Well, here's a brute force attempt to get the data. We don't have access to the FEMA version of the data and the NWS version lags by 2-3 minutes. You could schedule this to run every 30-60 seconds. The most granular level you can get is by county -- there's possibility that you could do some coding against the polygon data, but not every alert has the data. To use this script, you'd have to add the variables to Indigo, change the county code and replace the variable ids with those assigned by indigo.
There are other fields I could capture, but this was just to prove it could be done.
- Code: Select all
import urllib2
from xml.dom.minidom import parseString
# download the file
theUrl = 'http://alerts.weather.gov/cap/wwaatmget.php?x=TXC439&y=1'
# theUrl = 'http://alerts.weather.gov/cap/wwaatmget.php?x=ARC093&y=1'
f = urllib2.urlopen(theUrl)
theXml = f.read()
theDocTree = parseString(theXml)
# HEADER
noaaAlertID0 = theDocTree.getElementsByTagName("id")[0].firstChild.data
noaaAlertGenerator0 = theDocTree.getElementsByTagName("generator")[0].firstChild.data
noaaAlertUpdated0 = theDocTree.getElementsByTagName("updated")[0].firstChild.data
noaaAlertAuthor0 = theDocTree.getElementsByTagName("name")[0].firstChild.data
noaaAlertTitle0 = theDocTree.getElementsByTagName("title")[0].firstChild.data
# ALERT 1
noaaAlertID1 = theDocTree.getElementsByTagName("id")[1].firstChild.data
noaaAlertUpdated1 = theDocTree.getElementsByTagName("updated")[1].firstChild.data
noaaAlertPublished1 = theDocTree.getElementsByTagName("published")[0].firstChild.data
noaaAlertAuthor1 = theDocTree.getElementsByTagName("name")[1].firstChild.data
noaaAlertTitle1 = theDocTree.getElementsByTagName("title")[1].firstChild.data
noaaAlertSummary1 = theDocTree.getElementsByTagName("summary")[0].firstChild.data
noaaAlertCapEvent1 = theDocTree.getElementsByTagName("cap:event")[0].firstChild.data
noaaAlertCapEffective1 = theDocTree.getElementsByTagName("cap:effective")[0].firstChild.data
noaaAlertCapExpires1 = theDocTree.getElementsByTagName("cap:expires")[0].firstChild.data
noaaAlertCapStatus1 = theDocTree.getElementsByTagName("cap:status")[0].firstChild.data
noaaAlertCapMsgType1 = theDocTree.getElementsByTagName("cap:msgType")[0].firstChild.data
noaaAlertCapCategory1 = theDocTree.getElementsByTagName("cap:category")[0].firstChild.data
noaaAlertCapUrgency1 = theDocTree.getElementsByTagName("cap:urgency")[0].firstChild.data
noaaAlertCapSeverity1 = theDocTree.getElementsByTagName("cap:severity")[0].firstChild.data
noaaAlertCapCertainly1 = theDocTree.getElementsByTagName("cap:certainty")[0].firstChild.data
noaaAlertCapAreaDesc1 = theDocTree.getElementsByTagName("cap:areaDesc")[0].firstChild.data
noaaAlertPolygon1Temp = theDocTree.getElementsByTagName("cap:polygon")[0].firstChild.data
noaaAlertPolygon1 = '[(' + noaaAlertPolygon1Temp.replace(' ', '),(') + ')]'
except IndexError, e:
noaaAlertID1 = ""
noaaAlertUpdated1 = ""
noaaAlertPublished1 = ""
noaaAlertAuthor1 = ""
noaaAlertTitle1 = ""
noaaAlertSummary1 = ""
noaaAlertCapEvent1 = ""
