Logging "Activity Monitor" to file?
Tue Dec 26, 2017 6:10 pm
Do any of you Mac gurus know if it's possible to log a CPU and Memory usage snapshot to file per day?
I've a problem with my Mac which I suspect is a plugin getting a tiny bit greedy every day such that after about 6-8 weeks my Mac becomes unresponsive.
I can't get in it remotely to debug it as it's unresponsive, and I can't use traditional user input devices as the monitor is "blanked" by TeamViewer (to stop my monitor constantly switching over when PC goes to sleep) and I can't therefore see what's happening on screen.
I can't see the last time it happened as text-searching for "Starting Indigo Server" in the /Logs folder doesn't find anything within the log retention.
I'm fancying logging daily snapshot of CPU/Memory then I can browse it after-the-fact next time the Mac goes in a coma.
Peter
Wed Dec 27, 2017 5:03 am
CliveS offline
Re: Logging "Activity Monitor" to file?
Not sure if this would help https://github.com/jeetsukumaran/Syrupy
CliveS
Wed Dec 27, 2017 5:20 am
Wed Dec 27, 2017 8:50 am
roussell offline
You can use something like this to dump the RSS (resident Set Size) memory usage for a given process. In the example below I check the Sonos Plugin process and dump to a file in the Indigo user's Document folder:
ps x -o rss,command | grep Sonos.indigoPlugin |awk '{print $1}'|head -1>>/Users/Indigo/Documents/output.csv
In this example, 'output csv will contain one line for each time the process is ran, containing the RSS value of the process "Sonos.indigoPlugin"
101976
If you want a date and timestamp in the file, then use something like this:
printf "`date '+%D, %X,'` `ps x -o rss,command | grep Sonos.indigoPlugin |awk '{print $1}'|head -1`\n" >>/Users/Indigo/Documents/output.csv
Which will produce this:
12/27/17, 09:01:18, 101976
12/27/17, 09:01:20, 101976
12/27/17, 09:01:22, 101976
12/27/17, 09:01:23, 101976
You can use either cron or create a schedule in Indigo to run the above line (modified to suit your plugin and output path/file) and whatever interval you wish. Then just import the file into Excel or whatever to view the memory usage.
Terry
Users browsing this forum: Google [Bot] and 32 guests
