INSTEON Motion Sensor
Wed Aug 07, 2013 3:16 pm
This topic is to discuss the Motion Sensor from INSTEON.
Device Details
How to use with Indigo
Tue Aug 27, 2013 1:27 pm
Len Evansic offline
Re: INSTEON Motion Sensor
Is there any way to get a battery level from the Insteon motion sensor, other than catching a "Button 3" signal? I saw a video of the Aeon Labs Z-Wave multi-sensor on Indigo, and couldn't help to notice the nice battery charge bar graph.
-- Len
Tue Aug 27, 2013 1:47 pm
Hi Len,
It is more complicated with the INSTEON motion sensor, but take a look at this forum thread.
Sat Aug 31, 2013 8:45 am
Bollar offline
I am seeing duplicate Insteon commands from all of my motion sensors. Is anyone else seeing this, or can anyone point me towards the right solution?
Aug 31, 2013, 9:41:40 AM
  Received INSTEON                "Porch Front Yard Motion" on (button 1)
  Trigger                         Porch Front Yard Motion Heartbeat
  Trigger                         Porch Front Yard Motion Down
Aug 31, 2013, 9:42:11 AM
  Received INSTEON                "Living Room Motion" off (button 1)
Aug 31, 2013, 9:42:41 AM
  Received INSTEON                "Porch Front Yard Motion" off (button 1)
And BTW, non-motion Insteon switches don't send duplicate signals:
Aug 31, 2013, 9:47:37 AM
  Received INSTEON                "Porch Back Yard Sec" on
  Trigger                         Porch West Sync
  Sent INSTEON                    "Porch Back Yard Sec" on to 100
  Received INSTEON                "Porch Back Yard Sec" off
  Sent INSTEON                    "Porch Back Yard Sec" on to 0
Sat Aug 31, 2013 9:23 am
Dewster35 offline
Just the nature of some of the insteon motion sensors is that they send out duplicate on and duplicate off commands, so it's not something you're doing wrong. You just have to have your logic setup right to account for it.
Sat Aug 31, 2013 9:27 am
In this case the easiest way to avoid problems is to make your triggers use the Device State Changed type and not the INSTEON command received type. The former will only fire when the state transitions from OFF to ON, while the latter will fire twice if there are duplicate back-to-back commands.
Sat Aug 31, 2013 7:53 pm
Bollar offline
Mm, okay.
The care and feeding of these Insteon motion sensors is quite a lot of work. Maybe my next group will be Z-Wave.
Sun Sep 01, 2013 9:59 am
Well, while I don't disagree that the INSTEON motion sensors have some special challenges, in this particular case I don't think this should be considered doing something "special" or out of the ordinary.
Device State changes are almost always preferable to catching raw commands IMO - because it's a single concept that works exceptionally well across many different device types and it allows us to present a more unified mechanism that hides details (like, say, multiple duplicate commands) that are often not that useful to users.
Sun Sep 01, 2013 12:32 pm
Bollar offline
Well, my griping was more about the sensor itself, rather than Indigo.
In this case, I used "Insteon Command Received" for a couple of reasons -- mainly, the device has three groups, and it wasn't clear to me which group "Device State" followed. If device state follows group 1, I can change those triggers and leave groups 2 & 3 as Insteon Commands.
The good news for me is that the motion sensors are the only place where I've used Insteon Command Received - all the other devices are Device Changed.
Maybe a future version of Indigo could set up these sensors like the FanLinc and have separate devices for each of the groups?
Mon Sep 02, 2013 10:17 am
ethanw offline
Can I use the INSTEON Motion Sensor as an alarm sensor? There are some areas in the house that needs extra coverage.
I am thinking leveraging those sensor to write to my Ademco alarm panel through the ad2usb plugin.
Basically someone walks in the house the sensor will trigger a script that writes to the Ademco alarm to go off instantly.
Is this possible? Any pro any cons?
Mon Sep 02, 2013 12:32 pm
berkinet offline
ethanw wrote:
Can I use the INSTEON Motion Sensor as an alarm sensor? ...Is this possible? ...Any pros any cons?
Yes. The ad2usb can create virtual expander modules with 8 zones each. You can then create Indigo Managed Virtual Zone devices with the ad2usb plugin. You control the state of those zones (clear, fault or trouble) in an Indigo Trigger or Action Group with an ad2usb plugin action. There is no scripting necessary. Note that you will also need to create zones definitions in your panel, just as you would if they were provided by a real expander board.
The Pros:
  • It is easy to add devices like motion detectors to your panel.
