Smart plug added, but on / off doesn't work
Sat Jul 01, 2023 9:36 am
dlleon offline
I've added a smart plug. Log will report values but error out on off/on command:
Tuya Error Patio Bug light tuya 'off' command failed
Tuya Device states for Outdoor patio temp
Tuya {'result': [{'code': 'va_temperature', 'value': 307}, {'code': 'va_humidity', 'value': 612}, {'code': 'battery_percentage', 'value': 10}, {'code': 'temp_unit_convert', 'value': 'f'}, {'code': 'maxtemp_set', 'value': 40}, {'code': 'minitemp_set', 'value': 10}, {'code': 'maxhum_set', 'value': 90}, {'code': 'minihum_set', 'value': 30}, {'code': 'temp_alarm', 'value': 'cancel'}, {'code': 'hum_alarm', 'value': 'cancel'}, {'code': 'bright_value', 'value': 233}, {'code': 'temp_sensitivity', 'value': 3}, {'code': 'hum_sensitivity', 'value': 5}, {'code': 'switch', 'value': False}], 'success': True, 't': 1688225702886, 'tid': 'd8b22026182411ee8c70fe98ebe72f12'}
Tuya Device info for Outdoor patio temp
Tuya {'result': {'active_time': 1675277105, 'category': 'wsdcg', 'category_name': 'Temperature and Humidity Sensor', 'create_time': 1653616332, 'gateway_id': '', 'icon': 'smart/icon/ay1522815888395iqsuQ/efec180637780e4c91208680ac12d111.png', 'id': 'ebcae61fd2f80d24adcb8n', 'ip': '104.50.216.93', 'lat': '32.9000', 'local_key': '5d2a5abff56a6555', 'lon': '-96.7800', 'model': 'NEO WIFI HT', 'name': 'Covered patio', 'online': True, 'owner_id': '72813327', 'product_id': '0k8mzr1ajxzvj5ar', 'product_name': 'WIFI HT', 'sub': False, 'time_zone': '-06:00', 'update_time': 1688225622, 'uuid': 'cdf1b10a41e19d24'}, 'success': True, 't': 1688225703035, 'tid': 'd8c23f47182411ee8c70fe98ebe72f12'}
Tuya Device states for Patio Bug light tuya
Tuya {'result': [{'code': 'switch_1', 'value': False}, {'code': 'countdown_1', 'value': 0}, {'code': 'add_ele', 'value': 4}, {'code': 'cur_current', 'value': 0}, {'code': 'cur_power', 'value': 0}, {'code': 'cur_voltage', 'value': 1231}, {'code': 'relay_status', 'value': 'power_on'}, {'code': 'cycle_time', 'value': ''}, {'code': 'random_time', 'value': ''}], 'success': True, 't': 1688225703136, 'tid': 'd8d89084182411ee8c70fe98ebe72f12'}
Tuya Device info for Patio Bug light tuya
Tuya {'result': {'active_time': 1664222446, 'category': 'cz', 'category_name': 'Socket', 'create_time': 1661133103, 'gateway_id': '', 'icon': 'smart/icon/ay15306906879543yc3O/e7a27577e2dbb5eb6ecefa2eaf5f6e25.jpg', 'id': 'ebeb887f16f7c9ecfaj80y', 'ip': '104.50.216.93', 'lat': '32.9000', 'local_key': '32445f8a540c7849', 'lon': '-96.7800', 'model': 'wifi计量插座', 'name': 'Bug light', 'online': True, 'owner_id': '72813327', 'product_id': 'xf5vhc7zctkoe7pv', 'product_name': 'Smart Plug', 'sub': False, 'time_zone': '-05:00', 'update_time': 1687970525, 'uuid': 'dc326e205f461ab1'}, 'success': True, 't': 1688225703285, 'tid': 'd8e8c7f0182411ee804ade073cb82c5d'}
Sat Jul 01, 2023 12:56 pm
racarter offline
Re: Smart plug added, but on / off doesn't work
I assume the plug operates correctly via the Tuya app?
I've just uploaded a new version of the plugin which publishes the Tuya server response in case of command failure. Please install this and let me know the response when the failure occurs.
Tue Jul 04, 2023 11:10 pm
dlleon offline
Thank you for making this plug in, and thanks for the quick response. Here's the log update for both the temperature issue and the plug issue:
Tuya Starting Tuya monitoring thread
Tuya {'result': [{'code': 'va_temperature', 'value': 304}, {'code': 'va_humidity', 'value': 605}, {'code': 'battery_percentage', 'value': 10}, {'code': 'temp_unit_convert', 'value': 'f'}, {'code': 'maxtemp_set', 'value': 40}, {'code': 'minitemp_set', 'value': 10}, {'code': 'maxhum_set', 'value': 90}, {'code': 'minihum_set', 'value': 30}, {'code': 'temp_alarm', 'value': 'cancel'}, {'code': 'hum_alarm', 'value': 'cancel'}, {'code': 'bright_value', 'value': 1}, {'code': 'temp_sensitivity', 'value': 3}, {'code': 'hum_sensitivity', 'value': 5}, {'code': 'switch', 'value': False}], 'success': True, 't': 1688533750727, 'tid': '13859c1d1af211ee8c70fe98ebe72f12'}
Tuya Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 81, in runConcurrentThread
File "plugin.py", line 155, in getReadings
type: local variable 'batteryState' referenced before assignment
Tuya Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Tuya Error outoor fence light 'on' command failed
Tuya {'code': 2008, 'msg': 'command or value not support', 'success': False, 't': 1688533760485, 'tid': '1956e83b1af211ee804ade073cb82c5d'}
Tuya {'result': [{'code': 'va_temperature', 'value': 304}, {'code': 'va_humidity', 'value': 605}, {'code': 'battery_percentage', 'value': 10}, {'code': 'temp_unit_convert', 'value': 'f'}, {'code': 'maxtemp_set', 'value': 40}, {'code': 'minitemp_set', 'value': 10}, {'code': 'maxhum_set', 'value': 90}, {'code': 'minihum_set', 'value': 30}, {'code': 'temp_alarm', 'value': 'cancel'}, {'code': 'hum_alarm', 'value': 'cancel'}, {'code': 'bright_value', 'value': 1}, {'code': 'temp_sensitivity', 'value': 3}, {'code': 'hum_sensitivity', 'value': 5}, {'code': 'switch', 'value': False}], 'success': True, 't': 1688533760823, 'tid': '198a58ce1af211ee9fecaa50f188a4b0'}
Tuya Error outoor fence light 'off' command failed
Tuya {'code': 2008, 'msg': 'command or value not support', 'success': False, 't': 1688533763923, 'tid': '1b6279b71af211ee9fecaa50f188a4b0'}
Wed Jul 05, 2023 12:20 am
racarter offline
New release fixes batteryState error and should handle on/off requests for devices with differing command sets, which is the root of your problem. Give it a try and let me know.