noaaAlertCapEffective1 = ""
noaaAlertCapExpires1 = ""
noaaAlertCapStatus1 = ""
noaaAlertCapMsgType1 = ""
noaaAlertCapCategory1 = ""
noaaAlertCapUrgency1 = ""
noaaAlertCapSeverity1 = ""
noaaAlertCapCertainly1 = ""
noaaAlertCapAreaDesc1 = ""
noaaAlertPolygon1 = ""
except AttributeError, e: # Needed because cap:polygon is sometimes missing
# ALERT 2
noaaAlertID2 = theDocTree.getElementsByTagName("id")[2].firstChild.data
noaaAlertUpdated2 = theDocTree.getElementsByTagName("updated")[2].firstChild.data
noaaAlertPublished2 = theDocTree.getElementsByTagName("published")[1].firstChild.data
noaaAlertAuthor2 = theDocTree.getElementsByTagName("name")[2].firstChild.data
noaaAlertTitle2 = theDocTree.getElementsByTagName("title")[2].firstChild.data
noaaAlertSummary2 = theDocTree.getElementsByTagName("summary")[1].firstChild.data
noaaAlertCapEvent2 = theDocTree.getElementsByTagName("cap:event")[1].firstChild.data
noaaAlertCapEffective2 = theDocTree.getElementsByTagName("cap:effective")[1].firstChild.data
noaaAlertCapExpires2 = theDocTree.getElementsByTagName("cap:expires")[1].firstChild.data
noaaAlertCapStatus2 = theDocTree.getElementsByTagName("cap:status")[1].firstChild.data
noaaAlertCapMsgType2 = theDocTree.getElementsByTagName("cap:msgType")[1].firstChild.data
noaaAlertCapCategory2 = theDocTree.getElementsByTagName("cap:category")[1].firstChild.data
noaaAlertCapUrgency2 = theDocTree.getElementsByTagName("cap:urgency")[1].firstChild.data
noaaAlertCapSeverity2 = theDocTree.getElementsByTagName("cap:severity")[1].firstChild.data
noaaAlertCapCertainly2 = theDocTree.getElementsByTagName("cap:certainty")[1].firstChild.data
noaaAlertCapAreaDesc2 = theDocTree.getElementsByTagName("cap:areaDesc")[1].firstChild.data
noaaAlertPolygon2Temp = theDocTree.getElementsByTagName("cap:polygon")[1].firstChild.data
noaaAlertPolygon2 = '[(' + noaaAlertPolygon2Temp.replace(' ', '),(') + ')]'
noaaAlertID2 = ""
noaaAlertUpdated2 = ""
noaaAlertPublished2 = ""
noaaAlertAuthor2 = ""
noaaAlertTitle2 = ""
noaaAlertSummary2 = ""
noaaAlertCapEvent2 = ""
noaaAlertCapEffective2 = ""
noaaAlertCapExpires2 = ""
noaaAlertCapStatus2 = ""
noaaAlertCapMsgType2 = ""
noaaAlertCapCategory2 = ""
noaaAlertCapUrgency2 = ""
noaaAlertCapSeverity2 = ""
noaaAlertCapCertainly2 = ""
noaaAlertCapAreaDesc2 = ""
noaaAlertPolygon2 = ""
# ALERT 3
noaaAlertID3 = theDocTree.getElementsByTagName("id")[3].firstChild.data
noaaAlertUpdated3 = theDocTree.getElementsByTagName("updated")[3].firstChild.data
noaaAlertPublished3 = theDocTree.getElementsByTagName("published")[2].firstChild.data
noaaAlertAuthor3 = theDocTree.getElementsByTagName("name")[3].firstChild.data
noaaAlertTitle3 = theDocTree.getElementsByTagName("title")[3].firstChild.data
noaaAlertSummary3 = theDocTree.getElementsByTagName("summary")[2].firstChild.data
noaaAlertCapEvent3 = theDocTree.getElementsByTagName("cap:event")[2].firstChild.data
noaaAlertCapEffective3 = theDocTree.getElementsByTagName("cap:effective")[2].firstChild.data
noaaAlertCapExpires3 = theDocTree.getElementsByTagName("cap:expires")[2].firstChild.data
