applescript to indigo interface
Fri Aug 07, 2015 4:04 am
as applescript has problems interfacing to indigo would anyone be interested in an easy to use interface to send commands from applescript to indigo and read variables or device states
idea:
- in indigo a plugin runs that checks (every x seconds) a file (/users/yourid/documents/indigocommands/toIndigo) with commands from applescript to indigo
-- if the file is new or has a new line the plugin reads it and executes the requested command i.e. set variable to xx or dimmer etc.
-- write to file /users/yourid/documents/indigocommands/toApple the response from indigo
-- reset the file and wait for next command
in applescript:
- write requested commands to a file like this:
   do shell script 'echo "set variable xx to yy"          >> /users/yourid/documents/indigocommands/toIndigo'
   do shell script 'echo "set device xx  state yy to zz"      >> /users/yourid/documents/indigocommands/toIndigo'
   do shell script 'echo "get variable xx"                  >> /users/yourid/documents/indigocommands/toIndigo'
   do shell script 'echo "get device xx state yy"         >> /users/yourid/documents/indigocommands/toIndigo'
- read back result
   set responseFromIndigo to do shell script 'cat  /users/yourid/documents/indigocommands/toApple'
this concept bypasses the security issues with the applescript -> indigo interface.
Fri Aug 07, 2015 12:01 pm
Korey offline
Re: applescript to indigo interface
I'd be interested!
:D
Korey
Tue Aug 11, 2015 2:01 am
davinci offline
I think it is a good idea.
Something that Indigo should do!
Tue Aug 11, 2015 10:07 am
I will start working on it next week.
First read/ write variables and device/states
Then actions
And then listen to changes in variables and devices.
Tue Aug 11, 2015 10:47 am
autolog offline
Not sure if Watchdog will help?
so thought I would share the link - Watchdog :)
Users browsing this forum: No registered users and 39 guests
