Aeon Labs Z-Stick Plus Gen5 (ZW090)
Thu Aug 20, 2015 9:05 pm
This thread is for discussing the Aeon Labs Z-Stick Plus Gen5 (ZW090).
Device details
How to use with Indigo
Fri Aug 21, 2015 12:10 am
wiery offline
Re: Aeon Labs Z-Stick Plus Gen5 (ZW090)
Is it officially supported now ?
Fri Aug 21, 2015 8:19 am
Yes (that's the purpose of the Supported Hardware forums and subforums).
One caveat: Indigo doesn't yet support secure mode, so you should include devices in the normal mode.
Fri Aug 21, 2015 1:23 pm
wiery offline
I get the following error every time i sync with the Gen 5 Z-stick, i presumed it was because its unsupported but this is with 6.1.3
2015-08-20 10:27:59.837 Z-Wave Syncing - started for device "008 - Routing Slave"
2015-08-20 10:27:59.868 Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 5, 6
2015-08-20 10:27:59.868 Z-Wave Syncing - requesting neighbor list update of "008 - Routing Slave"
2015-08-20 10:28:03.921 Z-Wave Syncing - neighbor list update complete (no change)
2015-08-20 10:28:03.921 Z-Wave Syncing - assigning return route to "008 - Routing Slave"
2015-08-20 10:28:04.648 Z-Wave Syncing - assigned return route
2015-08-20 10:28:04.892 Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Recessed Door Sensor (ZW089) - 00020059
2015-08-20 10:28:05.017 Z-Wave Syncing - retrieved protocol version 3.92, app version 1.12
2015-08-20 10:28:05.148 Z-Wave Syncing - retrieved class hierarchy: Routing Slave : -- : -- (04 : 07 : 01, base 00)
2015-08-20 10:28:05.148 Z-Wave Syncing - retrieved command classes: 80v1 30v1 84v2 85v1 86v1 70v1 71v1 72v1 73v1 98v1 59v1 7Av1 5Ev1
2015-08-20 10:28:05.280 Z-Wave Syncing - retrieved wake interval of 1440 minutes
2015-08-20 10:28:05.422 Z-Wave Syncing - device "008 - Routing Slave" wake interval changed to 60 minutes
2015-08-20 10:28:05.679 Z-Wave Syncing - retrieved group 1 associations: [1]
2015-08-20 10:28:05.813 Z-Wave Syncing - retrieved group 2 associations: []
2015-08-20 10:28:05.813 Z-Wave Syncing - group 1 association to interface already exists (skipping)
2015-08-20 10:28:06.762 Z-Wave Syncing - retrieved battery level of 100%
2015-08-20 10:28:06.889 Z-Wave Syncing - changed device "Sitting Room - Blind 1 Sensor" type from zwCustomType to zwOnOffSensorType
2015-08-20 10:28:06.901 Group Trigger Error Error in plugin execution ServerReplacedElem:
File "plugin.py", line 290, in deviceUpdated
<type 'exceptions.KeyError'>: key onOffState not found in dict
2015-08-20 10:28:06.902 SQL Logger adding column "onoffstate" to table device_history_80375916 ("Sitting Room - Blind 1 Sensor")
2015-08-20 10:28:06.927 Z-Wave Syncing - complete
Fri Aug 21, 2015 4:05 pm
That error is for the Group Trigger 3rd party plugin, not Z-Wave...
Sat Aug 22, 2015 1:33 pm
nathanw offline
Z-Stick Plus Gen 5 radio range?
I recently replaced my S2 stick with a Gen5 stick. The reception range on the Gen5 stick seems a lot worse - the stick has been with the Mac in the basement of my house, and it can no longer hear from the Multisensor 5 in a room on the second floor, which I used to get regular updates from. Additionally, I picked up a Smart Switch 6 (mostly for the power monitoring feature), and discovered that the Z-Stick couldn't hear from it when it was behind my refrigerator, just above the basement room with the stick (It could transmit to it, though - toggling the SS6 worked, even if Indigo didn't see the ack). Moving it to another outlet about three feet farther from the stick (but not behind a refrigerator) worked fine.
Does this match anyone else's experience? Are there any radio-power settings to adjust? Or could it be defective? I've tried a couple of different physical orientations of the stick, without visible effect.
Sun Aug 23, 2015 1:03 am
Coolcaper offline
If anything my reception has gotten better, so don't know. Might be an issue with the stick? Aeotec were supposed to release a tool to check the health of various nodes in June but so far I haven't received an update.
Sun Aug 23, 2015 1:09 am
lochnesz offline
The IMA tool is available on the Aeotec web. Only for Windows though. I haven't tried it, but I got this from their support:
"It does take awhile to run, and it will run tests for each device multiple times before giving you a health notification.
It does not work for battery devices and only powered products.
Testing a single node takes upwards of 1-4 minutes."
Peter
Sun Aug 23, 2015 9:05 pm
Coolcaper offline
Thanks for that Peter. I never checked again on their website as they said they would get in touch. Again like you said it's windows only so I wonder how much can be done with that!
Wed Sep 30, 2015 6:52 am
norcoscia offline
Does anyone know how to find out what the latest firmware version is for the Aeon Labs Z-Stick Plus Gen5 - I can find the download on their site but the text notes do not provide any info concerning. What version is in the download, what versions exist, what changed between versions. Thanks in advance for any help!
_______
Norm
Thu Oct 01, 2015 2:37 am
lochnesz offline
I can't see any new firmware for the gen5 stick on their web. Only the IMA tool and drivers. Where do you see it?
Peter
Thu Oct 01, 2015 6:30 am
norcoscia offline
On the support page, to be honest I assumed the driver listed under the Gen5 stick was the sticks firmware - I assumed that since down the page they list the drivers for all of the OS's ( they support). I'm also unsure why they list MAC drivers (on the bottom of the page) when up in the top section of the page it says MACs don't need drivers.
I don't have a stick yet I'm just doing some homework before I jump into Z wave with Indigo. I have a lot of z-wave parts from my last HA adventure and at some point I want to repurpose them if possible / practical.
_______
Norm
Thu Oct 01, 2015 9:47 am
The driver link at the bottom (which, last time we checked, was terribly out of date) is for the Z-Stick Series 2, not the Gen5.
Thu Oct 08, 2015 9:31 am
stevemac00 offline
I'm a retired engineer but I'd appreciate being treated like a Millennial. (What are the "3 Thing I need to Know" to make this work?)
I doubt I can simply unplug the old and plug in the new.
The two links Matt posted at the top of the thread are funny but not much help.
Can you post the steps to swap out my old black z-stick with the new one?
(My old black one is still working since getting torqued when the Mac was bumped but the USB connector is loose.)
Thu Oct 08, 2015 3:35 pm
See this forum thread:
viewtopic.php?f=58&t=14764
Users browsing this forum: jltnol and 1 guest
