Convert Military Time to Standard Time?
Sat Jul 02, 2011 5:00 pm
ckeyes888 offline
Curious if it's possible using AS to convert military time to standard time, e.g. 2330 to 11:30 pm?
I use military time for my sprinkler set time, easier to adjust adding or subtracting to, and I'd like to be able
to have reminders/announcements based on that time, but in the am/pm format.
Carl
Sun Jul 03, 2011 6:03 am
bschollnick2 offline
Re: Convert Military Time to Standard Time?
Carl, the formula for Military Time is simple...
Here's some pseudo code:
If hour => 13:
# Time is 24 hr
new_hour = hour - 12
And vice versa.
There is nothing tricky about 24 hour time...
Here's code to convert to 24 hour. The reason I am showing it, is simply to illustrate that most of the code is there to decode the time string...
I wasn't able to find any 24 to 12 code, at least my google foo failed me... I know it's out there...
-- This assumes that the input is a 12-hour time string, that any separators in it are colons, and that it ends with either "am" or "pm".
on h12toh24(input, separator)
set t to words of text 1 thru -3 of input
if (text -2 thru -1 of input is "pm") then set item 1 of t to (item 1 of t) + 12
repeat 3 - (count t) times
set end of t to 0
end repeat
tell (1000000 + (item 1 of t) * 10000 + (item 2 of t) * 100 + (item 3 of t)) as text
return text 2 thru 3 & separator & text 4 thru 5 & separator & text 6 thru 7
end tell
end h12toh24
for v5 - http://bit.ly/T6WBKu
Sun Jul 03, 2011 8:24 am
ckeyes888 offline
Many thanks Ben. Good example to learn from as well.
Carl
Sun Jul 03, 2011 12:52 pm
ckeyes888 offline
Found this code but have no idea if/how to implement it to set a variable in Indigo.
"Simple and clean... convert 24 hour format to 12 hour format with PHP native functions.
BTW, works in the other direction too (12 hour to 24 hour)... that's the second line below"
<?=date("g:i a", strtotime("13:30"));?>
<?=date("H:i", strtotime("1:30 pm"));?>
Can something like this be used?
Carl
Sun Jul 03, 2011 3:32 pm
ckeyes888 offline
Found another. Got this one working.
set militaryTime to value of variable "sprk_Start_Time"
set standardTime to militaryTimeToStandardTime(militaryTime)
on militaryTimeToStandardTime(militaryTime)
    set militaryTime to militaryTime as text
    set theHour to text 1 thru 2 of militaryTime
    set theMinutes to text 3 thru 4 of militaryTime
    set theHourNumber to theHour as number
    if theHourNumber is equal to 24 then
        set standardTime to "12:00 AM"
    else if theHourNumber is greater than 12 then
        set theHourNumber to theHourNumber - 12
        set standardTime to (theHourNumber as text) & ":" & theMinutes & " PM"
    else if theHourNumber is equal to 12 then
        set standardTime to theHour & ":" & theMinutes & " PM"
    else if theHourNumber is equal to 0 then
        set standardTime to "12" & ":" & theMinutes & " AM"
    else
        set standardTime to theHour & ":" & theMinutes & " AM"
    end if
    set value of variable "sprk_Start_Time_AmPM" to standardTime
end militaryTimeToStandardTime
Sat Jul 16, 2011 8:05 am
ckeyes888 offline
Hmm...well the above script works if the military time variable is all four characters, 0021 etc.
If it's less than four characters, 21 etc., it doesn't work.
Any help in a fix?
