Motion Detecting Help Needed
Sat Feb 21, 2004 6:41 pm
gregjsmith offline
I'm looking for a way to do various things after X minutes from the last motion detected in the house. This "away mode" is going to be different then day and night and it has to look at when the last motion was detected from all the motion detectors in the house.
Do the readers of the board have any suggestions?
Sat Feb 21, 2004 7:23 pm
dscottbuch offline
Re: Motion Detecting Help Needed
Here's one idea.
Have a variable "motion detected"
Whenever any motion is detected toggle this variable between true and false.
Have two trigger actions, one that activates on the true-false transition and on on the false-true transition
These trigger actions both do the same thing, they 'remove delayed actions' for the target devices and then they re-establish the delayed actions for the target devices in X minutes. If any motion occurs the delays are reset. This is done with the applescript commands.
How does that sound??
Sun Feb 22, 2004 11:04 am
gregjsmith offline
(No subject)
I had considered this:
A variable called "lastInsideMotion" in which every motion detector puts its Current Date into.
I would have trigger action called "Away Mode" that reacts to a change to this variable. The reaction would be do somethings via applescript in a new trigger event that would occur in X minutes. It would also have to delete any trigger events that exist to do this already.
Doesn't look like I can create trigger events via applescript so I'm not sure where to go now.
Sun Feb 22, 2004 12:24 pm
(No subject)
Can you pre-create the Time/Date Action that executes your AppleScript? If it was an "Every N minutes" Time/Date Action, then you could toggle it from a disabled to an enabled state. Whenever a countdown (Every N minutes) Time/Date action transitions from a disabled to enabled it resets the countdown timer.
Regards,
Matt
Sun Feb 22, 2004 12:25 pm
dscottbuch offline
(No subject)
Maybe I'm missing something but I would think the following applescript
remove delayed actions for trigger "target trigger"
enable trigger action "target trigger" in X minutes*60
executed in a trigger action which activates on the change of the variable "lastInsideMotion" would work.
Each motion trigger could simply write the date to the variable using the applescript
 set value of variable "lastInsideMotion" to (current date a string)
which would also tell you the last time motion was detected.
This can be done for each trigger action or device.
Sun Feb 22, 2004 1:35 pm
gregjsmith offline
(No subject)
I've got it working, but got Indigo crashing as well.
I've got on trigger that is activated by a variable change called "Set Away mode" It has this embeded applescript:
   if value of variable "HouseOccupied" is true then
      disable trigger action "Initiate Away Mode"
      enable trigger action "Initiate Away Mode"
   else if value of variable "HouseOccupied" is false then
      set value of variable "HouseOccupied" to true
      SetSetpoint("H", (value of variable "HeatingOccupiedTemp"))
   end if
I've got a date/time trigger set for 45 minutes called "Initiate Away Mode". It has the following embedded applescript:
SetSetpoint("H", (value of variable "HeatingAwayTemp"))
set (value of variable "HouseOccupied") to false
After a motion detector fires Indigo will crash. When I restart i will see that the "Initiate Away Mode" trigger will have the new date/time stamp on it.
Sun Feb 22, 2004 1:43 pm
dscottbuch offline
(No subject)
question:
If you put the applescript in an external script and run it manually does Indigo crash or does applescript crash?
If you remove the SetSetpoint does it crash?
Sun Feb 22, 2004 1:45 pm
(No subject)
Hi Greg,
Are you running Indigo 1.3.2? I finally pushed this out of beta status to the release download (on the download web page). I fixed some AppleScript problems in the last couple of dot releases.
Regards,
Matt
Sun Feb 22, 2004 2:42 pm
gregjsmith offline
(No subject)
It was doing it in an external applescript as well. i have 1.3.0, I will download the latest and let you know.
