INSTEON Motion Sensor
Sun Aug 13, 2017 11:15 am
jphauck offline
Re: INSTEON Motion Sensor
I feel like I have tried everything to change the flashing on these new motion sensor 2 units.
They are awesome motion sensors. They are super responsive, and with the USB power adapter the battery issue is gone.
However I have had to resort to covering the bedroom unit when I go to sleep because of the extremely bright LED flash for motion that in a dark room is crazy.
Anyone have any luck changing that setting? I have tried everything I can think of.
Jim
Jim H.
Concord, CA
Thu Aug 17, 2017 12:12 am
kelmk offline
Jim
I can’t get the light to turn off either. I have tried through the Insteon app with no luck.
Thu Aug 17, 2017 6:14 am
jalves offline
Jim
Don't know if this will work for you, but there is a raw command that turns off some pilot light type things (dimmer switches and fanlinks). I used it to turn off the LED's in my fan links to keep them from glowing in a dark room. Might be worth a try for the motion sensor.
Interfaces > Insteon/X10 Powerline > Execute Raw Insteon Command
Select Device from list
Command 1 Byte 0x20
Command 2 Byte 0x08 [turns them OFF] 0x09 [turns them ON]
Check "send extended message"
Jeff
Sat Oct 14, 2017 12:28 pm
jphauck offline
Tried that raw command and what it says I am executing does not match what I typed.
Tried on a ceiling fan and a motion sensor - results:
Error "Office - Sensor - Motion" raw insteon command; failed (checksum invalid)
INSTEON Commands Error Command didn't return successfully. Here's the command sent: [32, 8]
Error "Office - Light - Cieling Fan" raw insteon command; failed (checksum invalid)
Error "Office - Fan - Cieling" raw insteon command; failed (checksum invalid)
Jim H.
Concord, CA
Wed Nov 01, 2017 8:44 pm
Traumatized1 offline
Re: INSTEON Motion Sensor 2
I have a new insteon motion 2. I have out working to send on command to trigger light.
It seems to work well but two nights ago it started sending out a button 19 on command every 30 seconds to 1 minute.
Does anyone know what this is and how to stop it?
Rf
Thu Nov 02, 2017 8:02 am
I'm not sure what group/button 19 broadcasts mean from that module (the module's manual, unfortunately, isn't helpful in that regard). Did you try removing/reinstalling the batteries to see if that gets it to stop? If not I'd suggest you try a factory reset and then resync it with Indigo.
Wed Nov 08, 2017 8:41 pm
jphauck offline
I just started getting those as well on a new motion sensor. What is that all about?
Jim H.
Concord, CA
Sun Nov 12, 2017 7:14 pm
I have been out of town.
Reset did not work.
I bought an Insteon Hub to program motion since the Indigo support for it is suboptimal.
The button 19 on went away for a while then came back.
I have no problem with indigo as I receive the ON that i need to trigger a dog flood motion to go on. With a software off command.
The button 19 ever 30 seconds os annoying.
Please advise.
Rf
Fri Nov 17, 2017 11:55 pm
I'm not sure what that group number is about. The newer motion sensor is poorly documented. We'll try to get the details from Smarthome again.
Sat Nov 18, 2017 8:00 am
Thank you very much
Wed Dec 06, 2017 7:15 am
This is driving me nuts.
Any idea for Insteon motion 2
received button 19 on every minute.
Rf
Sat Dec 09, 2017 1:19 pm
I'm going to try contacting Smarthome again for technical documentation, but in the mean time I suggest you call their customer support and/or post on this forum to see if you can find out how to prevent it from sending that message.
Sun Jan 07, 2018 12:42 pm
jphauck offline
I finally just pulled my unit that was doing this motion call mentioned above. I replaced it with a new unit and it was fine. The only thing different I did when I first install this was to replace a previous generation MD and just resync. That might be the problem I dont know.
Jim H.
Concord, CA
Sun Jan 07, 2018 12:54 pm
There is a problem with the version 2 motion detector. It has a temp sensor that sends out this every minute button 19 on at a certain tempoeorature. This kills th battery life to under 4 weeks in a cold climate. No way to turn it off.
Flaw with insteon motion 2 outdoors in the cold. They need to fix it.
Very disappointed in it.
Rf
Mon Feb 05, 2018 12:49 pm
Did you hear that from Smarthome support, or find it online somewhere? I'm curious as to what the conditions are (specific temperature) when it starts sending out the message.
Page 5 of 9 1, 2, 3, 4, 5, 6, 7, 8, 9