noaaAlertCapStatus3 = theDocTree.getElementsByTagName("cap:status")[2].firstChild.data
noaaAlertCapMsgType3 = theDocTree.getElementsByTagName("cap:msgType")[2].firstChild.data
noaaAlertCapCategory3 = theDocTree.getElementsByTagName("cap:category")[2].firstChild.data
noaaAlertCapUrgency3 = theDocTree.getElementsByTagName("cap:urgency")[2].firstChild.data
noaaAlertCapSeverity3 = theDocTree.getElementsByTagName("cap:severity")[2].firstChild.data
noaaAlertCapCertainly3 = theDocTree.getElementsByTagName("cap:certainty")[2].firstChild.data
noaaAlertCapAreaDesc3 = theDocTree.getElementsByTagName("cap:areaDesc")[2].firstChild.data
noaaAlertPolygon3Temp = theDocTree.getElementsByTagName("cap:polygon")[2].firstChild.data
noaaAlertPolygon3 = '[(' + noaaAlertPolygon3Temp.replace(' ', '),(') + ')]'
noaaAlertID3 = ""
noaaAlertUpdated3 = ""
noaaAlertPublished3 = ""
noaaAlertAuthor3 = ""
noaaAlertTitle3 = ""
noaaAlertSummary3 = ""
noaaAlertCapEvent3 = ""
noaaAlertCapEffective3 = ""
noaaAlertCapExpires3 = ""
noaaAlertCapStatus3 = ""
noaaAlertCapMsgType3 = ""
noaaAlertCapCategory3 = ""
noaaAlertCapUrgency3 = ""
noaaAlertCapSeverity3 = ""
noaaAlertCapCertainly3 = ""
noaaAlertCapAreaDesc3 = ""
noaaAlertPolygon3 = ""
# ALERT 4
noaaAlertID4 = theDocTree.getElementsByTagName("id")[4].firstChild.data
noaaAlertUpdated4 = theDocTree.getElementsByTagName("updated")[4].firstChild.data
noaaAlertPublished4 = theDocTree.getElementsByTagName("published")[3].firstChild.data
noaaAlertAuthor4 = theDocTree.getElementsByTagName("name")[4].firstChild.data
noaaAlertTitle4 = theDocTree.getElementsByTagName("title")[4].firstChild.data
noaaAlertSummary4 = theDocTree.getElementsByTagName("summary")[3].firstChild.data
noaaAlertCapEvent4 = theDocTree.getElementsByTagName("cap:event")[3].firstChild.data
noaaAlertCapEffective4 = theDocTree.getElementsByTagName("cap:effective")[3].firstChild.data
noaaAlertCapExpires4 = theDocTree.getElementsByTagName("cap:expires")[3].firstChild.data
noaaAlertCapStatus4 = theDocTree.getElementsByTagName("cap:status")[3].firstChild.data
noaaAlertCapMsgType4 = theDocTree.getElementsByTagName("cap:msgType")[3].firstChild.data
noaaAlertCapCategory4 = theDocTree.getElementsByTagName("cap:category")[3].firstChild.data
noaaAlertCapUrgency4 = theDocTree.getElementsByTagName("cap:urgency")[3].firstChild.data
noaaAlertCapSeverity4 = theDocTree.getElementsByTagName("cap:severity")[3].firstChild.data
noaaAlertCapCertainly4 = theDocTree.getElementsByTagName("cap:certainty")[3].firstChild.data
noaaAlertCapAreaDesc4 = theDocTree.getElementsByTagName("cap:areaDesc")[3].firstChild.data
noaaAlertPolygon4Temp = theDocTree.getElementsByTagName("cap:polygon")[3].firstChild.data
noaaAlertPolygon4 = '[(' + noaaAlertPolygon4Temp.replace(' ', '),(') + ')]'
noaaAlertID4 = ""
noaaAlertUpdated4 = ""
noaaAlertPublished4 = ""
noaaAlertAuthor4 = ""
noaaAlertTitle4 = ""
noaaAlertSummary4 = ""
noaaAlertCapEvent4 = ""
noaaAlertCapEffective4 = ""
noaaAlertCapExpires4 = ""
noaaAlertCapStatus4 = ""
