Indigo Automation 'Disease'
Mon Feb 26, 2018 8:33 am
Colorado4Wheeler offline
Re: Indigo Automation 'Disease'
durosity wrote:
had a lot of anxiety issues and panic attacks over stupid little things like when the heating wasn't turning itself on correctly and things.
I cannot begin to count how many times I've been through that. Where it's just not quite dialed in and you start questioning at what point was all this headache easier than turning on a light switch (something not lost on my wife either). I've wrested with ripping out my HA system so many times that I couldn't keep track. I took a long break from Indigo coding shortly after the HBB launch when I had a dozen people screaming about an issue that just couldn't be tracked down. Notice how this new version of HomeKit integration is a tightly controlled beta? Yea, there are reasons for that and my sanity is the #1 reason.
I get it.
Glad you came out unscathed and that you are healthy :wink:
Mon Feb 26, 2018 10:43 am
Yeah. That’s exactly why I stopped trying to learn python and never released the few plugins I did write.. I was terrified it might cause some sort of issue as I’d seen you have. Not that the ones I created were anywhere near as useful as yours :D
Mon Feb 26, 2018 10:12 pm
RogueProeliator offline
I'm pretty sure that I'd be single if I did that.
If I spent $5k+ on a curtain rod, I would actually be quite dead. Then she would sell the curtain rod.
Mon Feb 26, 2018 11:00 pm
It was three curtain rods for that total cost. So, much better. :D
Tue Feb 27, 2018 1:56 am
That's still $1666 per rod! Thats probably $1400 more than i paid for my motorised rod :wink:
Tue Feb 27, 2018 6:33 am
Only if she could refrain from beating you to death with said rod.
Tue Feb 27, 2018 6:45 am
There ain’t a court in the land that’d find her guilty.
Thu Mar 08, 2018 9:06 pm
jh71283 wrote:
In your case Dave, you may be able to just wire one of these in, and run those LED's off the white channel only.
I did wind up grabbing one of the devices you mentioned but haven't played with it yet.
I landed on a simple solution that worked for our particular circumstance. I took a USB charger from an old Nook--5V at 0.87A if I'm remembering right. I thought I might try to hook the fairy lights up directly since 3 AA batteries is probably the better part of 5v when new. Worked perfectly well, but the better part of an amp meant the lights were too bright for our taste. So I put a 22Ω resistor in line with the negative wire (I don't think it matters which one you choose) and soldered up the connections. Topped it off with a little bit of shrink tubing. Worked perfectly.
The lamp in question is near a floor lamp that's already controlled by Indigo and now this is too. The picture doesn't really do it justice.
Sun Mar 18, 2018 4:17 pm
That’s pretty! :)
Mon Mar 19, 2018 3:36 am
The wife did a nice job arranging the lights -- it looks even better in person.
Mon Mar 19, 2018 6:14 am
So when shall I come over then? Might stay for dinner if that’s ok.. perhaps the night.. or a few nights..
(Since Jay evicted me from OUR house I’ve been living destitute on the streets. So.. uh.. I might stay a while)
Mon Mar 19, 2018 6:15 am
Do you do windows? Toilets?
We might be able to work something out...
Mon Mar 19, 2018 6:16 am
Windows? What kinda sick man are you?
Also I use the corner. What’s a toilet?
Mon Mar 19, 2018 6:19 am
Not Windows, windows.
The cat has dibs on the corners.
Mon Mar 19, 2018 6:31 am
If I were an animal I’d most certainly be a cat.
We can share the same corner. If not we can do that weird fighting cats do.. batting each other..
