Help with XBMC integration
Tue Mar 01, 2016 2:03 pm
tenallero offline
Re: Help with XBMC integration
jens wrote:
Thanks for the perfect declarations Tenallero,
:D
Now the next question,
Where in the code I put "service.indigo" mapen ?? and how can I find what I'm going to set in Kodi ?,
Kodi is running and I have connected it to my server, can now watch movies, etc.
//Jens
Sorry
Maybe I don´t understand well your question.
Have you follow the plugin wiki?
https://github.com/tenallero/Indigo-XBMC/wiki
Have you installed service.indigo.zip in your system?
I you have problems storing the zip file into the openelec filesystem
you can ssh login inside raspberrypi and use wget to download the file.
- You must enable ssh server in your openelec inside Kodi settings
- Open terminal in your Mac.
- Then input these commands.
ssh root@<raspberrypi-ipadress> (password = openelec)
(if login success then you are now inside your raspberry pi)
cd downloads
wget https://github.com/tenallero/Indigo-XBM ... indigo.zip
ls -la (you must see a file with name service.indigo.zip)
exit
Now, goto Kodi and install the add-on from zip file ... You will find the zip file on "downloads" folder.
And follow wiki instructions
Other ideas:
copy the zip file in a usb memory stick (fat32 formated), plug in to the raspberry pi
Other idea:
You will be able to see your raspberry pi using your Mac Finder. Use "Connect as" to connect as "root@openelec"
Using drag&drop transfer the zip file from Mac to RaspberryPI
Good luck
Ramon
Sun Mar 06, 2016 2:12 pm
tenallero offline
tenallero wrote:
:D
//Jens
Sorry
cd downloads
exit
Other ideas:
Other idea:
Good luck
Ramon
Hi Jens,
Did you installed the service.indigo.zip inside your Raspberry?
I am trying to upload the Indigo service to the Kodi official repository.
So, you only will need to browse the repository inside Kodi, instead to install from .zip file
If, finally, I have an approval for my code, I will notify the forum
Sun Mar 06, 2016 3:04 pm
jens offline
It saying something is wrong with the file? //jens
Sent from my iPhone 6 using Tapatalk
Sun Mar 06, 2016 3:29 pm
tenallero offline
Maybe, you can try with the new release I have submitted to Kodi repository
Thu Jan 05, 2017 2:22 am
docp offline
Hello
Thanks for your hard work with this plugin - I currently use the Plex plugin for play pause states triggering the lights to turn off / come on. Is a similar functionality available with your plugin? I am thinking of getting an android media box that runs kodi (v17 I think). However it uses an wrapper to run its own media player so HD audio works (it is the himedia q5) .
Do you know if your plugin would work with the above ?
Wed Sep 13, 2017 3:15 pm
ckeyes888 offline
Is this XMBC plugin still viable? I'm about to move from 10.7 to 10.8 to use Kodi
hoping for a decent replacement for Front Row.
Curious if it's possible to choose the media to play? I've checked out the commands that are available in it
but none seem to be reference choosing media....just vol, mute, stop, start etc.
Carl
Fri Feb 26, 2021 2:51 am
Rjay offline
hey all, I assume this plugin is now really dead with the advent of Kodi v19 (think all plugins need to be Python v3)? Was working in v18 prior with a few tweaks
Do you think there is interest in the Community to get this or another up and running? As I use Kodi for all media endpoints in the house (single interface for all local media and streaming media such as Kayo, Stan etc) its actually a really useful plugin as you could send notifications to end points that appear as OSD pop ups such as "Dishwasher / Washing Cycle Complete" etc as well as control the end point automatically
cheers
