Ok MQTT Explorer confirms the device is connected to the MQTT Broker. We can focus on getting the data from the broker into the plugin.
The screenshots below are not meant to be used to copy my configuration - they are for my devices, ip addresses, Mac addresses, and naming. I think you've figured this out by now, but we will work with you to get the specific values set for your devices.
1) Please send a screenshot of your MQTT Broker connection configuration. It has a Model of "MQTT Broker" and a Protocol of "MQTT Connector". Specifically the "Connection Info" and "Topic Subscriptions" sections. Also confirm the device shows a status of "Connected".
- Broker Device
- Screen Shot 2023-04-03 at 8.25.36 PM.png (81.18 KiB) Viewed 36403 times
- Broker Connection Info
- Screen Shot 2023-04-03 at 7.59.54 PM.png (45.15 KiB) Viewed 36403 times
- Broker Topic Subscriptions
- Screen Shot 2023-04-03 at 8.01.11 PM.png (33.78 KiB) Viewed 36403 times
2) Send a screenshots of your triggers of type "MQTT Connector Event" with an event of "Topic Component Match". If your are only using MQTT for my Shelly plugins, then you should have two of these triggers. Please send a screenshot for any and all triggers of the specific type.
- ShellyNG trigger
- Screen Shot 2023-04-03 at 8.05.35 PM.png (101.59 KiB) Viewed 36403 times
3) Send a screenshot of the Indigo configuration section for your Shelly Plus 1.
- Indigo Device Configuration
- Screen Shot 2023-04-03 at 8.10.30 PM.png (82.94 KiB) Viewed 36403 times
By the way, I don't think FlyingDiver, cuhouse, or myself would waste our time helping you if none of this worked.
100% of my home automation is Shelly.
100% my Shelly plugins and FlyingDiver's MQTT plugin. If this ecosystem/flow didn't work, then I'd have no lights right now, my aquarium would be dark, and my coffee wouldn't have brewed this morning. We just have to get you configured correctly.
