Somfy Z-Wave to RTS Interface (ZRTSI) & Indigo?
Mon Oct 17, 2016 12:49 am
dduff617 offline
Re: Somfy Z-Wave to RTS Interface (ZRTSI) & Indigo?
i like that it has battery reporting - it's a big downer to install lots of home automation gear in your house and then routinely some fraction of it not working due to batteries running out.
Tue Jan 17, 2017 4:53 pm
jalves offline
Just got four new Bali Somfy Autoview (z-wave) controlled blinds installed a few hours ago. Looking for info on how to control them from Indigo using my existing z-wave controller. User manual from Bali is very sparse on info about including/excluding in networks. I'm doing some google searches, but wondering if anybody in our Indigo ecosystem has experience with these.
Jeff
Tue Jan 17, 2017 10:10 pm
sjoing offline
@Jeff check out this video
https://youtu.be/8mTF8uF7jnE
It helped me get the Bali auto view connected to Indigo
Wed Jan 18, 2017 8:11 am
jalves offline
Thanks, I found the same video. Going to try it in the next couple of days.
Jeff
Sat May 20, 2017 11:24 pm
sjoing offline
For others looking for setup help, in addition to previously mentioned items in this thread, this blog post was helpful for me in setting up these new AutoView shades:
http://notes.kendeeter.com/2017/01/08/bali-autoview-and-openzwave/
Mon Oct 23, 2017 1:58 pm
wideglidejrp offline
Has anyone had experience with the Venetian style Somfy shades? They go up and down like normal shades, but when they get to the closed position, the horizontal blades of the shade tilts 90 degrees. This allows the sun in and defeats the purpose of closing the shades. My workaround for this is to follow the close command with an immediate open command followed by a stop command. To do the stop command, I use a Raw Z-wave command of 0x26 0x05. This usually works, but not always, due to the latency of getting the command from z-stick ZRTSI controller to the shade. I am hoping there is a two-byte command to take the shade out of the tilt mode.
John R Patrick
Author of
Home Attitude
Mon Sep 10, 2018 2:26 pm
Re: Somfy Z-Wave raw commands
I have the Shangri La Blind Stripes with Somfy motors. They are like Venetian blinds. When they go down and reach stop position, they rotate 90 degrees. I am trying to find a command which prevents the rotation. I am using
UP: 0x26, 0x04, 0x60, 0x00
DOWN: 0x26, 0x04, 0x20, 0x00
STOP: 0x26, 0x05
Anybody aware of any other codes?
John R Patrick
Author of
Home Attitude
Users browsing this forum: No registered users and 22 guests
