Landscape lighting, 12V
Fri Apr 16, 2021 11:06 am
jroach offline
Today, I control my outdoor lights (off/on) using x10). I would be very interested in seeing how people have cracked the 'color' or dimming of individual bulbs
in a 12V landscape lighting setup. If you have a setup, would love to see how it looks/works in the wild.
Fri Apr 16, 2021 11:31 am
Korey offline
Re: Landscape lighting, 12V
I use a Insteon dimmer to dim our Low voltage landscape lights (incandescent). the only way I know to dim individual zones is have multiple transformers with multiple dimmer modules.
When installing my system, I separated it into 4 zones, I had a Smartenit EZIO4O setup with relays so I could control what zone was on using a single transformer.
Unfortunately the EZIO4O died and I have never replaced it, so it's just 1 dimmable zone now. :?
Korey
Fri Apr 16, 2021 12:34 pm
jroach offline
Korey, I only can control one zone now as well.
Hoping some people have experimented with some sort of 12V color controller or DIY/Hack.
Fri Apr 16, 2021 2:09 pm
jroach offline
There are bulbs like this:
https://www.amazon.com/Brilliance-MR16- ... 242&sr=8-9
which looks to have enough brightness when compared to the Gledopto (200 lumens) but is wifi. I'm assuming if its wifi then we would need a plug-in.
Tue Apr 12, 2022 2:57 pm
jroach offline
FX Luminaire released a landscape lighting system "ZDC" (Zone, Dimming, Color). Looks pretty cool and doesn't require rewiring from what I can tell.
You do have to buy their controller and bulbs (retrofit is just Zone and Dimming) and if you want color you need to buy a new fixture. Price gets up there pretty quick but looks fun.
Also works with Lutron so I'm curious if anybody has tried hooking it up to Indigo via the Lutron plug-in.
https://www.fxl.com/product/transformer ... ntegration
Sat Apr 23, 2022 3:09 pm
jroach offline
found these today:
Anybody have any experience with them?
They are wifi so I'm assuming I could cobble something together to make them work within indigo (Alexa...maybe?)
Sun Mar 24, 2024 1:10 pm
jroach offline
Fri May 03, 2024 2:28 pm
jroach offline
Ordered the two pack. At first it didn't work but likely because the bulb was too far from the nearest working hue bulb. I moved it to another landscape light closer to the house and everything worked! I then tried adding the second bulb to a light that might be a bout 20' away but behind a cement wall. It didn't work:(
I'm not certain if my new bulbs are zigbee OR bluetooth connected. I have a zigbee stick downstairs and need to figure out how to use it as its been awhile.
