Home Assistant Agent for Media Device Types?
Mon Mar 11, 2024 6:00 am
vtmikel offline
Moving from Indigo would be way too much of a disruption for me at this point. I'm banking on a strategy of using HA plugins with the Home Assistant Agent plugin that FlyingDiver built to bring those devices to Indigo. The problem is that strategy does not work for a non-standard device, like the Onkyo. We can bring the device over from HA, but the actions would be missing to control the AVR.
Mon Mar 11, 2024 8:00 am
srkinard offline
Re: Upgrade to Python 3?
I tried this...and after a short time the HA Agent plugin would spike IndigoServer to the point of becoming unresponsive. The more HA devices added to Indigo, the faster it happened. I just didn't feel like troubleshooting.
But it took me a while to finally decide to just redo it all...I love Indigo in a lot of ways so it was a tough choice
Mon Mar 11, 2024 8:17 am
That's probably because I have not attempted to implement any kind of media device type from HA. What exactly is the Home Assistant device type for the AVR?
Mon Mar 11, 2024 11:45 am
vtmikel offline
I just assumed this would be a nightmare, but maybe it's not?
The HA type is a media_player (https://www.home-assistant.io/integrati ... ia_player/)
I noticed that the Onkyo integration creates an Entity, not a Device.
Mon Mar 11, 2024 11:48 am
HA does multiple entities for any one physical device. Devices are physical, entities are the HA internal reference.
My initial implementation only did entity types that had a (more or less) one to one correlation with native Indigo device types. Indigo doesn't have a media-player device type.
Let me take a look at the media player entity type and see what I can do with it.
Mon Mar 11, 2024 12:03 pm
In your Indigo client, please use the menu command that writes the HA entity info to the log. Then search for the media_player section, and post that entire section to this thread.
Mon Mar 11, 2024 12:11 pm
vtmikel offline
I'm using v2023.3.2 of your plugin. When I click to write to log, nothing happens. Did this get fixed in your latest release? Unfortunately I'm stuck on Indigo 2022.2 because of the Onkyo integration.
If no other way, I can fire up the latest Indigo on a new config to get this log.
Mon Mar 11, 2024 12:30 pm
I don't recall that any bugs with that function. It certainly works on the current release. If you can upgrade temporarily to get that info, I'd appreciate it.
Mon Mar 11, 2024 12:32 pm
I've requested the Indigo team move the latest posts in this thread about using HAA to the HAA forum.
Mon Mar 11, 2024 1:12 pm
vtmikel offline
I was a dummy, I had the plugin config set to Error Messages only. Here's the log. Not that while you see only one source listed here, there will be multiple and user-specific. You can see how the HA plugin allows for configurable sources here: https://www.home-assistant.io/integrations/onkyo/
        "receiver": {
            "attributes": {
                "friendly_name": "receiver",
                "source_list": [
                    "Playstation 3"
                "supported_features": 20364
            "context": {
                "id": "01HRQA79J0V1PRQ0027SF008PJ",
                "parent_id": null,
                "user_id": null
            "entity_id": "media_player.receiver",
            "last_changed": "2024-03-11T17:51:00.672765+00:00",
            "last_updated": "2024-03-11T17:51:00.672765+00:00",
            "state": "off"
        "receiver_zone_2": {
            "attributes": {
                "friendly_name": "receiver Zone 2",
                "source_list": [
                    "Playstation 3"
            "context": {
                "id": "01HRQA79MNBYW8KQKF9XSNKND5",
                "parent_id": null,
                "user_id": null
            "entity_id": "media_player.receiver_zone_2",
            "last_changed": "2024-03-11T17:51:00.757252+00:00",
            "last_updated": "2024-03-11T17:51:00.757252+00:00",
            "state": "off"
Mon Mar 11, 2024 1:18 pm
That was all wrapped by the "media_player" section, right? Just those two entries in it? Bummer, apparently that integration doesn't include the "device_class" attribute, which is really useful.
Mon Mar 11, 2024 1:20 pm
vtmikel offline
Correct, all in the media_player. I have a bunch of Sonos's and random devices I dont use in that section, which I didn't post.
