About to Break Ground...
Sun Jun 12, 2022 3:08 pm
boisy offline
Re: About to Break Ground...
The experimentation with home automation technologies continues. Here's what I recently acquired:
  1. Three of nanoleaf's a19 essentials smart bulbs. I bought these as a way to experiment with smart lighting. I've always been an advocate of the "smart switch" but being able to set a light to different colors and color temperatures is attractive. These lights are also Thread routers, and I'm keen about getting Thread devices wherever I can.
  2. The Lilygo T-Relay. This is an ESP32 board with four relays built-in. It works great and replaces quite a bit of the home-brew ESP32 garage door controller system I posted earlier.
  3. The Lumary Smart Canless Recessed LIghting 6 inch 4 piece set. These are Wi-Fi lights that you control from your phone. They change colors and color temperatures, which I am growing to love. Wall colors can look completely different based on the color temperature of light, and being able to adjust this right from the phone is very cool, not to mention the smorgasbord of other colors these lights can do. These are also "thin" lights. They don't need a can and come with a box containing the LED driver electronics that just sits up in the ceiling.
    This foray into smart lights has gotten me rethinking switches for the new construction project. At first I thought I would go with traditional white recessed pot lights and a smart dimmer, but the more I think about it, the more I'm inclined to focus on the lights themselves. What I really want are Thread-based switches, but those don't exist yet. I looked at Inovelli, but they are still out of stock. I still have a couple of months to decide, but I don't expect things will change much by then. I may just get plain dumb switches and focus on finding a better switch solution down the road.
Sun Jun 12, 2022 3:15 pm
boisy offline
I forgot to add something to the previous post. Part of doing new construction is going to a lighting/fixture place and choosing lights. The lady we're working with at one of the local supply houses recommended Satco 7" LED lights which have adjustable color temperature, but (a) require a can, and (b) require you to take the light out to change the color. I couldn't understand why she would recommend a retrofit light for new construction. The cost of the light and the can exceeds the cost of one of the Lumary lights. Plus the wafer thin design of the Lumary just makes it a better choice.
Mon Jun 13, 2022 1:37 am
agame offline
One point i'd make is that LEDs in the real-world do occasionally fail. At least for me.
Luminaires that allow bulb replacement are therefore not exposed to the challenges of a seeking identical replacements at some point in the future (if matching fittings is important).
[fun fact: Australian residential downlight systems don't have the distinction of with/without a 'can' - I had to Google that - downlight luminaires invariably spring-fit to a hole in the plasterboard regardless of whether they have a user-replaceable bulb. So your decision tree is quite different!]
Mon Jun 13, 2022 11:32 am
boisy offline
That is a good point. When we had our LEDs canned lights installed in our current home, the electrician gave the same reason for going with canned lights and screw-in bulbs: if I went with all-in-one's I may find it hard to match if one goes out.
Honestly though, I hate the look of these lights, and wish I would have gone against his advice. I will do that in this instance for sure. It's easy enough to buy an additional four-pack to keep around as extras "just in case." Also, while you want the lights in the same room to match, you can certainly try different light styles in different rooms, so there's always the option of moving lights around if need be to keep sets of the same style together.
Mon Jun 13, 2022 2:21 pm
Do you plan to die in this house? Or will you eventually sell it?
If you ever care about selling the house, go ahead and pull the RG-6 (at least one) to every wall box for a TV. I'm assuming you're pulling ethernet to TV locations and not depending on Wifi.
Mon Jun 13, 2022 7:18 pm
boisy offline
Joe, I want to understand the rationale here. RG6 is not used in the new neighborhood -- it's all FTTH. I just don't see the need for RG6, especially when an HDHomeRun delivers OTA TV channels via ethernet.
Please convince me.
Mon Jun 13, 2022 7:25 pm
You still need it for Satellite TV, and not everyone will use something like an HDHomeRun for OTA. They might want direct antenna to the TV. I use a Tablo tuner myself, but I still have the antenna connected directly to some of the TVs in case of network or tuner box failure.
