Zigbee2mqtt Bridge Version 2023.0.58 Update
Fri Mar 10, 2023 7:48 am
Version 2023.0.58 of the plugin is now available in the Indigo Plugin Store.
This is a recommended update for all Zigbee2mqtt Bridge plugin users, especially if you want Temperature Sensors to work correctly! :wink:
Bug Fix + Miscellaneous
Fix Temperature Sensor bug which was causing temperature sensor readings not to be updated in Indigo.
Added Indigo UI icons for Humidity, Lux (Illuminance) and Temperature Sensor.
