--[url=applescript://com.apple.scripteditor/?action=new&script=on%20searchReplace(theText,%20SearchString,%20ReplaceString)%0A%09set%20OldDelims%20to%20AppleScript's%20text%20item%20delimiters%0A%09set%20AppleScript's%20text%20item%20delimiters%20to%20SearchString%0A%09set%20newText%20to%20text%20items%20of%20theText%0A%09set%20AppleScript's%20text%20item%20delimiters%20to%20ReplaceString%0A%09set%20newText%20to%20newText%20as%20text%0A%09set%20AppleScript's%20text%20item%20delimiters%20to%20OldDelims%0A%09return%20newText%0Aend%20searchReplace]Click here to open this script in a new Script Editor window[/url].
on searchReplace(theText, SearchString, ReplaceString)
set OldDelims to AppleScript's text item delimiters
set AppleScript's text item delimiters to SearchString
set newText to text items of theText
set AppleScript's text item delimiters to ReplaceString
set newText to newText as text
set AppleScript's text item delimiters to OldDelims
return newText
end searchReplace
I have several attachment scripts that I pass device names to. I need to keep track of some parameter of that device, like dim level for example. Problem with that is you cannot use spaces in the variable name. This script will allow you make variable friendly names.
- Code: Select all
set UnitName to "Main Bedroom Lamp"
set NewUnitName to searchReplace(UnitName, " ", "_")
--Result: "Main_Bedroom_Lamp"
You can then create a variable based on NewUnitName. You can get variables using the same method.
