Robotic Vacuums
Sun Oct 22, 2023 3:41 am
racarter offline
Re: Robotic Vacuums
You’re welcome :)
Thu Oct 26, 2023 6:07 am
Re: Robotic Vacuums
I’m presuming the answer will be no, but on the Tuya app I can assign room numbers for the ones that the bot has mapped out and then tell it to go clean room.
Would it be possible to implement this within indigo? It’d then allow me to map that functionality to HomeKit or Shortcuts to tell Siri to clean a specific room.
Thu Oct 26, 2023 7:30 am
racarter offline
Re: Robotic Vacuums
Unfortunately there's nothing in the API for the device to get room data or send room commands.
Thu Oct 26, 2023 3:43 pm
Re: Robotic Vacuums
Bummer! I thought as much, but thanks for looking!
Sun Nov 05, 2023 5:55 am
Re: Robotic Vacuums
Hum.. I just realised that the action to start the vac isn’t actually working.
I’ve enabled all the logging options in settings but nothing appears beyond it mentioning the action group has been run.
Any ideas?
Sun Nov 05, 2023 6:26 am
racarter offline
Re: Robotic Vacuums
Turn on comms logging and send me the result.
Mon Nov 06, 2023 4:06 am
Re: Robotic Vacuums
Here's the logs with everything turned on as best I'm aware. Running the action group doesn't actually trigger anything in the logs, the resulting entries are just the updates that appear in the log regardless:
   Action Group                    Robotic Cleaner - Clean
   Tuya                            ----------------------------------------------------
   Tuya                            Device states for Hallway - Robotic Vacuum Cleaner
   Tuya                            {'result': [{'code': 'power_go', 'value': False}, {'code': 'pause', 'value': False}, {'code': 'switch_charge', 'value': True}, {'code': 'mode', 'value': 'smart'}, {'code': 'status', 'value': 'charge_done'}, {'code': 'clean_time', 'value': 44}, {'code': 'clean_area', 'value': 25}, {'code': 'electricity_left', 'value': 100}, {'code': 'suction', 'value': 'strong'}, {'code': 'cistern', 'value': 'middle'}, {'code': 'seek', 'value': False}, {'code': 'direction_control', 'value': 'forward'}, {'code': 'reset_map', 'value': True}, {'code': 'path_data', 'value': ''}, {'code': 'command_trans', 'value': 'qgAmGwIABPwz/8b9m//G/Zv9YPwz/WACBAFoBUYFZAVGBWQAeAFoAHgj'}, {'code': 'request', 'value': 'get_both'}, {'code': 'edge_brush', 'value': 145}, {'code': 'reset_edge_brush', 'value': False}, {'code': 'roll_brush', 'value': 295}, {'code': 'reset_roll_brush', 'value': False}, {'code': 'filter', 'value': 145}, {'code': 'reset_filter', 'value': False}, {'code': 'duster_cloth', 'value': 0}, {'code': 'switch_disturb', 'value': True}, {'code': 'volume_set', 'value': 0}, {'code': 'break_clean', 'value': True}, {'code': 'fault', 'value': 0}, {'code': 'total_clean_area', 'value': 170}, {'code': 'total_clean_count', 'value': 9}, {'code': 'total_clean_time', 'value': 218}, {'code': 'device_timer', 'value': 'qgADMQAAMQ=='}, {'code': 'disturb_time_set', 'value': 'qgAIMwAWAAAIAAFS'}, {'code': 'device_info', 'value': 'eyJXaUZpX05hbWUiOiJJbGx1bWluYXRlIiwiUlNTSSI6NzAsIklQIjoiMTkyLjE2OC4xLjIxNyIsIk1hYyI6IkJDRkQwQzQ1OUQyNCIsIk1DVV9WZXJzaW9uIjoiMjIuMC4xNiIsIkZpcm13YXJlX1ZlcnNpb24iOiIyLjYuMTEiLCJEZXZpY2VfU04iOiJMdWJsdWVsdVNMNjBEMjMwNzI4MTMyMyIsIk1vZHVsZV9VVUlEIjoiamNrajNhNGYzM2Q2MzM1M2Y4NzgifQ=='}, {'code': 'voice_data', 'value': 'qwAAAAAHNQAAAAIDZJ4='}, {'code': 'language', 'value': 'chinese_simplified'}, {'code': 'dust_collection_num', 'value': 1}, {'code': 'dust_collection_switch', 'value': False}, {'code': 'customize_mode_switch', 'value': True}], 'success': True, 't': 1699265024767, 'tid': 'c54a9e297c8b11ee925ba219d4c92787'}
   Tuya                            Device info for Hallway - Robotic Vacuum Cleaner
   Tuya                            {'result': {'active_time': 1697708987, 'category': 'sd', 'category_name': 'Robot Vacuum', 'create_time': 1697708987, 'gateway_id': '', 'icon': 'smart/icon/bay1652343476308GR4a/9c4ff626ae5c4a75802d45fca50506eb.png', 'id': 'bf1c2318764db04152yito', 'ip': '82.69.119.17', 'lat': '55.0111', 'local_key': '|KS+0zuz)x{B#F6x', 'lon': '-1.6599', 'model': '', 'name': 'SL60D', 'online': True, 'owner_id': '162009572', 'product_id': 'tdxitkhbixikp8eh', 'product_name': 'SL60D', 'sub': False, 'time_zone': '+01:00', 'update_time': 1699160103, 'uuid': 'jckj3a4f33d63353f878'}, 'success': True, 't': 1699265024851, 'tid': 'c55749c07c8b11eeab9046acc027565a'}
Mon Nov 06, 2023 5:18 am
racarter offline
Re: Robotic Vacuums
Found bug. Fixed bug. Saved new version. Uploaded new version to plugin store for Durosity to test.
Mon Nov 06, 2023 7:16 am
Re: Robotic Vacuums
Perfect, that's working well! I can't believe I hadn't actually tried it from Indigo!
Out of interest, is there an API call for stopping the vac without it to dock? EG it's just ran over something nasty and I don't want it spreading it everywhere..
Mon Nov 06, 2023 7:29 am
racarter offline
Re: Robotic Vacuums
There isn’t currently a stop command, but the charge command will send the vac straight back to its dock. I could implement a stop command if you want…
Mon Nov 06, 2023 7:32 am
Re: Robotic Vacuums
If it’s not hard to do it’d be very handy!
Mon Nov 06, 2023 8:23 am
racarter offline
Re: Robotic Vacuums
Yep, really hard.
New version in store. :wink:
Sun Nov 12, 2023 1:43 pm
Re: Robotic Vacuums
racarter wrote:
Yep, really hard.
I appreciate you slaving over that for all those days and nights!
