Webinterface with PHP and Flash
Mon Apr 05, 2004 4:12 am
Netbox offline
I just started a little flash interface for Indigo.
First I wanted to do this in Filemaker 7, but because
they disabled the "run Applescript from web trigger" function :cry:
Now I do it with my new friend php ;)
link:
217.122.181.104/homelink/
source code at:
217.122.181.104/homelink/homelink.sit
(the flash-code is still messy, I'll will clean this up later)
netbox@home.nl
(the codewarrior from Zwollywood)
Mon Apr 05, 2004 9:37 am
Re: Webinterface with PHP and Flash
Great! As an former Macromedia guy, I was hoping to have some type of Flash UI for Indigo at some point. I tried to look over your source, but there doesn't appear to be a file with the link you gave above. Can you re-post the correct URL?
For folks trying to see the test page above in Safari, make sure you temporarily turn off the "block pop-up windows" option. Otherwise, you'll just get a blank browser window.
Regards,
Matt
Mon Apr 05, 2004 10:02 am
Netbox offline
oops here a new try...
ftp://192.168.1.10/homelink.sit
user:somebody
pass:somebody
Mon Apr 05, 2004 10:38 am
Re: oops here a new try...
Still no luck with this. I suspect you meant IP address 217.122.181.104 above since 192.168.*.* is a local address, but that didn't work either.
I did get the authentication dialog, but the login and password didn't work.
Matt
Mon Apr 05, 2004 11:14 am
Netbox offline
(No subject)
Matt I just mailed the files to U.
feel free to post it.
netbox
Mon Apr 05, 2004 12:38 pm
(No subject)
Got it. Here are the source files (AppleScripts, PHP scripts, Flash file, etc.) for those interested:
http://www.perceptiveautomation.com/ind ... melink.dmg
Matt
Sat May 15, 2004 10:31 pm
gregjsmith offline
(No subject)
Any tips for setting this up? What files are suppose to go where, etc?
Sun May 16, 2004 7:23 am
(No subject)
The files should work anywhere inside your site directory. Keep them all in the same folder, except the source *.fla files which can go wherever (including the trash if you don't want the source or don't have Flash). To make it work open the homelink.html file.
You'll need to edit your Apache config file to turn on PHP if you have not already.
Regards,
Matt
Sun May 16, 2004 8:38 am
gregjsmith offline
(No subject)
I went an installed the package from here first and did as you said. It worked easily.
Users browsing this forum: No registered users and 27 guests