Fri Jul 07, 2023 11:56 pm
dlleon offline
So, it's working, but throwing out errors.
Tuya {'result': [{'code': 'va_temperature', 'value': 298}, {'code': 'va_humidity', 'value': 651}, {'code': 'battery_percentage', 'value': 10}, {'code': 'temp_unit_convert', 'value': 'f'}, {'code': 'maxtemp_set', 'value': 40}, {'code': 'minitemp_set', 'value': 10}, {'code': 'maxhum_set', 'value': 90}, {'code': 'minihum_set', 'value': 30}, {'code': 'temp_alarm', 'value': 'cancel'}, {'code': 'hum_alarm', 'value': 'cancel'}, {'code': 'bright_value', 'value': 41}, {'code': 'temp_sensitivity', 'value': 3}, {'code': 'hum_sensitivity', 'value': 5}, {'code': 'switch', 'value': False}], 'success': True, 't': 1688795768223, 'tid': '221ef1631d5411ee8c70fe98ebe72f12'}
Tuya {'result': {'active_time': 1675277105, 'category': 'wsdcg', 'category_name': 'Temperature and Humidity Sensor', 'create_time': 1653616332, 'gateway_id': '', 'icon': 'smart/icon/ay1522815888395iqsuQ/efec180637780e4c91208680ac12d111.png', 'id': 'ebcae61fd2f80d24adcb8n', 'ip': '104.50.216.93', 'lat': '32.9000', 'local_key': '5d2a5abff56a6555', 'lon': '-96.7800', 'model': 'NEO WIFI HT', 'name': 'Covered patio', 'online': True, 'owner_id': '72813327', 'product_id': '0k8mzr1ajxzvj5ar', 'product_name': 'WIFI HT', 'sub': False, 'time_zone': '-06:00', 'update_time': 1688795358, 'uuid': 'cdf1b10a41e19d24'}, 'success': True, 't': 1688795768363, 'tid': '222c62b41d5411ee804ade073cb82c5d'}
Tuya Device states for outoor fence light
Tuya {'result': [{'code': 'switch_1', 'value': True}], 'success': True, 't': 1688795768462, 'tid': '2241eabd1d5411ee9fecaa50f188a4b0'}
File "plugin.py", line 85, in runConcurrentThread
File "plugin.py", line 193, in getReadings
type: list index out of range
Tuya {'result': [{'code': 'va_temperature', 'value': 298}, {'code': 'va_humidity', 'value': 651}, {'code': 'battery_percentage', 'value': 10}, {'code': 'temp_unit_convert', 'value': 'f'}, {'code': 'maxtemp_set', 'value': 40}, {'code': 'minitemp_set', 'value': 10}, {'code': 'maxhum_set', 'value': 90}, {'code': 'minihum_set', 'value': 30}, {'code': 'temp_alarm', 'value': 'cancel'}, {'code': 'hum_alarm', 'value': 'cancel'}, {'code': 'bright_value', 'value': 41}, {'code': 'temp_sensitivity', 'value': 3}, {'code': 'hum_sensitivity', 'value': 5}, {'code': 'switch', 'value': False}], 'success': True, 't': 1688795778733, 'tid': '2862fefa1d5411ee804ade073cb82c5d'}
Tuya {'result': {'active_time': 1675277105, 'category': 'wsdcg', 'category_name': 'Temperature and Humidity Sensor', 'create_time': 1653616332, 'gateway_id': '', 'icon': 'smart/icon/ay1522815888395iqsuQ/efec180637780e4c91208680ac12d111.png', 'id': 'ebcae61fd2f80d24adcb8n', 'ip': '104.50.216.93', 'lat': '32.9000', 'local_key': '5d2a5abff56a6555', 'lon': '-96.7800', 'model': 'NEO WIFI HT', 'name': 'Covered patio', 'online': True, 'owner_id': '72813327', 'product_id': '0k8mzr1ajxzvj5ar', 'product_name': 'WIFI HT', 'sub': False, 'time_zone': '-06:00', 'update_time': 1688795358, 'uuid': 'cdf1b10a41e19d24'}, 'success': True, 't': 1688795778893, 'tid': '2870404a1d5411ee9fecaa50f188a4b0'}
Tuya {'result': [{'code': 'switch_1', 'value': False}], 'success': True, 't': 1688795779057, 'tid': '2888bdb11d5411ee8c70fe98ebe72f12'}
Sat Jul 08, 2023 4:11 am
racarter offline
Your plugs aren't reporting energy usage - either all of the time or some of the time. Plugin was expecting more data that it was getting.
New version in plugin store should fix.
