Automated -and- manual control in one device?
Thu Jan 01, 2004 7:49 pm
gmaletic offline
Does anyone make an X10 "lamp" controller (by this, I mean an X10 switch that plugs into an outlet, then controls a lamp or some similar device by turning on/off the power to the device) that has its -own- power switch? I'd like to control some lamps in my house with devices like this, but I'm worried that my Mac will have a lamp set to "off" at exactly the time that I'd like to manually switch on the lamp, and I won't be able to since its power has been cut off.
I guess what I'm asking for is a lamp controller that offers the same flexibility as an X10 wall switch: full computer control as well as manual control.
Thanks.
Thu Jan 01, 2004 8:07 pm
Re: Automated -and- manual control in one device?
Most of the lamp and appliance modules do this (LampLinc, for example). There isn't a switch on the module, but it can detect when you manually turn the lamp's real switch from off to on. Normally, this means you have to turn the lamp 2 clicks to get it on manually -- the first click turns the lamp off even though it is really already off, and the second click turns in on.
Regards,
Matt
Fri Jan 02, 2004 12:07 pm
gmaletic offline
But...
That's very cool. But what happens if I turn the lamp off after having turned it on manually? Then it will not be able to be controlled centrally again, right? (Until I turn it back on again by hand, that is.)
Thanks for your help.
Fri Jan 02, 2004 12:20 pm
Re: But...
True, there is no way to manually turn it off such that Indigo could then turn it back on without additionally turning it on manually again.
Regards,
Matt