Carl
Tue Jul 19, 2011 2:30 pm
Brandt offline
Ben is better at AS than I am, but if militaryTime is a standard AS timestamp then you could do something like:
set standardTime to ((militaryTime div hours) - 12) & ":" & (militaryTime div minutes)
if (militaryTime div hours) > 12 then
set timeNotation to "pm"
else
set timeNotation to "am"
end if
set standardTime to standardTime & timeNotation
    else
    end if
Indigo 7 w/ Dual-Band 2413U PLM
macOS High Sierra 10.13.x
2011 iMac 3.4 GHz Intel Core i7
Thu Jul 21, 2011 9:54 am
ckeyes888 offline
Been trying variations of this with no luck:
        set timeNotation to " pm"
    else
        set timeNotation to " am"
    end if
end tell
Carl
Thu Jul 21, 2011 11:41 am
Brandt offline
Carl,
The computer relies on a complete date/time stamp, and this complete stamp stored in your variables would make it easier to interact with using AS. I assume you are just putting a time like "2300" as the value of the variable? Is your system time set to 12 or 24 hour format? Can you give us a bigger (more detailed ) overview of what you are trying to do? We may be making this more complicated than it needs to be.
-Brandt
Thu Jul 21, 2011 12:39 pm
Brandt offline
military time by standard isn't ever written with less than 4 characters ( i should know I was in the Navy ;) ) Applescript isn't really meant to handle this it is meant to communicate between mac applications, in other words it's not really the right tool for the job. Indigo 5 supports python, which would probably be a better tool for the job.
Any help in a fix?
Carl
Thu Jul 21, 2011 12:55 pm
ckeyes888 offline
My system clock is using the 12 hr format. I use the military time format for my sprinkler
countdown timer variable as it just seemed easier to add/subtract from, due to rain/heat etc.
with my incredibly limited knowledge of AS.
I have a script that executes whenever the variable "sprinkler_start_time" changes to convert it to standard time which sets another
variable, sprinkler_start_time_AmPm", which I use for display purposes on CP's etc.
Again, the script I'm using works fine if the military time variable is all four digits, 0045,
but doesn't if it's less digits, e.g.45.
Hope this is making some sense anyway.
Carl
Thu Jul 21, 2011 1:19 pm
Brandt offline
ok well use your original code, just add some tests to it:
    if length of militaryTime is equal to 4 then
    else if length of militaryTime is equal to 2 then
        set theHour to "00"
        set theMinutes to text 1 thru 2 of militaryTime
    end if
    if (theHourNumber is equal to 00) & (theMinutes is equal to 00) then
    else if (theHourNumber is equal to 00) & (theMinutes is not equal to 00) then
    else
    end if
This code is untested and very sloppy, I'd be surprised if it works....If you can wait I can test and improve it when I get home this evening.
Fri Jul 22, 2011 9:56 pm
Brandt offline
Finally got around to testing it and added a few things:
   else if length of militaryTime is equal to 3 then
      set theHour to "0" & text 1 of militaryTime
      set theMinutes to text 2 thru 3 of militaryTime
      set theHour to "00"
   else if length of militaryTime is equal to 1 then
      set theHour to "00"
      set theMinutes to "0" & text 1 of militaryTime
   end if
   if (theHourNumber is equal to 0) and (theMinutes is equal to 0) then
   else if theHourNumber = 12 then
   else if (theHourNumber is equal to 0) and (theMinutes is not equal to 0) then
   else
   end if
This works with 1, 30, 124, 1750, 0000....just remember there is no 2400. It goes from 2359 to 0000
Fri Jul 22, 2011 11:47 pm
ckeyes888 offline
Thanks a bunch Brandt. I'll install it tomorrow.
Carl
Fri Nov 11, 2011 2:02 pm
ckeyes888 offline
Came across another issue. I have a trigger that turns on the hot tub and calculates
what time the tub will reach the desired temp based on it's current temp.
I simply take the military time and add time to it depending on the current hot tub temp.
Problem is that the new number can be outside the military time spec by going over 59 mins.
e.g. if the military time is 1550 and I add 30 mins it becomes 1580, then when I convert that
using the script above the ready time becomes 3:80 pm.
Any ideas?
Many thanks,
Carl