Didn't you say you're doing the wiring yourself? If so, for the cost of a couple hundred dollars for a reel or two of cable you're preventing a possibly significant deficiency at same time.
Tue Jun 14, 2022 3:13 am
boisy offline
Some good points. And I have several boxes of RG6 laying around from earlier projects, so the cost has already been paid for the material.
If I do run RG6, I'll keep the ends in the boxes because I really have no intention of using it myself, but at least the cable will already be there.
Tue Jun 14, 2022 4:22 am
Boxes? Low voltage is usually done with mud rings, which aren't actually boxes. But yeah, just leave them in the wall behind the ring.
Tue Jun 14, 2022 5:22 am
boisy offline
Yes, you are correct. I can keep them behind the cover plate and if they are ever needed, properly terminate them with connectors.
Mon Jan 23, 2023 3:54 pm
boisy offline
Well, we're about 6 weeks or so away from completion and moving in. I haven't updated this thread in a while, so I figured I would. Here's what's done:
  1. All ethernet cables are run (CAT6).
  2. I decided not to run RG6.
  3. Fiber internet is installed and up and running.
  4. Outside cameras are installed and working.
  5. Unifi equipment is up and running, along with wireless access points in the attic.
  6. All door sensors are installed.
  7. I decided to go with dumb recessed lights and dumb switches, except for a few places where I'll be placing Z-Wave switches. Thread/Matter devices are still few and far between, and Indigo isn't supporting them just yet, so Z-Wave it is for now.
Questions? Ask away!
Mon Jan 23, 2023 3:56 pm
Are you sure your WAPs are rated for attic temps? Not sure where you are, but that would be a no-go here in Florida.
Mon Jan 23, 2023 4:05 pm
boisy offline
This isn't a traditionally insulated house. The walls and attic are using foam insulation. I'm told that the attic temperature will be anywhere from 5-10 degrees different from the house due to the communication between the attic and the interior of the house.
Sat Feb 11, 2023 4:41 pm
boisy offline
Here's a quick update on the progress....
We're still about a month away from completion. I moved my 27" iMac from our current house to the new house next to the network rack and Indigo is humming along.
I have 22 individual door sensors that indicate open or closed. Those 22 wires go to 22 separate digital I/O pins on an ESP32 and a breakout board. That ESP32 is running custom code that sends each door state to FlyingDiver's MQTT Broker plugin. With the additional MQTT plugins he has, I am able to determine the state of each door and perform actions based on changes. For now, I get a push notification every time one of the 22 doors open or closes. This isn't practical for regular use, but it allows me to test out each door sensor and lets me know where the workers are throughout the house.
Later, when we're moved in, I'll turn those off and use the door states for a more practical purpose, such as a whole house alarm system with my VSS plugin, and turning on lights when door states change.
SecuritySpy is running on the iMac as well, and with both Cynical SecuritySpy and the Image downloader and SecuritySpy helper plugins, I'm able to send myself notifications when one of the four cameras mounted to the house detects a vehicle or a human (I'm waiting for Perry to add support for animals).
GoControl Z-Wave glass break sensors will go in this week. I already have the bases mounted on the ceilings of each room where windows are. These are normally battery operated, but I ran 16 gauge 2 conductor wire in the ceiling from one to the next, and have a 3.3v DIN rail power supply that will power those.
I'll be using a Kidde SM120X and a Zooz Z-Wave dry contact relay module to detect Smoke/CO2 status that will be installed when the electrician comes tomorrow to start wiring switches and outlets, and hanging light fixtures. I also have Z-Wave switches and dimmers already onboarded and designated for specific rooms. As we're off temporary power and onto meter base power, I'll be able to test those.
I have three floodlights that use the Homeseer HS-FLS100+ that will also be installed.
In the mean time, I'm setting up triggers and schedules that I'll anticipate needing once everything is in place.
Users browsing this forum: No registered users and 26 guests
