Eva Logik / Inovelli/New One - Dual Outdoor Outlet Module
Thu Sep 28, 2023 9:08 am
aldera offline
This is an outdoor dual outlet. It works except you can't address the outlets individually. They're either both on or both off. Hope to get this into the next Indigo update. Thanks.
Z-Wave Syncing - started for "MO_Dual31"
Z-Wave Syncing - retrieved module neighbors list: 2, 6, 11, 25, 37, 38, 39, 41, 47, 48, 50, 80, 95, 118, 121, 135, 205, 213
Z-Wave Syncing - assigning return route to "226 - MO_Dual31"
Z-Wave Syncing - retrieved manufacture and model names: Eva Logik / Inovelli - 0312, Relay Switch - AC010097
Z-Wave Syncing - retrieved protocol version 7.16, app version 1.00
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : -- (04 : 10 : 00, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 25v1 5Ev1 85v1 8Ev1 59v1 55v1 86v1 72v1 5Av1 87v1 73v1 98v1 9Fv1 60v4 6Cv1 7Av1 70v1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved multi-endpoint types: 1:(10 : 00), 2:(10 : 00)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 25 85 59 8E 6C 98 9F], 2:[5E 25 85 59 8E 6C 98 9F]
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - complete
Fri Sep 29, 2023 12:44 pm
Re: Eva Logik / Inovelli/New One - Dual Outdoor Outlet Modul
We'll look into getting this added to the next release.
Tue Oct 03, 2023 3:54 pm
The recent Indigo 2023.1.0 release includes preliminary support for this module so you should now be able to control the relays independently. You might need to re-sync the module first.
