Had another blip this morning, EVO and Reflector went down but yesterday I could not turn the TRV's up and down with the up/down arrows today they worked and went to look at the Dining Room TRV and it had increased from 19c to 21c as per log file so it seems you fixed it with the update.
All TRV's now moved over to your plugin, Apple Home working fine with it, 24 hours more and I will update Indigo to latest version,
2 questions
Do you poll the EU server regularly
Call it Evohome instead of Honeywell Evohome (just a suggestion to cut down the length in log and differentiate between your plugin and original.)
- Code: Select all
21 Oct 2023 at 08:27:32
Honeywell Evohome Error [Sat Oct 21 08:27:32 2023] Cannot read Evohome data
Honeywell Evohome Error [Sat Oct 21 08:27:32 2023] Failed to retrieve Evohome data. Aborting update and trying again in 30 seconds
21 Oct 2023 at 08:28:48
Zigbee2mqtt Bridge received "Z Conservatory Left Window Contact" battery level 83%
Zigbee2mqtt Bridge received "Z Conservatory Left Window Contact" voltage 2.975 Volts
21 Oct 2023 at 08:30:00
Z-Wave received "Front Door Lock" status update battery level 90%
21 Oct 2023 at 08:31:19
Honeywell Evohome [EVO Zone: Bathroom]: Setting Heat Setpoint to: 18.0
21 Oct 2023 at 08:32:13
Z-Wave received "En Suite Floor Heating Thermostat" temperature update to 14.0 °C
Error reflector connection test failed: unable to connect to server
Warning reflector reconnection scheduled in 5 seconds
Reflector restarting reflector connection to https://highsteads.indigodomo.net
Honeywell Evohome [EVO Zone: Bathroom]: Setting Heat Setpoint to: 17.0
21 Oct 2023 at 08:33:56
Honeywell Evohome [EVO Zone: Conservatory]: Setting Heat Setpoint to: 9.0
21 Oct 2023 at 08:34:18
Honeywell Evohome [EVO Zone: Utility Room]: Setting Heat Setpoint to: 13.0
21 Oct 2023 at 08:36:34
21 Oct 2023 at 08:37:09
Honeywell Evohome [EVO Zone: Dining Room]: Setting Heat Setpoint to: 20.0
Honeywell Evohome [EVO Zone: Dining Room]: Setting Heat Setpoint to: 21.0
