homematic: latest release
Sat Oct 28, 2023 5:42 am
first non beta released: V2022.1.2
it supports > 29 HmIP device types (switches, sensors, weather station, keypad, thermostats, valves for underflow heating etc).
see https://forums.indigodomo.com/viewtopic.php?f=400&t=27520 for details for install, supported devices, etc.
Tue Nov 07, 2023 9:44 am
Re: homematic: latest release
changes in V2022.2.3 2023-10-28
added:
- HMIP-PCBS: outlet relay on a pc board
- rain start / stop
- rain today, yesterday total
- energy usage total
- sun shine duration
in the pipeline:
- HMIP-MIO16-PCB 16 channel i/o analog and digital / relay
fixed:
- wrong mapping of some states
- reduced updates of states to minimum (only when changed)
- some minor issues
supported devices
- HMIP-SPDR:           left <-> right passage sensor
- HMIP-KRC4:           4 key button
- HMIP-WRC6:           6 button remote
- HMIP-WKP:            Keypad sensor
- HMIP-WRC:            2 button wall switch
- HMIP-RC8:            8 button remote
- HMIP-FCI6:           6 switch on/off
- HMIP-SDW :           water alarm sensor
- HMIP-SWSD:           smoke alarm sensor
- HMIP-SWDO:           optical on / off sensor
- HMIP-SCI:            on / off kabel sensor
- HMIP-SWDM:           magnet on / off sensor
- HMIP-SMI:            Motion Sensor
- HMIP-SRD:            Rain sensor
- HMIP-SWO-PR:         prof weather station
- HMIP-DLD:            Door key open / closer
- HMIP-WRC:            turn left righ push switch
- HMIP-STHO:           internal / external Temp / humidity sensor
- HMIP-FALMOT-C12:     12 channel underfloor heating
- HMIP-FAL230-C10:     10 channel  230V underfloor heating
- HMIP-FAL230-C6:      6 channel  230V underfloor heating
- HMIP-FAL24-C10:      10 channel  24V underfloor heating
- HMIP-FAL24-C6:       6 channel  24V underfloor heating
- HMIP-WTH:            wall thermostat (various types)
- HMIP-ETRV:           radiator attached thermostat (various types)
- HMIP-PS:             powerplug switch
- HMIP-PSM:            powerplug switch w energy measurement
- HMIP-PDT:            powerplug  dimmer
Wed Feb 14, 2024 4:55 am
changes in V2022.3.3 2024-02-14
supported devices (34 + sub versions)
- HMIP-KRCx:           x button key
- HMIP-WRCx:           x button remote
- HMIP-WKP:            10 digit Keypad
- HMIP-WRC:            1-2 button wall switch
- HMIP-RCx:            x button remote
- HMIP-SCI:            on / off cable sensor
- HMIP-STI:            Capacitor button sensor
- HMIP-STV:            Tilt and movement sensor
- HMIP-SCTH:           wall CO2 Temp Humidity sensor
      -BWTH            wall thermostat
- HMIP-USBSM:          USB V, A, P, measurement and relay board
- HMIP-PCBS:           low volt relay
in the pipeline:
-HMIP-MP3P             mp3 player and light alarm
-HMIP-MIO16            multichannel io board
-HmIP-MOD-OC8          8 channel output swtch open collector
Wed Mar 20, 2024 11:06 am
changes in V2022.5.4 2024-03-20
added several new device types and more functionality
this version is fully functional, mst devices are supported, most functions are supported.
supported device types (66 + sub versions)
### homematic name       indigo dev type               what kind of device type
   "HMIP-FALMOT":      "HMIP-FALMOT",            # floor heating system valve driver
   "HMIP-DLD":       "HMIP-DLD",               # Door-Lock
   "HMIP-DBB":       "HMIP-BUTTON",            # handheld remote switch   #### button devices need a simple program in homematic: just trigger on any change of button- no action required, then the indigo state will be updated
   "HMIP-DSD":       "HMIP-BUTTON",            # battery board ring sensor/ switch
   "HMIP-BRC":         "HMIP-BUTTON",            # behind wall switch
   "HMIP-RC":         "HMIP-BUTTON",            # any handheld switch
   "HMIP-RC8":         "HMIP-BUTTON",            # 8 button
   "HMIP-KRC":         "HMIP-BUTTON",            # 4 button hand device
   "HMIP-KRCA":      "HMIP-BUTTON",            # 4 button hand device
   "HMIP-FCI":       "HMIP-BUTTON",            # x channel behind wall switch / button
   "HMIP-STI":         "HMIP-BUTTON",            # capacitor single / double button
   "HMIP-WRC2":       "HMIP-BUTTON",            # wall switch 2
   "HMIP-WRCC2":       "HMIP-BUTTON",            # wall switch 2
   "HMIP-WRC4":       "HMIP-BUTTON",            # wall switch 4
   "HMIP-WRC6":       "HMIP-BUTTON",            # wall switch 6
   "HMIP-WRCR":       "HMIP-BUTTON",            # wall switch rotate
   "HMIP-WRCD":      "HMIP-WRCD",            # switch w display
