Time of last event
Fri May 02, 2003 1:45 pm
Guest offline
Time of last event
Does Indigo have the ability to determine the time of the last event? For example, if I receive an X10 A1 on, I may choose to not do anything if the device is already on and it is within one minute from getting the last A1 on.
I think this is similar to the time delta of xtension.
Fri May 02, 2003 6:19 pm
Re: Time of last event
Not currently, but that is a great feature request.
regards,
matt
Mon May 05, 2003 1:43 am
The latest beta version 1.1 now has a device property "last changed" that returns the time / date of when the device state last changed. You can get the beta at:
http://www.perceptiveautomation.com/ind ... o_beta.dmg
regards,
matt
Tue Oct 21, 2003 1:57 pm
gregjsmith offline
(No subject)
Might you post a example here of using this in a applescript?
Tue Oct 21, 2003 2:32 pm
(No subject)
Sure. Make sure that the "time stamp attachment.scp" script is inside of your attachments folder. If you installed an older copy of Indigo, then you might have to dig it out of the Indigo package (Indigo isn't smart enough to copy updated scripts out of the package after you've launched the first time):
  Indigo.app/Contents/Resources/First Run/Scripts/Attachments/
Then, from within an AppleScript Action (either embedded or external compiled script file), just call the function GetTimeStampForAddress(). For example,
tell app "Indigo"
  log "office light last mod at " & GetTimeStampForDevice("office light")
  log "A1 last mod at " & GetTimeStampForAddress("A1")
end tell
Note this function gives you the last time that particular X10 address (or device with that address) was received by the interface. It doesn't report time/dates if you modify the device within Indigo, or have Indigo send an X10 command. For that you can use the "last changed" property of the device object.
regards,
matt
Thu Oct 30, 2003 1:14 pm
dalenis offline
(No subject)
I can not get this to work.....
tell app "Indigo"
  log "Last motion in kitchen at " & GetTimeStampForDevice("Motion Kitchen")
end tell
Message written to log....
Last motion in kitchen at unknown
Any ideas.
Dale
Thu Oct 30, 2003 1:37 pm
(No subject)
Did you recently restart Indigo? The time stamps for this script aren't saved anywhere (unlike the device changed states that Indigo does internally save), so if you restart Indigo then everything starts in an "unknown" state.
regards,
Matt
Thu Oct 30, 2003 1:50 pm
Guest offline
(No subject)
Bingo.....that's was it!
I thought it read at the log file.
Dale
Thu Oct 30, 2003 1:57 pm
dalenis offline
(No subject)
A little more on this time/date stuff. I use the indigo.acgi web script and for some reason the motion sensor date and time are always 12:00:00 AM, 01/01/1904 on the web page.
Any thoughts on this.
Dale
Thu Oct 30, 2003 2:15 pm
(No subject)
The web .acgi script uses the device property "last changed." That is the Indigo internal property that shows when a device last changed its state. Since motion detectors don't have an on/off state in Indigo (I need to fix this...), that property always returns a date of 1/1/04 (the earliest mac native date).
The time stamp attachment script stores, and lets you retrieve, the time/date an X10 signal was last received for a specific X10 address. So, you could modify the web .acgi script to check for the 1/1/04 date, and have it call the time stamp attachment script in this case. Search for "last changed of curDevice" inside the web .acgi script for where you should add this additional conditional.
regards,
Matt
Tue Jun 15, 2004 6:50 pm
no name offline
(No subject)
I was playing around with the motion detectors and noticed that there still is not an "on state" for them. Do you think that will change in v1 or will we need to wait for v2?
Thanks.
Tue Jun 15, 2004 6:58 pm
(No subject)
This will probably have to wait for 2.0.
Regards,
Matt
