Home Assistant plugin updated for Python 3
Sun Jul 16, 2023 1:40 pm
Pre-release test version available: https://github.com/FlyingDiver/IndigoHA ... g/2022.0.0
There are two Home Assistant plugins on the store. This is an update of the simpler one, which only allows for representing a Home Assistant device in Indigo. Status of the devices are polled from HA, and can be controlled from the Indigo version of the device.
This release has had very minimal testing. Please report problems using the GitHub issues system.
This update uses the same plugin ID and device types as the original, so it should "just work". Make sure to keep a copy of the old plugin if (when!) you need to revert. Or get it from the plugin store.
Sun Jul 16, 2023 1:52 pm
farberm offline
Re: Home Assistant plugin updated for Python 3
This is awesome. Up and running just fine. I will monitor and let you know f there are any issues.
Thanks for your help.
Sun Jul 16, 2023 3:38 pm
Colly offline
Thanks Joe,
Have this up and running with my test Home Assistant setup.
I had been planning to deploy an instance of HA in a remote property and was thinking of communicating with it through a cloud MQTT broker.
Have I any options with this plugin to connect to a remote location?
Appreciate the effort to get this up and running as I see possibilities to fill gaps in my Indigo setup with some HA integrations.
Sun Jul 16, 2023 3:44 pm
farberm offline
You should be able to connec to a remote location so long as it has a static address
Sun Jul 16, 2023 3:46 pm
farberm offline
Joe …. On other thought. Mr. Slim plugin also works with the Honeywell thermostats. Is it possible to update that plugin?
Sun Jul 16, 2023 3:47 pm
I have no idea, and I'm never touching another thermostat plugin. Both of the ones I've done so far have been horrible.
Sun Jul 16, 2023 3:50 pm
Colly wrote:
Thanks Joe,
This plugin does not use MQTT. That's the other one. If you can reach the remote HA instance with a web browser, this plugin should work.
Sun Jul 16, 2023 3:51 pm
Colly offline
I’ll be able to give it a go later this week. Timing is perfect as I fly out Tuesday.
Fri Jul 21, 2023 8:04 am
mwoodage offline
Hello,
I'm getting the following error when trying to use the updated Home Assistant plugin, is it something i'm doing wrong or is there a bug?
File "plugin.py", line 93, in runConcurrentThread
type: 'attributes'
   Home Assistant Error            plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   Home Assistant Error            Error in plugin execution runConcurrentThread:
type: 'attributes'
Martin
Fri Jul 21, 2023 8:15 am
Not enough info. Turn on debug logging, restart the plugin, then do whatever you did to get the error. Then post the log.
Fri Jul 21, 2023 8:30 am
mwoodage offline
Sorry, my fault! I had the wrong HA Identity ID in the device settings,
It's working now, thank you :D
Mon Jul 24, 2023 8:18 pm
Thu Jul 27, 2023 5:47 am
roquej offline
Today, I use HomeAssitant to control only two items that don't have plugins in Indigo: Trane thermostat and iAqualink. Then I use MQTT and Virtual devices to interact with Indigo. It works but is messy. I don't care about the Trane but would love to use this plugin for the iAqualink setup to simplify my life. However, I am getting lots of errors when using it. Should I post the errors here on your GitHub?
JP
Thu Jul 27, 2023 5:51 am
The Trane Home (nee Nexia) plugin doesn't work for you?
If you're getting errors with the updated for Python3 Home Assistant plugin, then yes open an issue in my GitHub repository.
Thu Jul 27, 2023 7:59 am
roquej offline
The last time I tried the Trane Nexia plug-in, it didn't work. But let me try it again. It has been a while.
Thanks. I will open the issue in GitHub.
JP