  • Devices can be logic based as well as physical. For example, if the kitchen light goes on when the house is empty, fault the alarm.
  • You can create No Alarm Response (type 23) zones for things like leak/flood sensors, a garage door left open too long, temperature too hot or cold, etc.
The cons:
  • Unless the motion sensor or other device is dedicated to alarm use, you need to be very careful with the Indigo configuration, especially conditions, to avoid setting false alarms.
  • Any zones you create are as reliable as your Mac, OS X, Indigo and your configuration/programming skills.
  • INSTEON motion detector battery life sucks compared with wireless alarm grade equipment.
  • Unlike Alarm grade motion detectors, INSTEON motion detectors are not designed to avoid false triggers (I.e. pets).
But, on the whole, if you can manage the cons, I'd say this is a worthwhile project with a lot of return for relatively little effort.
Mon Sep 02, 2013 1:21 pm
ethanw offline
Thanks much partner for the great guidance :)
I can live with the cons. This is strictly for alarm purpose and nothing else. What's the battery life span in one of those?
This is the best option to add a motion sensor since I have no wiring to the locations I want them installed.
Cheers and thanks again
The Pros:
The cons:
Mon Sep 02, 2013 2:02 pm
berkinet offline
ethanw wrote:
...I can live with the cons. This is strictly for alarm purpose and nothing else. What's the battery life span in one of those?
In my experience (I.e. YMMV) with the Insteon MDs I get 3 to 4 months life from a good (I.e. NOT Kirkland) Alkaline batteries and maybe 6 months plus with Lithiums . That is vs. 5 years for the Ademco and similar alarm grade products.
Another possibility for you is to add a wireless receiver (either directly to the panel or in a keypad/receiver combination) and then use regular Ademco MDs. Through use of the ad2usb plugin, you can then use the Ademco MDs for Indigo triggers, even when the panel is not armed. An Ademco 5881ENM sixteen zone wireless receiver
costs around $75 and an Ademco 6160RF Alpha Keypad and Receiver costs around $125.
However, note that the Insteon MDs will generally trigger faster then an Ademco. That is largely due to the anti-falsing technology built into the commercial MDs. OTOH, the commercial MDs will generally re-trigger more often than the Insteon MDs. So, if you want snappy lights on/off action, the Insteons are preferable.
And finally. While the commercial alarm MDs are certainly better quality, even basic MDs like the Honeywell 5800PIR cost almost double what the Insteons cost. ($65 vs. $35)
If alarm use is your primary need, I'd say expand your panel if you can and then use the new wireless panel zones in Indigo. But, if you have pressing HA needs or a limited budget, go with the Insteons.
I guess the good news, and the bad news, are both that you have a lot of options :)
Wed Oct 02, 2013 6:48 pm
rjeffl offline
I also have noticed the double messages sent from the motion detector.
All seems to work fine when detecting a device state change from off to on.
[color=#0000FF]Sep 30, 2013 9:21:17 PM
  Received INSTEON                "Workshop Motion" on (button 1)
  Trigger                         Workshop Motion Detected
  Sent INSTEON                    "Workshop Lights" on
Sep 30, 2013 9:21:51 PM
  Received INSTEON                "Workshop Motion" off (button 1)
  Trigger                         Workshop Motion Stopped
  Received INSTEON                "Workshop Motion" off (button 1)[/color]
My question is about the button nomenclature in the log message, button 1, 2, etc. Does this indicate the "group"?
I see the following messages from the detector during the day.
[color=#0000FF]Oct 2, 2013 11:07:02 AM
  Received INSTEON                "Workshop Motion" off (button 2)
Oct 2, 2013 11:11:08 AM
  Received INSTEON                "Workshop Motion" on (button 2)
Oct 2, 2013 11:39:44 AM
Oct 2, 2013 2:16:25 PM
  Received INSTEON                "Workshop Motion" on (button 2)[/color]
Is this indicating a transition from dark to light, etc.?
Obviously the device state trigger ignores this, except may uses this as a qualifier or condition?
Is there a way to trigger on this button 2 transition?
If my understanding is correct, the detector will send a button 3 message when the battery is low?
Is there a way to trigger on a button 3 transition?
Just getting started with insteon and indigo, so all new to me.
Thanks.
Jeff
Wed Oct 02, 2013 7:04 pm
rjeffl offline
OK. Guess I answered one of my own questions.
I can see in the trigger form if I set the type to Insteon Command Received, I can select group 1, 2, or 3.
I guess what has me confused is the Button 1, 2 nomenclature in the log.
Might be less confusing if this were posted to the log as (Group 1) or (Group 2).
Jeff