noaaAlertCapMsgType4 = ""
noaaAlertCapCategory4 = ""
noaaAlertCapUrgency4 = ""
noaaAlertCapSeverity4 = ""
noaaAlertCapCertainly4 = ""
noaaAlertCapAreaDesc4 = ""
noaaAlertPolygon4 = ""
# WRITE HEADER TO INDIGO
indigo.variable.updateValue(251912902, value=str(noaaAlertID0)) # "noaaAlert0ID"
indigo.variable.updateValue(488888730, value=str(noaaAlertGenerator0)) # "noaaAlert0Generator"
indigo.variable.updateValue(1041636278, value=str(noaaAlertUpdated0)) # "noaaAlert0Updated"
indigo.variable.updateValue(851481444, value=str(noaaAlertAuthor0)) # "noaaAlert0Author"
indigo.variable.updateValue(414199120, value=str(noaaAlertTitle0)) # "noaaAlert0Title"
# WRITE ALERT 1 TO INDIGO
indigo.variable.updateValue(970579805, value=str(noaaAlertID1)) # "noaaAlertID1"
indigo.variable.updateValue(451934914, value=str(noaaAlertUpdated1)) # "noaaAlertUpdated1"
indigo.variable.updateValue(45734687, value=str(noaaAlertPublished1)) # "noaaAlertPublished1"
indigo.variable.updateValue(530210630, value=str(noaaAlertAuthor1)) # "noaaAlertAuthor1"
indigo.variable.updateValue(1508190911, value=str(noaaAlertTitle1)) # "noaaAlertTitle1"
indigo.variable.updateValue(27131104, value=str(noaaAlertSummary1)) # "noaaAlertSummary1"
indigo.variable.updateValue(507770105, value=str(noaaAlertCapEvent1)) # "noaaAlertCapEvent1"
indigo.variable.updateValue(1350045247, value=str(noaaAlertCapEffective1)) # "noaaAlertCapEffective1"
indigo.variable.updateValue(1045605899, value=str(noaaAlertCapExpires1)) # "noaaAlertCapExpires1"
indigo.variable.updateValue(1694945345, value=str(noaaAlertCapStatus1)) # "noaaAlertCapStatus1" Actual, Excercise, System, Test, Draft
indigo.variable.updateValue(361396269, value=str(noaaAlertCapMsgType1)) # "noaaAlertCapMsgType1" Alert, Update, Cancel, Ack, Error
indigo.variable.updateValue(636093119, value=str(noaaAlertCapCategory1)) # "noaaAlertCapCategory1" Geo, Met, Safety, Security, Rescue, Fire, Health, Env, Transport, Infra, CBRNE, Other
indigo.variable.updateValue(101309718, value=str(noaaAlertCapUrgency1)) # "noaaAlertCapUrgency1" Immediate, Expected, Future, Past Unknown
indigo.variable.updateValue(431261270, value=str(noaaAlertCapSeverity1)) # "noaaAlertCapSeverity1" Extreme, Severe, Moderate, Minor, Unknown
indigo.variable.updateValue(6635718, value=str(noaaAlertCapCertainly1)) # "noaaAlertCapCertainty1" Observed, Likely, Possible, Unlikely, Unknown
indigo.variable.updateValue(1574026820, value=str(noaaAlertCapAreaDesc1)) # "noaaAlertCapAreaDesc1"
indigo.variable.updateValue(1823083030, value=str(noaaAlertPolygon1)) # "noaaAlertPolygon1"
# WRITE ALERT 2 TO INDIGO
indigo.variable.updateValue(1818783764, value=str(noaaAlertID2)) # "noaaAlertID2"
indigo.variable.updateValue(1676631089, value=str(noaaAlertUpdated2)) # "noaaAlertUpdated2"
indigo.variable.updateValue(318906496, value=str(noaaAlertPublished2)) # "noaaAlertPublished2"
indigo.variable.updateValue(367560147, value=str(noaaAlertAuthor2)) # "noaaAlertAuthor2"
indigo.variable.updateValue(1084941128, value=str(noaaAlertTitle2)) # "noaaAlertTitle2"
