Coordinated control of iTunes, Pandora and AirFoil
Wed Mar 03, 2010 10:01 am
dougkress offline
I've just posted two scripts to control iTunes and Pandora (via PandoraBoy) to the user contribution library (http://www.perceptiveautomation.com/filelib/index.php?id=101.
The goal was to have iTunes and Pandora both be controlled with the same buttons, and simplify the control as much as possible. Additionally, I use AirFoil to control speakers throughout the house, so I have some control code for that configured as well.
Through the course of developing these scripts, I quickly came to the realization that I needed to subscribe to Pandora to have it work correctly, so I wouldn't recommend use with the "free" version.
Control of the three applications can be done independently of one another - you don't need to use Pandora to use iTunes and/or AirFoil. Additionally, you can use AirFoil in conjunction with the iTunes sync / control scripts included with Indigo, ignoring the iTunes control functions (and variables) included with this application.
Wed Aug 18, 2010 6:53 pm
hamw offline
Re: Coordinated control of iTunes, Pandora and AirFoil
Reading your post, can I control the PandoraBoy app with AppleScript and output the audio to an AP express? I have a whole house audio setup with an iTunes input, and wish to add Pandora, possibly as a separate input independent of iTunes, so I could have either source playing at the same time in different zones. Is AirFoil needed to direct the output to the APE in order to bypass itunes?
Thu Aug 19, 2010 11:57 pm
AlaskaDave offline
Just what I was looking to do. I've been using PandoraOne with my Pandora account so downloaded PandoraBoy so as to have script access. After downloading and running I see no spot w/in PanbdoraBoy to place my username/pass so as to access my account. Any ideas from those using PandoraBoy and this script?
UPDATE: I found an invisible button that appears to accept log-in but you can not enter your username/password for your Pandora account. I've since downloaded PandoraMan that has a similar interface yet accepts log-in. Can PandoraMan be accessed via. this script with modifications?
Most Recent: Looking at the PandoraMan Website it suggests that you first log-into your Pandora account using Safari followed by starting PandoraMan. This works and when quitting both PandoraMan and Safari and relaunching PandoraMan the settings seem to have stuck.
Tue Aug 24, 2010 12:58 pm
AlaskaDave offline
Before I install this script, is anyone using it and having good results? With the issues of getting PandoraMan to work I'm questioning if this is still working as advertised. I'd like to hear how users "us it" and what features they find most useful... anyone?
Thu Aug 26, 2010 12:49 am
AlaskaDave offline
Well, I seem to be typing/talking to myself. But yes, I did get it working with minimal effort. One thing I have yet to figure out and not sure if you can is the ability to select a Pandora Playlist as apposed to skipping to the next one. Ideas anyone?
Thu Aug 26, 2010 3:21 pm
hamw offline
AlaskaDave,
Have you found that you can send the Pandora to an AP Express and the computer's iTunes output to the computer audio out simultaneously?
It will be good to find out if one can directly select Pandora playlists as well. Would make that great.
Thu Aug 26, 2010 3:57 pm
AlaskaDave offline
I have not had success on either front. I noticed that the developer of the applescript placed his email in the header of the script so I will likely email him directory on that. As for multiple sources, I would like to always have the system input available for notifications while playing something else (iTunes, AirFoil...etc). I did notice that AirFoil has several plug-ins. One's called SoundFlower. Not sure what it does exactly, the description stating: The Soundflower Extra, used to power System Audio capture. I will likely leave a message for Rogue Amoeba and see if multiple sources is possible.
Wed Sep 29, 2010 9:42 am
Colorado4Wheeler offline
Great script! Works pretty well, but I cannot get nextTrack() to move to the next track on Pandora.
Wed Sep 29, 2010 10:25 am
AlaskaDave offline
I believe next track only works with iTunes. I have not looked a PandoraBoy's AS library, wonder if it's listed in there?
Wed Sep 29, 2010 2:23 pm
You actually have it there, called NextPandoraBoyTrack, but it doesn't work. I've done some research and apparently that Applescript command for PB is problematic - some work and some don't.
Tue Nov 09, 2010 8:45 pm
hamw offline
Doug,
Love your script. Got it working with no problems. It's set up to directly select stations by their number in the order so as to not have to skip through, but it would also be an advantage to select a station by its name. Does the Pandoraboy applescript command set have such an command?
station n : A Pandora Station
elements
       contained by application.
properties
        name (text, r/o) : Name of station
        identifier (text, r/o) : stationId for Station
I tried these variations:
tell application "PandoraBoy"
      set current station to station 1Bluegrass --as well as
end tell
and
      set current station to station name 1Bluegrass
end tell
No luck. What is the right way, if possible?
Wed Nov 10, 2010 8:13 am
Try this (untested):
      set current station to station named "1Bluegrass"
end tell
Wed Nov 10, 2010 8:41 am
hamw offline
0Nov, 2010 9:37:50 AM
  Error               script error: around characters 51 to 66
  Error               script error: PandoraBoy got an error: Can’t set station "1Bluegrass" to station named "1Bluegrass". (-10006)
10Nov, 2010 9:38:19 AM
Wed Nov 10, 2010 10:04 am
I just tried it with one of my stations and it worked, so I'm not sure what's going on. Try running it from Script Editor first.
Wed Nov 10, 2010 10:39 am
hamw offline
That worked. Thanks!
