Watched folder to trigger Indigo?
Sun Apr 03, 2016 1:08 pm
Different Computers online
Before I jump too far down this rabbit hole, I thought I would ask if this seems like a good idea:
My Foscam C1 is set up to record motion detection events to the Drop Box folder of the user my Indigo Server runs under.
If I use Automator to watch that folder, then on any new file, I could trigger an Indigo action, effectively making my C1 a motion detector.
Reasonable?
Sun Apr 03, 2016 1:22 pm
Re: Watched folder to trigger Indigo?
Yes, certainly.
Using the Restful API, you can call an Indigo action.
I do it with some Python on a Windows PC, but I'm sure Automator would work.
Sun Apr 03, 2016 2:59 pm
Where do I find docs on the the Restful API?
Sun Apr 03, 2016 4:13 pm
http://wiki.indigodomo.com/doku.php?id= ... stful_urls
Or:
Website > Support > How to Wiki > Tech Docs for Indigo 6* > RESTful API
*right at the bottom.
Sun Apr 03, 2016 4:44 pm
Thanks again! I even think I get it!
Assuming I have an indigo variable called YardMotion
I create this applescript that triggers on folder change:
set YardMotion to "true"
set IndigoWarning to "curl -u username:password --digest -X PUT -d value=" & YardMotion & " http://192.168.0.99:8176/variables/YardMotion"
do shell script IndigoWarning
Edit: fixed curly quotes in code
Last edited by Different Computers on Mon Apr 04, 2016 7:35 am, edited 1 time in total.
Mon Apr 04, 2016 12:34 am
In theory it looks right but I don't know AppleScript or how curl PUTs values.
Someone like @flyingdiver can probably help here.
Mon Apr 04, 2016 7:34 am
More experimenting got that script above to compile in Script Editor AFTER I replaced the curly quotes with straight quotes.
Mon Apr 04, 2016 8:01 am
Yeah, fancy quotes are a programmer's nightmare. Never use a word processor (TextEdit or worse) for editing scripts.