indigo.variable.updateValue(958812312, value=str(noaaAlertSummary2)) # "noaaAlertSummary2"
indigo.variable.updateValue(1429059287, value=str(noaaAlertCapEvent2)) # "noaaAlertCapEvent2"
indigo.variable.updateValue(146835994, value=str(noaaAlertCapEffective2)) # "noaaAlertCapEffective2"
indigo.variable.updateValue(657166470, value=str(noaaAlertCapExpires2)) # "noaaAlertCapExpires2"
indigo.variable.updateValue(34992235, value=str(noaaAlertCapStatus2)) # "noaaAlertCapStatus2" Actual, Excercise, System, Test, Draft
indigo.variable.updateValue(520328817, value=str(noaaAlertCapMsgType2)) # "noaaAlertCapMsgType2" Alert, Update, Cancel, Ack, Error
indigo.variable.updateValue(1721937615, value=str(noaaAlertCapCategory2)) # "noaaAlertCapCategory2" Geo, Met, Safety, Security, Rescue, Fire, Health, Env, Transport, Infra, CBRNE, Other
indigo.variable.updateValue(1674307807, value=str(noaaAlertCapUrgency2)) # "noaaAlertCapUrgency2" Immediate, Expected, Future, Past Unknown
indigo.variable.updateValue(1381376882, value=str(noaaAlertCapSeverity2)) # "noaaAlertCapSeverity2" Extreme, Severe, Moderate, Minor, Unknown
indigo.variable.updateValue(78500200, value=str(noaaAlertCapCertainly2)) # "noaaAlertCapCertainty2" Observed, Likely, Possible, Unlikely, Unknown
indigo.variable.updateValue(653615352, value=str(noaaAlertCapAreaDesc2)) # "noaaAlertCapAreaDesc2"
indigo.variable.updateValue(856990534, value=str(noaaAlertPolygon2)) # "noaaAlertPolygon2"
# WRITE ALERT 3 TO INDIGO
indigo.variable.updateValue(250611685, value=str(noaaAlertID3)) # "noaaAlertID3"
indigo.variable.updateValue(660531607, value=str(noaaAlertUpdated3)) # "noaaAlertUpdated3"
indigo.variable.updateValue(1866465128, value=str(noaaAlertPublished3)) # "noaaAlertPublished3"
indigo.variable.updateValue(1601846800, value=str(noaaAlertAuthor3)) # "noaaAlertAuthor3"
indigo.variable.updateValue(1576616853, value=str(noaaAlertTitle3)) # "noaaAlertTitle3"
indigo.variable.updateValue(51231625, value=str(noaaAlertSummary3)) # "noaaAlertSummary3"
indigo.variable.updateValue(1019018204, value=str(noaaAlertCapEvent3)) # "noaaAlertCapEvent3"
indigo.variable.updateValue(1318897258, value=str(noaaAlertCapEffective3)) # "noaaAlertCapEffective3"
indigo.variable.updateValue(1593320108, value=str(noaaAlertCapExpires3)) # "noaaAlertCapExpires3"
indigo.variable.updateValue(1380632583, value=str(noaaAlertCapStatus3)) # "noaaAlertCapStatus3" Actual, Excercise, System, Test, Draft
indigo.variable.updateValue(1709855541, value=str(noaaAlertCapMsgType3)) # "noaaAlertCapMsgType3" Alert, Update, Cancel, Ack, Error
indigo.variable.updateValue(473568572, value=str(noaaAlertCapCategory3)) # "noaaAlertCapCategory3" Geo, Met, Safety, Security, Rescue, Fire, Health, Env, Transport, Infra, CBRNE, Other
indigo.variable.updateValue(372339663, value=str(noaaAlertCapUrgency3)) # "noaaAlertCapUrgency3" Immediate, Expected, Future, Past Unknown
indigo.variable.updateValue(1676970597, value=str(noaaAlertCapSeverity3)) # "noaaAlertCapSeverity3" Extreme, Severe, Moderate, Minor, Unknown
