Help with XBMC integration
Sun Feb 28, 2016 3:33 pm
Korey offline
Re: Help with XBMC integration
tenallero wrote:
HI,
Just published a new release for XBMC plugin.
Just fixing some bugs for the Kodi Add-on.
Remember that for this plugin .. don´t forget to install the Kodi add-on
Hi Ramon,
Getting this error now with V0.0.15
Started plugin "XBMC 0.0.15"
  XBMC                            "Kodi - Theatre"  is on
  XBMC Error                      Kodi - Theatre: RPC API Error: {"error":{"code":-32601,"message":"Method not found."},"id":1,"jsonrpc":"2.0"}
  XBMC Error                      Error: global name 'indigoDevice' is not defined
  XBMC Error                      plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Korey
Sun Feb 28, 2016 4:40 pm
tenallero offline
Korey wrote:
tenallero wrote:
HI,
Hi Ramon,
Thanks Korey,
Can you put the plugin in debug mode? (plugin configuration. Debug = on)
And post the new log?
Sun Feb 28, 2016 4:51 pm
Korey offline
tenallero wrote:
Thanks Korey,
  XBMC Debug                      startup called
  XBMC Debug                      Local IP address: 192.168.0.4
  XBMC Debug                      Kodi - Korey MBP : Starting device
  XBMC Debug                      Kodi - Theatre: Starting device
  XBMC Debug                      XBMC - Bedroom CBUNTU: Starting device
  XBMC Debug                      XBMC - Theatre CBUNTU: Starting device
  XBMC Debug                      Starting listening socket on port 8189
  XBMC Debug                      Socket is open
  XBMC Debug                      Socket. received: <type>app</type><event>start</event> from: 192.168.0.4
  XBMC Debug                      Socket. Found XBMC device "Kodi - Theatre" for address 192.168.0.4
  XBMC Debug                      query  "Kodi - Theatre" version
  XBMC Debug                      Kodi - Theatre: sendRpcRequest
  XBMC Debug                      Kodi - Theatre: Request content: {"params": {"properties": ["version"]}, "jsonrpc": "2.0", "method": "Application.GetProperties", "id": 1}
  XBMC Debug                      Socket. received: <type>menu</type><menu>video</menu> from: 192.168.0.4
  XBMC Debug                      Socket. received: <type>player</type><event>onplaybackstarted</event><media>video</media><title>8 Mile</title> from: 192.168.0.4
Feb 28, 2016, 2:46:06 PM
  XBMC Debug                      Socket. received: <type>player</type><event>onplaybackstopped</event><media>video</media><title>8 Mile</title> from: 192.168.0.4
  XBMC Debug                      Socket. received: <type>menu</type><menu>home</menu> from: 192.168.0.4
  XBMC Debug                      Socket. received: <type>app</type><event>quit</event> from: 192.168.0.4
  XBMC Debug                      Received going to quit from "Kodi - Theatre
  XBMC                            "Kodi - Theatre"  is off
Korey
Sun Feb 28, 2016 5:03 pm
tenallero offline
Korey,
A new plugin relase on github.
No changes for the kodi-addon from v.0.0.15
Only for the Indigo plugin.
Put in debug mode and post the log.
