Interest in Next-gen Shelly Devices
Tue Oct 03, 2023 2:41 pm
Colly offline
Re: Interest in Next-gen Shelly Devices
siclark wrote:
I have a UK plug and have it working fine with this plug in. Shows power etc. not sure what’s missing.
Interesting - let me look into that so.
Wed Oct 04, 2023 1:39 pm
aaronlionsheep offline
Did you pick the "standard" Shelly Plus US model? I believe all the underlying functionality would be the same, but the UK and EU models have special "UI" components that the US does not have.
Wed Oct 04, 2023 1:51 pm
siclark offline
I have this one
https://www.shelly.com/en-de/products/product-overview/shelly-plus-plug-uk
Wed Oct 04, 2023 2:54 pm
I have this one
Sorry, I meant when picking the model when setting the device up with the plugin. Did you set it up as a Shelly Plus Plug US/IT?
Screenshot 2023-10-04 at 4.53.42 PM.png (30.17 KiB) Viewed 1739 times
Wed Oct 04, 2023 3:23 pm
siclark offline
Took a little while to see how to tell, in Define and Sync but yes, it’s setup as US/IT device. I don’t recall doing that or seeing an option.
Happy with how it’s working so far.
Wed Oct 04, 2023 5:45 pm
tazswe offline
Have anybody tested any of the Shelly blu sensors ?
If I understand it right you should be able to connect them with the ahellyNg.
Skickat från min SM-T720 via Tapatalk
Mon Oct 09, 2023 10:31 am
I released version 1.1.0 and it now supports the Pro 4PM (thanks berkinet), the 1/1PM mini devices, and the Plus S and Plug UK.
I didn't add support for the UI component of the S and UK plugs, but I can if that is desired.
https://www.indigodomo.com/pluginstore/290/
https://github.com/AaronLionsheep/Shell ... /tag/1.1.0
Mon Oct 09, 2023 10:35 am
I haven't seen any documentation on how the BLU sensors will work. I know they pair to a Shelly device, so it might be possible to create a Shelly script that relays the information over MQTT. The plugin would need some additional support for that though. The plugin is able to control the contents of a script, so if BLU sensors are desired, then its possible the plugin could maintain a Shelly script that relays the BLU device information over MQTT back to the plugin in a format it expects.
Mon Oct 09, 2023 2:39 pm
Colly offline
I have 2 configured in Indigo via the Home Assistant Agent plugin. I've just played about with them in my office. They are connecting directly with the rPi. I would hope to connect them to a Shelly Plus device and have them communicate directly with Indigo at some time in the future..... :)
Sun Jan 14, 2024 9:15 am
Colly offline
Hi Aaron,
I've added a few more Shelly devices to my test setup. These are:
Shelly Plus 1PM Mini
Shelly Plus PM Mini
Shelly 1PM Mini Gen 3
It would be great to have these fully supported by your plugin. Please reach out if I can help with testing.
