link to external url
Sun Jan 20, 2013 4:11 am
mat offline
i have control page button to toggle my projector on and off.
   if value of variable "CINEMAOFFSAFE" = "YES" then
      if value of variable "cinemamode" = "on" then
         execute trigger action "Cinema mode off"
         set value of variable "cinemamode" to "off"
      else
         execute trigger action "Cinema mode on"
         set value of variable "cinemamode" to "on"
(i need a "link to external url" to start plex on the ipad here)
      end if
   else
      execute trigger action "Projector warning"
   end if
end tell
which runs perfectly and checks not to power off if the projector has only been on for a short period of time to save the bulb.
in the "link to external url" I use "plexapp://" to start plex on the iso device that the projector was trigger from. The only issue is, as the button on the control page is a toggle, when i switch the projector off again, plex launches again (as it should because at present the external link is triggered again).
Is there a way to include the "link to external url" within applescript, so that I can make plex launch only when the projector is turned on - ie where noted conditionally in the script above?
I've searched but to no avail. Any suggestions please?
Late 2018 mini 10.14
Sun Jan 20, 2013 4:17 am
Re: link to external url
Hi Mat,
Unfortunately, no. Those URL click actions are client-side only, so the server cannot run any type of script or conditional before it occurs. There are server side actions as well, but those are handled differently and independently from the URL or control page navigation actions.
Sun Jan 20, 2013 7:42 am
mat offline
Thanks for the quick reply Matt.
No worries, its only the press of a button on the iPad, was just trying to make it slicker.
Cheers
Mat
Thu Feb 14, 2013 11:11 am
axlbundy offline
Sorry to hop into this thread but I'm currently working on my control pages and I've been able to create external URLs for certain apps (Remote, Plex, etc) but I do not know how to find the addresses to use for all the apps that I want to create shortcuts to. For example the Sirius XM app. Can you help me figure this out? There are probably 10 different apps that I need urls for.
Joe
Fri Feb 15, 2013 7:50 am
Hi Joe,
The site handleOpenUrl has a database, but it looks like the Sirius app isn't in there. Note the application has to add support for handling the openUrl command, so it is possible the Sirius app doesn't have that implemented.
Thu Feb 21, 2013 12:58 pm
axlbundy offline
Bummer about the Sirius app, but thanks for the link. I'll have to cross reference it with my installed apps.