Thanks in advance
Sun Feb 28, 2016 5:17 pm
Korey offline
tenallero wrote:
Korey,
Thanks in advance
Still seeing : XBMC Error Kodi - Theatre: RPC API Error: {"error":{"code":-32601,"message":"Method not found."},"id":1,"jsonrpc":"2.0"}
 Upgrading plugin "XBMC" to newer version 0.0.16 (previous version moved to trash)
  Loading plugin "XBMC 0.0.16"
  Starting plugin "XBMC 0.0.16" (pid 428)
  Started plugin "XBMC 0.0.16"
  XBMC Debug                      Switch off  "Kodi - Theatre" returned invalid reponse to request
  XBMC Debug                      Socket. received: <type>volume</type><volume>0</volume><muted>false</muted> from: 192.168.0.4
  XBMC Debug                      Kodi - Theatre: Request content: {"params": {"properties": ["version"]}, "jsonrpc": "2.0", "method": "Application.GetProperties", "id": 2}
  XBMC Error                      Kodi - Theatre: RPC API Error: {"error":{"code":-32601,"message":"Method not found."},"id":2,"jsonrpc":"2.0"}
  XBMC Debug                      Socket. received: <type>volume</type><volume>97</volume><muted>false</muted> from: 192.168.0.4
  XBMC Debug                      Kodi - Theatre: Request content: {"params": {"properties": ["version"]}, "jsonrpc": "2.0", "method": "Application.GetProperties", "id": 3}
  XBMC Debug                      Kodi - Theatre: Response content: {"id":3,"jsonrpc":"2.0","result":{"version":{"major":16,"minor":0,"revision":"2016-02-20-a5f3a99","tag":"stable"}}}
  XBMC Debug                      "Kodi - Theatre" version is 16.0
Feb 28, 2016, 3:13:01 PM
  XBMC Debug                      Socket. received: <type>player</type><event>onplaybackstarted</event><media>video</media><title>Brooklyn</title> from: 192.168.0.4
Feb 28, 2016, 3:13:17 PM
  XBMC Debug                      Socket. received: <type>player</type><event>onplaybackstopped</event><media>video</media><title>Brooklyn</title> from: 192.168.0.4
Feb 28, 2016, 3:13:50 PM
Feb 28, 2016, 3:14:13 PM
  XBMC Debug                      Kodi - Theatre: Request content: {"params": {"properties": ["version"]}, "jsonrpc": "2.0", "method": "Application.GetProperties", "id": 4}
  XBMC Error                      Kodi - Theatre: RPC API Error: {"error":{"code":-32601,"message":"Method not found."},"id":4,"jsonrpc":"2.0"}
  XBMC Debug                      Kodi - Theatre: Request content: {"params": {"properties": ["version"]}, "jsonrpc": "2.0", "method": "Application.GetProperties", "id": 5}
  XBMC Error                      Kodi - Theatre: RPC API Error: {"error":{"code":-32601,"message":"Method not found."},"id":5,"jsonrpc":"2.0"}
  XBMC Debug                      Kodi - Theatre: Request content: {"params": {"properties": ["version"]}, "jsonrpc": "2.0", "method": "Application.GetProperties", "id": 6}
  XBMC Debug                      Kodi - Theatre: Response content: {"id":6,"jsonrpc":"2.0","result":{"version":{"major":16,"minor":0,"revision":"2016-02-20-a5f3a99","tag":"stable"}}}
  XBMC Debug                      Socket. received: <type>menu</type><menu>settings</menu> from: 192.168.0.4
Feb 28, 2016, 3:14:58 PM
  XBMC Debug                      Socket. Switch off  "Kodi - Theatre" by inactivity
Korey
Sun Feb 28, 2016 5:32 pm
tenallero offline
Korey,
Reading the log, I can see the error is raised when the plugin ask the release to Kodi.
I have commented this query.
A new release (0.0.17) is ready to download for the Plugin.
https://github.com/tenallero/Indigo-XBMC/releases/tag/v0.0.17
But it is strange, because I use Kodi 15.0 (Isengard) and 16.0 (Jarvis) as you ... and I don´t get this error.
I can see you have two Kodi devices.
The errors come from "Kodi - Theatre" in the same ip address than Indigo. Is this "Kodi - Theatre" on release 16.0?
Sun Feb 28, 2016 5:51 pm
tenallero offline
Korey,
Now I can see your "Kodi - Theater" is on release 16.0 (Jarvis)
Strange behaviour.
After the first and second request, Kodi answers that it does not understand the request.
But, at the third time, Kodi understand the request and answer correctly
Sun Feb 28, 2016 6:17 pm
Korey offline
tenallero wrote:
Korey,
Looks like you fixed it!
Yes, Kodi - Theatre release V16
Thanks for all your work!