Sun Feb 22, 2004 3:04 pm
gregjsmith offline
(No subject)
Downloaded the latest version. Nice icon by the way :)
--[url=applescript://com.apple.scripteditor/?action=new&script=tell%20application%20%22Indigo%22%0A%09if%20not%20(variable%20%22HouseOccupied%22%20exists)%20then%0A%09%09make%20new%20variable%20with%20properties%20%7Bname%3A%22HouseOccupied%22,%20value%3A%22true%22%7D%0A%09end%20if%0A%09if%20(value%20of%20variable%20%22HouseOccupied%22)%20is%20true%20then%0A%09%09disable%20trigger%20action%20%22Initiate%20Away%20Mode%22%0A%09%09enable%20trigger%20action%20%22Initiate%20Away%20Mode%22%0A%09%09log%20%22Reset%20away%20mode%20date%2Ftime%20trigger%20for%2045%20minutes%22%0A%09else%20if%20(value%20of%20variable%20%22HouseOccupied%22)%20is%20false%20then%0A%09%09set%20(value%20of%20variable%20%22HouseOccupied%22)%20to%20true%0A%09%09SetSetpoint(%22H%22,%20(value%20of%20variable%20%22HeatingOccupiedTemp%22))%0A%09end%20if%0Aend%20tell]Click here to open this script in a new Script Editor window[/url].
tell application "Indigo"
     if not (variable "HouseOccupied" exists) then
          make new variable with properties {name:"HouseOccupied", value:"true"}
     end if
     if (value of variable "HouseOccupied") is true then
          log "Reset away mode date/time trigger for 45 minutes"
     else if (value of variable "HouseOccupied") is false then
          set (value of variable "HouseOccupied") to true
     end if
end tell
It doesn't crash Indigo but it doesn't disable or enable anything. It also doesn't make the log entry.
Sun Feb 22, 2004 4:23 pm
(No subject)
This is an AppleScript variable casting problem caused by the fact that variable values from Indigo are always returned as strings.
Change this line:
to:
  if (value of variable "HouseOccupied" as boolean) is true then
This one from:
to:
  else if (value of variable "HouseOccupied" as boolean) is false then
And this one from:
to:
  SetSetpoint("H", (value of variable "HeatingOccupiedTemp" as integer))
Regards,
Matt
Sun Feb 22, 2004 4:32 pm
gregjsmith offline
(No subject)
Matt, thanks for your help. but still having problems. The event log looks like this:
   exists variable "HouseOccupied"
      true
   get value of variable "HouseOccupied"
      "true"
      "Indigo got an error: Some data was the wrong type."
My script now looks like this:
--[url=applescript://com.apple.scripteditor/?action=new&script=tell%20application%20%22Indigo%22%0A%09if%20not%20(variable%20%22HouseOccupied%22%20exists)%20then%0A%09%09make%20new%20variable%20with%20properties%20%7Bname%3A%22HouseOccupied%22,%20value%3A%22true%22%7D%0A%09end%20if%0A%09if%20(value%20of%20variable%20%22HouseOccupied%22%20as%20boolean)%20is%20true%20then%0A%09%09disable%20trigger%20action%20%22Initiate%20Away%20Mode%22%0A%09%09enable%20trigger%20action%20%22Initiate%20Away%20Mode%22%0A%09%09log%20%22Reset%20away%20mode%20date%2Ftime%20trigger%20for%2045%20minutes%22%0A%09else%20if%20(value%20of%20variable%20%22HouseOccupied%22%20as%20boolean)%20is%20false%20then%0A%09%09set%20(value%20of%20variable%20%22HouseOccupied%22)%20to%20true%0A%09%09SetSetpoint(%22H%22,%20(value%20of%20variable%20%22HeatingOccupiedTemp%22%20as%20integer))%0A%09%09log%20%22House%20is%20not%20occupied%22%0A%09end%20if%0Aend%20tell]Click here to open this script in a new Script Editor window[/url].
     end if
          log "House is not occupied"
     end if
end tell
Edit: i got it, changed it to time date action from trigger.
