Detect amount of clicks on wall switch
Sat Feb 14, 2015 2:56 pm
davinci offline
I want to detect how many times I click on a wall switch.
This code would be working if it is triggered and run as I switch the wall switch multiple times. But it seems like it waits for the first one to complete. Has anyone an idea how to do it?
Trigger is the switch.
if value of variable "SwitchLock" is equal to true then
   set value of variable "Switch" to (value of variable "Switch") + 1
else
      set value of variable "SwitchLock" to true
      set value of variable "Switch" to 1
   end tell
   delay 0.5
   if value of variable "Switch" is equal to 2 then
      DO SOMETHING - 2 clicks
   end if
   if value of variable "Switch" is equal to 1 then
      DO SOMETHING - 1 click1
   end if
   set value of variable "SwitchLock" to false
end if
Mon Feb 16, 2015 6:17 pm
Re: Detect amount of clicks on wall switch
AppleScript delays should never be done in an embedded AppleScript because those scripts have to be run on the main executing thread of the server - so everything is held up until the script finishes executing (which is probably what you're seeing).
Maybe if you could describe more generally what you're trying to accomplish we can find the right solution...
Users browsing this forum: No registered users and 31 guests
