Applescript Arrays?
Tue Sep 13, 2016 3:43 am
Vangelis offline
Applescript Arrays?
Was wondering if this is possible to do in AppleScript (happy if easier in Python?)
I want to have Indigo announce entry to my front door via Sonos. I have the trigger for door entry and know how to put a variable into Sonos, but cannot work out how the script it. Basically I was thinking along the lines of an array? whereby the array would contain strings of words that could be announced...
e.g. array = "Hello There,
Welcome Home
Hi there how was your day
Door open"
The script would generate a random number between 1 and 4, and have this number pick one of the four array responses, this would then be announced by Sonos
So far I have this as my random number generator, but have seen an error whereby the Indigo Variable is read-only :(
property SonosAnnounce : 1
set value of variable SonosAnnounce to (random number from 1 to 4)
end tell
Any ideas?
Vangelis
Tue Sep 13, 2016 5:53 am
Re: Applescript Arrays?
I'm not able to do the Sonos part from here, but the random part is super simple in Python:
from random import randint
messages = ["Hello There",
            "Welcome Home",
            "Hi there how was your day",
            "Door open"
x = randint(0, len(messages)-1)
print messages[x]
As far as I know, Python doesn't have a native array structure, but a list will work quite well for your purpose. List elements are accessed by their 'index' -- in this case, 0 through 3 (4 items total; the first element in a list is the 'zeroth' element.) As you add strings to the list (paying attention to how list items are delineated) you don't have to worry about changing the random number generator as its upper boundary is automatically set by the number of elements in the list (minus 1, which allows you to include the zeroth element.) In other words, if we don't subtract 1, the generator would eventually call the Fifth Element which is busy saving the Universe.
Hope this helps.
Tue Sep 13, 2016 7:37 am
Vangelis offline
Cool - Thanks DaveL17 :D
My next question - in Python - how would I write that message[x] variable to one already created in Indigo? (I was getting a read-only issue before)
Vangelis
Tue Sep 13, 2016 1:10 pm
Arrays vs Lists vs Sets, oh my!
The traditional definition of an Array is much more like what you see in C - fixed sized items in a fix sized list. Python lists (like C++ and Objective C arrays) are different in that they can contain anything and are mutable (size can easily change). Python also has a tuple which is an immutable list (basically) and so is more space efficient. Python also has sets which are faster at testing membership but slower to iterate over.
Short version: they're all basically the same thing... :lol:
Tue Sep 13, 2016 1:13 pm
indigo.variable.updateValue(12345, value=messages[x]) # 12345 is the ID of the Indigo variable
Wed Sep 14, 2016 1:50 am
rhanson offline
Here's the no-math option:
import random
            "Welcome Home",
            "Door open"
indigo.variable.updateValue(12345, value=random.choice(messages))
Wed Sep 14, 2016 2:53 am
Vangelis offline
Added the following script :
def messages():
"Welcome Home",
"Door open"
def randint():
def x():
indigo.variable.updateValue(671930218, value=messages[x])
I had to add the 'def' text in order to define the Global Variables (Indigo compiler kept complaining) Although it compiles and runs, I see no update to the Indigo Variable (ID).
Any thoughts?
Vangelis
Wed Sep 14, 2016 3:59 am
There should be no need to add any methods to the code (unless it's part of a much larger script.) Did you per chance copy and paste the code into the Indigo embedded script window? Sometimes there are hidden characters that the compiler doesn't like. This code works for me when run as an embedded script:
            "Welcome Home",
            "Door open"
Wed Sep 14, 2016 4:42 am
Almost forgot the Sonos part. You probably have this figured out already, but here's one way to do it.
Create a trigger that fires whenever your messages variable changes.
Add any conditions that you might want.
Create a Sonos Group Announcement, and in the message field use variable substitution:
%%v:671930218%%
The group announcement field will speak both the variable value (i.e., "Welcome home.") but also any static text that you add as well.
%%v:671930218%% Vangelis. It's good to see you again.
Wed Sep 14, 2016 8:11 am
Vangelis offline
Yay - That worked (must have been corruption somewhere in the cut'n'paste)
Thanks all
Vangelis
Users browsing this forum: No registered users and 35 guests
