This date thingy?
Mon Oct 20, 2003 9:12 pm
gregjsmith offline
This date thingy?
I have a variable in Indigo that I am trying to convert to a date. Here is the code:
set last_rain to date (value of variable "WMlastrain")
The script editor will pop back with a dialog saying : Indigo got an error: Can't get date "Monday, Oct 20, 2003 4:04:06 PM".
Even if I
set somevar to value of variable "WMlastrain" as string
then try to create a date from that I get the same error. What am I doing wrong?
Tue Oct 21, 2003 1:37 am
Re: This date thingy?
Even if I
The problem is there is no built-in AppleScript function to coerce a string into a date. When compiling scripts hard coded time/date strings are automatically converted to date objects (you'll notice the format of the string changes based on your system time/date format prefs), but during runtime there isn't an automatic way to say, "convert this string (or variable holding a string) into a date."
I seem to recall seeing a AppleScript function that someone wrote to help handle this. I googled for it but didn't see it anywhere. Anyone have any code snippets to help with this?
regards,
matt
Tue Oct 21, 2003 5:39 am
gregjsmith offline
(No subject)
But if I
set last_rain to date "Monday, Oct 20, 2003 4:04:06 PM"
then it works. Isn't "Monday, Oct 20, 2003 4:04:06 PM" a string?
Tue Oct 21, 2003 8:19 am
(No subject)
gregjsmith wrote:
But if I
In this case, no. The AppleScript editor compiles that into a date object when you save the script. Try changing the "Monday" to "Mon", or the "October" to "10". Then, re-compile the script -- note it always reverts back to the original format. If it were a true literal string it wouldn't change.
regards,
matt
Tue Oct 21, 2003 12:23 pm
gregjsmith offline
(No subject)
There was a suggestion over at Macscripter BBS to put it in a subroutine like this:
on SubDate(TheString)
   return (date TheString) as date
end SubDate
I'll give it a try when I get home.
Tue Oct 21, 2003 12:57 pm
(No subject)
Seems to work... There goes my theory. I wonder why it works in this case. :?:
