I don't mean to hijack this thread, but I thought it would be worth noting:
Changing duration [minutes running] is NOT the proper way to irrigate.
- The purpose of irrigation is to water the roots [8-12 inches for lawn] EVERY TIME.
- If it takes 30 minutes for your water to reach the roots [based on soil type], it does so the same in March as it does in September.
- The correct way to irrigate is to adjust the FREQUENCY [or dry out period]
So your lawn schedule might look something like this:
- January/30 min/every 14 days
- May/30 min/ every 7 days
- September/30 min/ every 2 days
Deep soak >> dry out >> Deep soak >> dry out = Deep happy root system 8-12 inches down
Constant short cycles = Shallow unhealthy root system Shorter durations may only get the water 3-5 inches, and thats where your root system will grow.
The closer the roots are to the surface the more they are affected by the environment. Deep = Good
I use a water meter probe to determine when the next irrigation day will occur. The meter range is [0] DRY - [10] WET.
[5] is my target
Hope this was helpful to someone.
