs/indigo_log.txt"
   set errorLines to do shell script ("/usr/bin/grep -i error \"" & logFile & "\"")
   send email to myAddress with subject mySubject with body errorLines
end tell
Set myAddress and mySubject to whatever you like. But, make sure you don't remove the quotes.
Then, paste this into the AppleScript Editor and save it in the Indigo scripts directory into any folder except the Attachments folder. I created a myScripts folder to keep my own scripts in.
Finally, setup a schedule to run it when you want. I suggest just before midnight, since the Indigo log alias tools over at midnight.
You can tweak the line selection by changing the arguments to grep. The -i option makes the search case insensitive (I.e. it will match Error, error, ERROR, etc.). You could also change the text to search for if there were particular errors you wanted. Take a look at the grep man page in a terminal window. Just type "man grep."
Post back if you have any problems or questions.
Fri Dec 30, 2011 7:40 pm
chrismoore offline
Works great, thanks!
Fri Dec 30, 2011 7:43 pm
Richard -- You should be coding the example scripts in python. I know you know the language now. ;-)
Fri Dec 30, 2011 8:37 pm
berkinet offline
support wrote:
.You should be coding the example scripts in python. I know you know the language now. ;-)
Well, besides the complexity of doing this with popen or sup process or os.open, or command...
Then there is the issue of mailing from the shell on a Mac...
The clincher was the wonderful Indigo send email to... ...with subject... ...with body
You just made it too easy.
I could actually have done it in 2 lines in AS + 2 for the tell block. Try that in Python :-)
Fri Dec 30, 2011 8:53 pm
POOF. Your wish is my command. Try:
indigo.server.sendEmailTo("foo@fooville.com", subject="log errors", body="hello there")
You are on your own for for the grep, but I'll bet you can figure that out in 1 python line as well. ;-)
Fri Dec 30, 2011 9:15 pm
berkinet offline
You're worse than my mother :wink:
1 line:
indigo.server.sendEmailTo("foo@barcom", subject="log errors", body=os.popen('/usr/bin/grep -i error "/Library/Application Support/Perceptive Automation/Indigo 5/Logs/indigo_log.txt"').read())
Besides being compact, its also totally incomprehensible to someone getting started.
So, this is probably the better way to go:
myAddress = "foo@bar.com"
mySubject = "Log Error Report"
logFile = '"/Library/Application Support/Perceptive Automation/Indigo 5/Logs/indigo_log.txt"'
errorLines = os.popen('/usr/bin/grep -i error ' + logFile).read()
indigo.server.sendEmailTo(myAddress, subject=mySubject, body=errorLines)
Notes for @chrismoore and others: This can be run as an embedded script since the way Indigo runs Python is a little better behaved than AppleScript.