indigo.variable.updateValue(1139743337, value=str(noaaAlertCapCertainly3)) # "noaaAlertCapCertainty3" Observed, Likely, Possible, Unlikely, Unknown
indigo.variable.updateValue(487568757, value=str(noaaAlertCapAreaDesc3)) # "noaaAlertCapAreaDesc1"
indigo.variable.updateValue(667083469, value=str(noaaAlertPolygon3)) # "noaaAlertPolygon3"
# WRITE ALERT 4 TO INDIGO
indigo.variable.updateValue(1399660509, value=str(noaaAlertID4)) # "noaaAlertID4"
indigo.variable.updateValue(1661417371, value=str(noaaAlertUpdated4)) # "noaaAlertUpdated4"
indigo.variable.updateValue(450104477, value=str(noaaAlertPublished4)) # "noaaAlertPublished4"
indigo.variable.updateValue(1237945019, value=str(noaaAlertAuthor4)) # "noaaAlertAuthor4"
indigo.variable.updateValue(547657858, value=str(noaaAlertTitle4)) # "noaaAlertTitle4"
indigo.variable.updateValue(326675971, value=str(noaaAlertSummary4)) # "noaaAlertSummary4"
indigo.variable.updateValue(1499896221, value=str(noaaAlertCapEvent4)) # "noaaAlertCapEvent4"
indigo.variable.updateValue(56670747, value=str(noaaAlertCapEffective4)) # "noaaAlertCapEffective4"
indigo.variable.updateValue(232105237, value=str(noaaAlertCapExpires4)) # "noaaAlertCapExpires4"
indigo.variable.updateValue(1249037109, value=str(noaaAlertCapStatus4)) # "noaaAlertCapStatus4" Actual, Excercise, System, Test, Draft
indigo.variable.updateValue(1610819848, value=str(noaaAlertCapMsgType4)) # "noaaAlertCapMsgType4" Alert, Update, Cancel, Ack, Error
indigo.variable.updateValue(1954312401, value=str(noaaAlertCapCategory4)) # "noaaAlertCapCategory4" Geo, Met, Safety, Security, Rescue, Fire, Health, Env, Transport, Infra, CBRNE, Other
indigo.variable.updateValue(1035974472, value=str(noaaAlertCapUrgency4)) # "noaaAlertCapUrgency4" Immediate, Expected, Future, Past Unknown
indigo.variable.updateValue(1701840599, value=str(noaaAlertCapSeverity4)) # "noaaAlertCapSeverity4" Extreme, Severe, Moderate, Minor, Unknown
indigo.variable.updateValue(393185168, value=str(noaaAlertCapCertainly4)) # "noaaAlertCapCertainty4" Observed, Likely, Possible, Unlikely, Unknown
indigo.variable.updateValue(341984009, value=str(noaaAlertCapAreaDesc4)) # "noaaAlertCapAreaDesc4"
indigo.variable.updateValue(804386241, value=str(noaaAlertPolygon4)) # "noaaAlertPolygon4"
indigo.server.log("Last NOAA Alert Update: " + str(noaaAlertUpdated0))
And here's the code pulled from NWS:
- Code: Select all
<?xml-stylesheet href='http://alerts.weather.gov/cap/capatom.xsl' type='text/xsl'?>
This atom/xml feed is an index to active advisories, watches and warnings
issued by the National Weather Service. This index file is not the complete
Common Alerting Protocol (CAP) alert message. To obtain the complete CAP
alert, please follow the links for each entry in this index. Also note the
CAP message uses a style sheet to convey the information in a human readable
format. Please view the source of the CAP message to see the complete data
set. Not all information in the CAP message is contained in this index of
active alerts.
