Applescript Shell Curl Script
Mon Nov 25, 2013 11:23 am
MrJeffreyGee offline
I've been uploading weather data to the SQL database on my webserver using Applescript and Safari, which works fine. It's slow and CPU intensive, so I'm trying to convert over to using the curl command and I'm having trouble. If I type in this URL directly in a browser it works and the data is injected into the database, but when I do it with curl in an Applescript it doesn't work. I don't understand why. I don't get any errors and the output I get back in Terminal is just the code from the webpage. If anyone's got a clue why this is happening I'd appreciate some help.
This works in a browser
http://www.mywebsite.com/input.php?data1=text&data2=text&data3=text
This doesn't work in an applscript
tell application "Terminal"
   if (count of windows) is 0 then
      do shell script "/usr/bin/curl -d 'data1=text&data2=text&data3=text' http://www.mywebsite.com/input.php "
   else
      activate
      do shell script "/usr/bin/curl -d 'data1=text&data2=text&data3=text' http://www.mywebsite.com/input.php " in window 1
   end if
end tell
Tue Nov 26, 2013 12:23 am
Re: Applescript Shell Curl Script
drop the tell activate terminal ... etc just do
do shell script "curl -d 'data1=text&data2=text&data3=text' http://www.mywebsite.com/input.php "
nothing else
Tue Nov 26, 2013 6:10 am
nothing else
I've tried that too, but the data doesn't get injected into the sql database. It's really strange. I can't seem to get anything injected into the database with curl.
Tue Nov 26, 2013 8:08 am
Have you tried debugging on the server side to see exactly what is getting passed in both the working and non-working cases? Your curl POST request looks good to me, but there must be something different about the browser versus curl case.
Wed Nov 27, 2013 4:32 pm
do you have to enter userid and password when on the browser? I had the same problem
   do shell script " curl -u aaaaa:xxxxx -d  \"ReplySuccessPage=image.htm&ReplyErrorPage=errrimg.htm&BrightnessControl=64&ContrastControl=64&SaturationControl=64&AntiFlickerEnable=1&Mirror=0&ConfigSystemStream=Save\" http://192.168.1.78/setSystemStream  >/dev/null 2>&1 &"
this is setting some parameters on a web camera.
( aaaa xxxx are the userid and passwords)
you should try wireshark or the chrome debugger page to check what traffic actually goes over the wire.
