So the old technical timers on my pool pump is dead and instead of replacing it, I thought it would be good to bring it under control of Indigo. While there are a few plug-ins that work with existing pool automation equipment, in the end, all that automation and control is going to go to waste, as I'll have Indigo do everything it does, and better.
I've seen plugins for some boards, notably this http://www.indigodomo.com/pluginstore/196/, but this particular board can only handle 10Amps, which isn't enough for the pump.
So what I'm looking for is something similar... some kind of network relay board, that can handle both 220V, all the amps needed for the pump, and a plugin so I can run it from Indigo. I'm guessing something like this is out there, and just ready to go, but I've got no idea where to look.
