Get value of device?
Sun May 15, 2016 9:27 am
Different Computers offline
I really did try to figure this out from an example. Can't find one.
I'm trying to read the value of a Luminance sensor so I can (essentially) invert it for a dimmer value. I have a device called Luminance.
This compiles:
set value of variable currLux to (get value of device Luminance)
set value of variable "darkness" to (currLux - 1000) * -0.1
But when I Run it I get "the variable Luminance is not defined."
I could work around this by making an Indigo variable called Lux or some such, but this seems more elegant--or it would if I had the syntax right!
So what have I got wrong here? I tried "get value of device name Luminance" and that didn't work either.
Sun May 15, 2016 11:09 am
Re: Get value of device?
AppleScript doesn't have access to sensor devices (nor any device types introduced in the past 5 years or so). As we've said in multiple other threads, AppleScript is legacy and hasn't been enhanced since we introduced Python in Indigo 5 (nor will it be).
The Python version of your script (written in out the long way to help with learning):
# Get the source device - you can use the Copy Python Reference contextual menu to get the correct reference
sourceDevice = indigo.devices[SOURCEDEVICEIDHERE]
# Calculate the new value
newValue = (sourceDevice.sensorValue-1000) * -0.1
# Set the value of the destination variable
indigo.variable.updateValue(DESTINATIONVARIDHERE, value=str(newValue))
I think that's what you're looking to do. It could be shortened of course, but this shows you the explicit steps. Indigo Variables alway contain string values so that why we cast the new value to a string before setting it.
Sun May 15, 2016 11:21 am
Thanks.
I do get that AppleScript is not the future, but I have much, much more familiarity with it than anything else, and it's also a skill I can make use of in my work if I get better at it. Moving over to Python is a tall bar to get to the same comfort level!
Sun May 15, 2016 11:28 am
also when I put what I think are the proper references in:
sourceDevice = indigo.devices[450627924] # "Luminance"
newValue = (d.sensorValue-1000) * -0.1
indigo.variable.updateValue(darkness, value=str(newValue))
on the "new value" line I get
embedded script: global name 'd' is not defined
and in fact, I don't see any definition for anything called d.sensorvalue but then I don't know what the reference actually is.
Sun May 15, 2016 11:30 am
On that line, instead of "d" use "sourceDevice".
Sun May 15, 2016 11:36 am
"indigo.variable.updateValue(darkness, value=str(newValue))"
there is a variable named "darkness"
but I get
embedded script: global name 'darkness' is not defined"
Sun May 15, 2016 11:54 am
ok.
I think I got it.
indigo.variable.updateValue(1021324478, value=str(newValue))
right format? It compiles. And is changing my variable!
