Completely new install.. Getting errors
Mon Dec 18, 2023 5:38 pm
Re: Completely new install.. Getting errors
I don't think so. It's documented here: https://developers.home-assistant.io/docs/api/websocket
And there's no mention of enabling it. Though this page does mention enabling the REST API if you're not using the standard frontend: https://developers.home-assistant.io/docs/api/rest
Mon Dec 18, 2023 7:06 pm
kidney offline
OK just made some test with an app Called Websocket Client for Mac and when I try to connect I get this as a response....
{"type":"auth_required","ha_version":"2023.12.3"}..
I would think that means that the HA is there and asking for an auth token, but since I don't know more about ws structure I could try the auth procedure,
Mon Dec 18, 2023 7:12 pm
Well, the reply would be
{"type": "auth", "access_token": "TOKEN HERE"}
I'm at a loss as to how the Websocket Client app works and the plugin does not.
Mon Dec 18, 2023 7:13 pm
You are running that test on the same system the Indigo server (and the plugin) are running on?
Mon Dec 18, 2023 7:14 pm
kidney offline
Of course…. ;)
Tue Dec 19, 2023 7:25 am
You got a link to that Websocket client you used?
Tue Dec 19, 2023 7:26 am
Also, can you post a screen shot of the connection info used in that client?
Tue Dec 19, 2023 4:30 pm
kidney offline
Tue Dec 19, 2023 4:33 pm
I tried that one, didn't work at all for me.
I found a different one that did work.
Still have no idea why it doesn't work on your system.
What's the exact URL you're using with that websocket client?
Tue Dec 19, 2023 7:15 pm
kidney offline
Wed Dec 20, 2023 10:33 am
Try https://github.com/FlyingDiver/Indigo-H ... g/2023.3.1
The websocket library included in the plugin was corrupted.
Wed Dec 20, 2023 2:36 pm
kidney offline
Now everything works...... Glad I wasn't the problem hihi!
Wed Dec 20, 2023 3:29 pm
That was sure a weird one. I have no idea how those files got wiped out.
