Looking for a better solution than a bunch of controllable wall warts for use in my equipment rack. Prefer something intended for installation in a 19" equipment rack. HTTP or socket communications are fine.
Suggestions?
CliveS wrote:Looking on eBay now they appear to be over £100. When did you buy them so cheap? They look like something I need for my rack.I use the Aviosys IP Power 4 port 9258S Web Power Switch http://www.aviosys.com/9258st.html and control them either via http or the Indigo IP9258 plugin by @NickSmith http://forums.indigodomo.com/viewtopic.php?f=134&t=8977 which controls On/Off/Toggle and Status.
I also have the 8 port rack mount version but cannot get the plugin to work with it, I have tried but am a Python numpty but I expect you could revamp it quite easily.
They also do a 9258S+Ping that can ping an address and reboot when it does not receive a reply after a time or number of pings, handy as a standalone unit for the router/modem but again I have 2 that I cannot control via the plugin as it has a different reply from the switch.
I have bought them all from eBay for around 20-30 pounds each and the US versions have a T at the end in place of the UK S models and a couple of 4 port T models are on US eBay at $38.00 at present.
CliveS
Users browsing this forum: No registered users and 31 guests
