Getting Started with Somfy Blinds & Such
Fri Jul 07, 2023 6:46 pm
SearchCz offline
I have a bunch of *somfy* window shades not yet integrated into my smarthome in any way. I’m am bout to add a *somfy* compatible powered screen on an enclosed porch, and the seller is offering a bridge of sorts called TaHoma.
I’m apprehensive because I already have an extensive Indigo setup controlling lots of devices through multiple bridges. I wonder if perhaps there is a more generic option I should consider that works well with I Diego to control *somfy* devices. Writing from Canada if that matters. I’m MHA e a few bridges already, including:
VELUX
MyQ
Hue
SmartThings
Sat Jul 08, 2023 3:46 pm
mclass offline
Re: Getting Started with Somfy Blinds & Such
Check out Bond Home device. Supports a range of blinds and other devices including Somfy.
In conjunction with the excellent Bond plugin, i have successfully integrated about 20 Somfy and Rollease blinds into indigo, and effectively control them with Alexa.
Another hub, yes, but better performance than manufactures hubs - especially the Rollease Pulse2 that has appalling range!
mclass
Sat Jul 15, 2023 2:30 am
b_weijenberg offline
Somfy IO is only supported by Somfy controllers.
Somfy RTS can be controlled using the RFXCOM plugin and the RFXCOM Transceivers (RFXusb-RFX433)
This transceiver can also be used to receive many weather sensors.