<feed xmlns="http://www.w3.org/2005/Atom" xmlns:cap="urn:oasis:names:tc:emergency:cap:1.1" xmlns:ha="http://www.alerting.net/namespace/index_1.0">
<!-- TZN = <CDT> -->
<!-- TZO = <-5> -->
<!-- http-date = Sun, 13 Apr 2014 04:50:00 GMT -->
<id>http://alerts.weather.gov/cap/wwaatmget.php?x=TXC439&y=0</id>
<generator>NWS CAP Server</generator>
<updated>2014-04-13T11:50:00-05:00</updated>
<author>
<name>w-nws.webmaster@noaa.gov</name>
</author>
<title>Current Watches, Warnings and Advisories for Tarrant (TXC439) Texas Issued by the National Weather Service</title>
<link href="http://alerts.weather.gov/cap/wwaatmget.php?x=TXC439&y=0" />
<entry>
<id>http://alerts.weather.gov/cap/wwacapget.php?x=TX12514E2C1DC8.WindAdvisory.12514E390290TX.FWDNPWFWD.cd331d01680eb21ed8f27e386c74bb2e</id>
<published>2014-04-13T11:50:00-05:00</published>
<author>
</author>
<title>Wind Advisory issued April 13 at 11:50AM CDT until April 13 at 8:00PM CDT by NWS</title>
<link href="http://alerts.weather.gov/cap/wwacapget.php?x=TX12514E2C1DC8.WindAdvisory.12514E390290TX.FWDNPWFWD.cd331d01680eb21ed8f27e386c74bb2e" />
<summary>...A WIND ADVISORY REMAINS IN EFFECT FOR THE WESTERN TWO THIRDS OF NORTH TEXAS THROUGH 8 PM... .DEEP SURFACE LOW PRESSURE CENTERED IN OKLAHOMA WILL RESULT IN A STRONG AND GUSTY SOUTH WIND ALONG AND WEST OF A SHERMAN... CORSICANA...TO HEARNE LINE. WIND SPEEDS WILL RANGE FROM 20 TO 30 MPH WITH SOME GUSTS IN EXCESS OF 35 MPH. WIND SPEEDS WILL</summary>
<cap:event>Wind Advisory</cap:event>
<cap:effective>2014-04-13T11:50:00-05:00</cap:effective>
<cap:expires>2014-04-13T20:00:00-05:00</cap:expires>
<cap:status>Actual</cap:status>
<cap:msgType>Alert</cap:msgType>
<cap:category>Met</cap:category>
<cap:urgency>Expected</cap:urgency>
<cap:severity>Minor</cap:severity>
<cap:certainty>Likely</cap:certainty>
<cap:areaDesc>Bell; Bosque; Collin; Comanche; Cooke; Coryell; Dallas; Denton; Eastland; Ellis; Erath; Falls; Grayson; Hamilton; Hill; Hood; Jack; Johnson; Lampasas; Limestone; McLennan; Milam; Mills; Montague; Navarro; Palo Pinto; Parker; Robertson; Rockwall; Somervell; Stephens; Tarrant; Wise; Young</cap:areaDesc>
<cap:polygon />
<cap:geocode>
<valueName>FIPS6</valueName>
<value>048027 048035 048085 048093 048097 048099 048113 048121 048133 048139 048143 048145 048181 048193 048217 048221 048237 048251 048281 048293 048309 048331 048333 048337 048349 048363 048367 048395 048397 048425 048429 048439 048497 048503</value>
<valueName>UGC</valueName>
<value>TXZ091 TXZ092 TXZ093 TXZ100 TXZ101 TXZ102 TXZ103 TXZ104 TXZ115 TXZ116 TXZ117 TXZ118 TXZ119 TXZ120 TXZ129 TXZ130 TXZ131 TXZ132 TXZ133 TXZ134 TXZ141 TXZ142 TXZ143 TXZ144 TXZ145 TXZ146 TXZ156 TXZ157 TXZ158 TXZ159 TXZ160 TXZ161 TXZ174 TXZ175</value>
</cap:geocode>
<cap:parameter>
<valueName>VTEC</valueName>
<value>/O.CON.KFWD.WI.Y.0011.000000T0000Z-140414T0100Z/</value>
</cap:parameter>
</entry>
</feed>
