Smart mailbox saga, and success
Posted: Thu Jun 06, 2019 10:39 am
Our mailbox is not attached to the house. It is outside a gate, on the road. So, to avoid unnecessary trips to check if we had mail or a package over the past few years I have made several attempts to create a smart mailbox. The basic idea was to be notified when there was mail in the mailbox. Up until now, all of these attempts failed for one reason or another.
The initial concept was to be notified each time the mailbox door was opened. My first approach was to use a tilt-sensor (a typical alarm element) on the door of the mailbox. Each time the door opened, it would light a key on a keypad link (via an alarm interface plugin). The light could be reset by pressing the key. Technically, it worked. But, what happened was nobody would ever bother to reset the system after collecting the mail. Also, simply opening and closing a mailbox is not, per-se, an indication that mail has arrived or been collected.
My next attempt was to find a way to be notified of the actual presence of something in the mailbox. This approach would have no need to be reset since it was the state of the mailbox I would monitor rather than delivery or collection of the mail. My first approach at mail detection was to use a distance sensor at the top of the mailbox. The hypothesis being the presence of something in the mailbox would shorten the distance between a sensor at the top, and the mailbox floor. I tried sonar and light based sensors. But, both were unreliable because of the different ways mail could land in the mailbox. Another issue was something like a single postcard which was not easily measurable.
I then tried simply measuring reflected light. The hypothesis here is if the mailbox inside is black, the presence of anything (other than something 100% black) would reflect additional light. I painted the inside of the mailbox black and mounted an LED and light detector at the top of the mailbox, looking towards the mailbox floor. This worked to a degree. But, was fooled by the mailbox being opened (daylight or even streetlights) or objects that were dark in color. In the end, there was just not a reliable differentiation between presence and absence of an object.
Next, I considered using a camera with image detection. But, set that aside for a while because of the complexity.
Then, I returned to an idea I had considered early on, but discarded because it seemed to be too much work. This idea was to essentially install a scale on the bottom on the mailbox with a false floor resting on it. I decided to use a 0-5kg load cell as the detector and connect it through a Wheatstone bridge to an analog I/O port and on to Indigo via a plugin. This had moderate success. I could detect a change in weight of less than 1 gram. However, there was a major issue with the load cell - it was not temperature stable. This meant I had no reliable zero-point to use as an "empty" reference. I tried looking for a change of a certain minimum value. But, even that was unreliable - simply having a letter fall out of my hand and back into the mailbox would fool the system.
However, I knew I had the right approach and all I needed to do was find the right hardware. With no easy way to know which load cells would work, I decided to try to adapt a regular electronic kitchen scale. But, while looking for the right scale I happened upon the Stamps.com 0-5lb USB mail scale. This scale is typically given away when someone opens an account and they are readily available on the used market. ebay has loads of them at an average price of $10 USD. I then found someone's project where they figured out how to read the scale directly from a computer. That was all I needed.
I got the scale, removed the (very simple) load cell an d electronics from the case and placed them under my false floor. (The scale automatically sets the tare weight when it turns on, so the false floor weight is no issue.) I then adapted the software I had found to read the scale once a minute and compare the weight to the last reading, or see if it was zero and had the program update Indigo using the RESTful API. It works! I get notified when the weight becomes n on-zero and again when it becomes zero. I also mounted a bright blue LED outside the gate so we can see if there is mail when we arrive.
There is a potential gotcha, If there is a power failure when there is mail in the mailbox and the power comes back on with the mail still present, the tare will now include the mail. This hasn't happened yet. But, it is easy enough to simply power cycle the scale.
YMMV.
YMMV.
