today the event log started showing this:
iTunes Sync iTunes is not responding (check iTunes for open modal dialogs)
I have not changed anything in regards to iTunes script, which triggers to open when server is started...
kpfriedberg wrote:today the event log started showing this:
kpfriedberg wrote:ok thanks, seems to work now, that said, we didn't rip any cd's...itunes has really just been idle...
jay wrote:kpfriedberg wrote:ok thanks, seems to work now, that said, we didn't rip any cd's...itunes has really just been idle...
If you see that problem again, try switching to iTunes and see if it's responsive - I bet it either won't be or you'll see very slow UI reactions.
kpfriedberg wrote:so just a follow up to this...i see this error in the event log periodically, when it last happened, iTunes was fine, no sluggishness whatsoever. After I saw that, i played a song, and the iTunes variables in Indigo fired up no problem...I suspect that this error periodically happens when iTunes is idle for a long period of time. I always keep iTunes open in case i want to listen to music and I am not by the computer (via either Remote or Indigo Touch). So I am guess that's the problem...
kpfriedberg wrote:Matt,
just a follow up here. was updating to 3.0 on my iPhone and the event log began spitting these out...maybe something to do with the aforementioned in this thread?
Jun 17, 2009 6:41:04 PM
tell app "iTunes"
play
end tell
macpro wrote:This is the message I'm getting: "iTunes Attachment iTunes is not responding (check iTunes for open modal dialogs)"
Error script error: «script» doesn’t understand the iTunesPlay message. (-1708)