   "HMIP-WKP":       "HMIP-WKP",               # key pad
   "HMIP-SWO-PR":       "HMIP-SWO-PR",            # weather sensor temp, hum ,rain, wind, wind direction, sun
   "HMIP-SWO-PL":       "HMIP-SWO-PR",            # weather sensor temp, hum ,rain, wind,                 sun
   "HMIP-SWO-B":       "HMIP-SWO-PR",            # weather sensor temp, hum ,rain, wind
   "HMIP-SRD":       "HMIP-SRD",               # rain sensor
   "HMIP-SL":          "HMIP-SL",               # Light sensor
   "HMIP-SFD":       "HMIP-SFD",               # particulate sensor
   "HMIP-STE2":       "HMIP-STE2",            # particulate sensor
   "HMIP-STHO":       "HMIP-STHO",            # Temp-Humidity Sensor
   "HMIP-SCTH":       "HMIP-SCTH",            # CO2 Temp Humidity Sensor
   "HMIP-SWSD":       "HMIP-SWSD",            # smoke alarm
   "HMIP-SCI":       "HMIP-SWDM",            # contact sensor
   "HMIP-SWDM":       "HMIP-SWDM",            # Magnet Contact sensor
   "HMIP-SRH":       "HMIP-SRH",               # window open=2/tilted=1/close=0
   "HMIP-STV":       "HMIP-SWDM",            # tilt sensor
   "HMIP-SWDO":       "HMIP-SWDM",            # optical sensor
   "HMIP-SWD||":       "HMIP-SWD",               # eater sensor,  || only accept strict HMIP-SWD no additional characters
   "HMIP-SPDR":       "HMIP-SPDR",            # left right pass sensor
   "HMIP-SAM":         "HMIP-SAM",               # gravity, movement sensor on/off
   "HMIP-SMI":         "HMIP-SMI",               # movement sensor inside
   "HMIP-SMO":         "HMIP-SMI",               # movement sensor outside
   "HMIP-SPI":         "HMIP-SMI",               # movement sensor
   "HMIP-MOD-OC8":    "HMIP-MOD-OC8",            # 8 channel open collector output switch
   "HMIP-MIO16-PCB":    "HMIP-MIO16-PCB",         # multi channel i/o 4 analog trigger, digital trigger, 4 open collector, 4 relay output
   "HMIP-MP3P":       "HMIP-MP3P",            # sound/ light output
   "HMIP-ASIR":       "HMIP-ASIR",            # alarm siren
   "HMIP-FROLL":       "HMIP-ROLL",            # Jalousie(Jealousy) / curtains  up / down  / left right
   "ELV-SH-WSC":       "ELV-SH-WSC",            # 2 channel servo controller
   "HMIP-PDT":       "HMIP-PDT",               # dimmer output
   "HMIP-FDT":       "HMIP-PDT",               # dimmer output
   "HMIP-BDT":         "HMIP-PDT",               # dimmer outlet
   "HMIP-DRD3":      "HMIP-PDT3",            # 3 dimmer fuse box
   "HMIP-DRBL":      "HMIP-PDT4",            # 4 dimmer fuse box
   "HMIP-DRSI1":      "HMIP-PS",               # on/off germnan fuse box relay
   "HMIP-PS||":      "HMIP-PS",               # on/off outlet
   "HMIP-FS":         "HMIP-PS",               # on.off outlet
   "HMIP-PS-":         "HMIP-PS",               # any simple on/off outlet
   "HMIP-PCBS||":      "HMIP-PS",               # on/off board relay
   "HMIP-PCBS-":      "HMIP-PS",               # on/off board relay
   "HMIP-PCBS2":      "HMIP-PS2",               # 2 on/off board relay
   "ELV-SH-SW1-BA":   "HMIP-PS",               # on/off board relay w battery
   "HMIP-WGC":         "HMIP-PS",               # garage door controller
   "HMIP-DRSI4":      "HMIP-PS4",               # on/off german fuse box 4-relay
   "HMIP-PSM":       "HMIP-PSM",               # on/off outlet w energy measurements
   "HMIP-FSM":       "HMIP-PSM",               # on/off outlet w energy measurements
   "HMIP-USBSM":       "HMIP-PSM",               # on/off outlet w energy measurements USB
   "HMIP-BSM":         "HMIP-PSM",               # PowerOutlet Switch W Energy measurement
   "HMIP-ETRV":      "HMIP-ETRV",            # eTRV-RadiatorValve
   "HMIP-BWTH":       "HMIP-WTH",               # wall thermostat
   "HMIP-WTH":       "HMIP-WTH",               # wall thermostat
## supporting device types
   "HMIP-HEATING":    "HMIP-HEATING",            # heating group of several EVTR and WTH, not a real device
   "RPI-RF-MOD":       "Homematic-AP",            # RPI host
   "HMIP-HAP":       "Homematic-AP",            # ACCESS point
   "ROOM":          "HMIP-ROOM"               # room, not a real device , shows devices in room
##   "HMIP-SYSVAR":       "SYSVAR-xxx"            # xxx = FLOAT, BOOL, STRING, ALARM
available menu - Actions:
set dimmers, relays, colors, alarm, Displays, set system variables
does not support HM (no ip) devices, not supported by CCU jack
  but can be read by using a system-variable and script
Fri Mar 29, 2024 6:15 am
changes in V2022.5.5 2024-03-29
added menu/action option to send a value to any homematic sysvar
added option to add an offset to states like temperature, humidity etc.