Upgrading plugin "XBMC" to newer version 0.0.17 (previous version moved to trash)
  Loading plugin "XBMC 0.0.17"
  Starting plugin "XBMC 0.0.17" (pid 615)
  Started plugin "XBMC 0.0.17"
Feb 28, 2016, 3:37:26 PM
  XBMC Debug                      Socket. received: <type>player</type><event>onplaybackstarted</event><media>video</media><title>Steve Jobs</title> from: 192.168.0.4
Feb 28, 2016, 3:37:59 PM
  XBMC Debug                      Socket. received: <type>player</type><event>onplaybackstopped</event><media>video</media><title>Steve Jobs</title> from: 192.168.0.4
Screen Shot 2016-02-28 at 3.40.22 PM.PNG (470.75 KiB) Viewed 7637 times
Korey
Sun Feb 28, 2016 6:23 pm
tenallero offline
Korey,
Thanks to you
Good night
Mon Feb 29, 2016 2:47 am
jens offline
Someone with Kodi integration to work with Rpi ??
//Jens
Mon Feb 29, 2016 2:50 am
tenallero offline
//Jens
I am running OpenElec 6.0 on a RaspberryPi 2
Works ok with the Indigo Plugin.
Mon Feb 29, 2016 3:07 am
jens offline
tenallero wrote:
//Jens
Tanks for answer will try today :D
//Jens
Mon Feb 29, 2016 12:04 pm
jens offline
tenallero wrote:
//Jens
Do you have some install help to Pi 2 ?? :)
//Jens
Mon Feb 29, 2016 1:07 pm
tenallero offline
jens wrote:
tenallero wrote:
//Jens
//Jens
Jens,
It is your first time with Raspberry Pi?
Do you have a minimum Linux shell knowledge?
First of all, you need to download to download an OpenElec image for raspberry Pi 2 (Must be for your PI2, not older Pi´s)
http://openelec.tv/get-openelec
Some wiki here:
http://wiki.openelec.tv/index.php/HOW-TO:Installing_OpenELEC/Creating_The_Install_Key#tab=DiskImage
You will need a tool to write the downloaded image to the SD Card
With a Mac, I use ApplePi-Baker (http://www.tweaking4all.com/hardware/ra ... -pi-baker/)
If you work with Windows .... Win32DiskImager (https://sourceforge.net/projects/win32diskimager/)
Plug your HDMI TV set to the raspberry
Plug an usb keyboard and mouse
Plug an ethernet wire
Insert the SDCard into the raspberry
Plug a "reliable" 5VDC 2Amper power adapter to your pi. Power stability is very important. Apple iPad power adapter is very good
Power on
And .... Kodi/Openelec will appear in your monitor.
Lets go to settings and configure it as you need.
Kodi (inside Openlec) has special settings to manage some "Linux" features, like open ssh server, samba server, etc ...
You will need to open ssh server in order to remote login to the linux internal shell
Mac has a ssh client, so you must open mac´s terminal and ssh login inside your openelec
You can transfer de Kodi Indigo zip file to openelec in many ways, via SMB, using wget, etc ....
Depending on the codec of your videos or livetv, you may purchase a mpeg-2 licences
http://www.raspberrypi.com/mpeg-2-license-key/
And, as an extra point, if you want to convert your openelec into a 2000 USD HIFI system, you can purchase some DAC or DAC+Amplifier board to plug into your raspberry.
Openelec variant exist with driver for these boards
https://www.hifiberry.com/
http://www.iqaudio.co.uk/
For remote control exist miriads of possibilities.
I use this combination:
Flirc usb dongle (https://flirc.tv/more/flirc-usb)
Microsoft Xbox One remote (http://www.xbox.com/es-ES/xbox-one/acce ... s_tNnR7uC6)
I hope this help you
Tue Mar 01, 2016 12:07 pm
jens offline
Thanks for the perfect declarations Tenallero,
:D
Now the next question,
Where in the code I put "service.indigo" mapen ?? and how can I find what I'm going to set in Kodi ?,
Kodi is running and I have connected it to my server, can now watch movies, etc.
//Jens
Users browsing this forum: No registered users and 36 guests
