Home Assistant Agent Releases
Mon Dec 18, 2023 12:18 pm
Release 2023.3.0 now available.
Connection handling updates
Better handling of the websocket connection, including retry to connect and a new Event type for connection errors.
Wed Dec 27, 2023 9:58 am
Re: Home Assistant Agent Releases
Release 2023.3.2 now available.
Adds plugin config menu to select temperature scale for Climate devices. This effects the UI value only, no conversion is done.
Defaults to F, set to C if your Home Assistant instance is set to Celsius.
Tue Apr 16, 2024 8:20 pm
Release 2024.0.4 in the plugin store.
I'm a little behind on these notices.
Added media player device support.
Fixed bug in Fan support.
Changed action labels to clarify devices.