Also, this is what it looks like when the device is on:
        "receiver": {
            "attributes": {
                "audio_information": {
                    "format": "PCM",
                    "input_channels": "2.0 ch",
                    "input_frequency": "44.1 kHz",
                    "listening_mode": "All Ch Stereo",
                    "output_channels": "4.0 ch",
                    "output_frequency": ""
                "is_volume_muted": false,
                "source": "cd_tv/cd",
                "source_list": [
                    "Playstation 3"
                "supported_features": 20364,
                "video_information": {
                    "input_color_depth": "24bit",
                    "input_color_schema": "",
                    "input_resolution": "Unknown",
                    "output_color_depth": "24bit",
                    "output_color_schema": "",
                    "output_resolution": "0 x 0p",
                    "picture_mode": ""
                "video_out": "yes,out",
                "volume_level": 1.625
            "context": {
                "id": "01HRQF5CZ30J9ZGBKYCKCTHJVR",
                "parent_id": null,
                "user_id": null
            "last_changed": "2024-03-11T19:17:09.358009+00:00",
            "last_updated": "2024-03-11T19:17:21.507038+00:00",
            "state": "on"
Mon Mar 11, 2024 1:24 pm
vtmikel offline
I see what you mean, because here is an example of my Denon AVR:
        "denon_avr_x3700h": {
            "attributes": {
                "device_class": "receiver",
                "friendly_name": "Basement AVR - Denon AVR-X3700",
                "sound_mode_list": [
                    "MUSIC",
                    "MOVIE",
                    "GAME",
                    "AUTO",
                    "STANDARD",
                    "VIRTUAL",
                    "MATRIX",
                    "ROCK ARENA",
                    "JAZZ CLUB",
                    "VIDEO GAME",
                    "MONO MOVIE",
                    "DIRECT",
                    "PURE DIRECT",
                    "DOLBY DIGITAL",
                    "DTS SURROUND",
                    "AURO3D",
                    "AURO2DSURR",
                    "MCH STEREO",
                    "STEREO",
                    "ALL ZONE STEREO"
                "source_list": [
                    "Basement AppleTV",
                    "Basement Roku",
                    "Bluetooth",
                    "HEOS Music",
                    "Sonos",
                    "TV Audio",
                    "ZIDOO"
                "supported_features": 69004
            "context": {
                "id": "01HRQ9798K1P320BCEPJWPHQWF",
                "parent_id": null,
                "user_id": null
            "entity_id": "media_player.denon_avr_x3700h",
            "last_changed": "2024-03-11T17:33:31.795389+00:00",
            "last_updated": "2024-03-11T17:33:31.795389+00:00",
            "state": "off"
And with the device on:
            "attributes": {
                "media_content_type": "channel",
                "media_title": "Sonos",
                "sound_mode": "DTS SURROUND",
                    "MUSIC",
                    "MOVIE",
                    "GAME",
                    "AUTO",
                    "STANDARD",
                    "VIRTUAL",
                    "MATRIX",
                    "ROCK ARENA",
                    "JAZZ CLUB",
                    "VIDEO GAME",
                    "MONO MOVIE",
                    "DIRECT",
                    "PURE DIRECT",
                    "DOLBY DIGITAL",
                    "DTS SURROUND",
                    "AURO3D",
                    "AURO2DSURR",
                    "MCH STEREO",
                    "STEREO",
                    "ALL ZONE STEREO"
                "sound_mode_raw": "DTS Neural:X",
                "source": "Sonos",
                "source_list": [
                    "Basement AppleTV",
                    "Basement Roku",
                    "Bluetooth",
                    "HEOS Music",
                    "Sonos",
                    "TV Audio",
                    "ZIDOO"
                "supported_features": 69004,
                "volume_level": 0.74
            "context": {
                "id": "01HRQFKZB2V0RB26KZSR7HR0KG",
                "parent_id": null,
                "user_id": "920aed0d63a44b8e8049fcfcc9c17115"
            "last_changed": "2024-03-11T19:25:19.085451+00:00",
            "last_updated": "2024-03-11T19:25:19.085451+00:00",
            "state": "on"
Screenshot 2024-03-11 at 3.38.38 PM.png (64.44 KiB) Viewed 667 times
Mon Mar 11, 2024 1:29 pm
vtmikel offline
Mon Mar 11, 2024 1:55 pm
vtmikel wrote:
Yeah, but I already knew how to find the defs for that field. :D
