Configuring NG relays
Tue Apr 04, 2023 1:00 pm
cuhouse offline
Re: Configuring NG relays
Bob,
Thanks. Can you post the MQTT Explorer with it expanded for this device ending in 5B6C?
I thought I was following a trail but seems to not be the issue unless all the screen shots you replied last to Aaron are not exactly current in your system?
I see where the MQTT Prefix has changed CASE throughout the thread. Not sure if you are editing this in the Shelly MQTT Setting GUI? You should just add the "leading" shellies-ng/ to what is there from the factory. I then copy this entire line after making the edit and then this gets pasted into the ShellyNGMQTT plugin device configuration "Base MQTT Topic" field.
I have attached just some examples from the thread where I noticed this. The first 3 have the MQTT Prefix in uppercase and the last is lowercase.
Every character in the MQTT topic type fields matter. They are case sensitive. I tried it with my ShellyPlus1. Changed one letter to uppercase in the Shelly MQTT Settings GUI and the device no longer worked in the ShellyNG plugin. I assume leading blank spaces would also matter.
The screenshots looked all good to me again assuming that this is exactly how your system is configured. I would scrub through the fields where you have made the MQTT prefix edits and double check.
Maybe something will hit Aaron when he gets a chance to review all your latest information.
Sorry I am not able to help more.
Jody
Screen Shot 2023-04-03 at 9.46.48 PM.png (101.64 KiB) Viewed 33365 times
Indigo 2022.1.2, Big Sur v11.7.1, Dedicated late 2014 Mac Mini, PowerLinc 2413U.
Tue Apr 04, 2023 3:49 pm
SMUSEBY offline
I just noticed that the shellyplua1pm device - last four digits of Mac address ab3c - appeared twice on the last MQTT Explorer screen shot, the first showing online = false, the second online = true. Clicking on the second one, online= true, on the right side, the window indicated that it was a retained record, which I deleted.
It only appears once now with online = false.
Thu Apr 06, 2023 6:59 pm
aaronlionsheep offline
Thanks for the screenshots. It appears your Indigo configuration is correct.
1) Can you clear all the output on your MQTT Explorer? This will help with debugging the next steps.
2) Can you go into the plugin settings for the MQTT Connector plugin and set the logging level to "Debugging messages"? This will add a lot of logging, so you probably don't want this on too long.
3) Open the web UI for one of the Shelly NG devices and turn the relay on/off to force it to send out an MQTT message. Then see if you are able to find that event (any topic logged with that device's Mac Address) showing in the Indigo log.
For example, this is what I see when I enable debugging:
   MQTT Connector Debug            Mosquitto: processReceivedMessage: shellies-ng/shellyplugus-c049ef88c33c/events/rpc, payload: {"src":"shellyplugus-c049ef88c33c","dst":"shellies-ng/shellyplugus-c049ef88c33c/events","method":"NotifyStatus","params":{"ts":1680828558.25,"switch:0":{"id":0,"voltage":117.3}}}
   MQTT Connector Debug            All Shelly Messages: type = topicMatch, broker = 1916579321
   MQTT Connector Debug            All Shelly Messages: Matching complete, is_match = False
   MQTT Connector Debug            All ShellyNG Messages: type = topicMatch, broker = 1916579321
   MQTT Connector Debug            All ShellyNG Messages: Matching complete, is_match = True
   MQTT Connector Debug            Plex MQTT Messages: type = topicMatch, broker = 1916579321
   MQTT Connector Debug            Plex MQTT Messages: Matching complete, is_match = False
I want to confirm if the messages are making it to the MQTT Connector plugin or not. If they are, this logging will show if the messages are being matched by a trigger.
4) Confirm you now see MQTT messages in MQTT Explorer for that device. This will confirm if the device is sending out messages over MQTT.
Thu Apr 06, 2023 8:43 pm
SMUSEBY offline
It's very nice to hear from you. I think the quote followed your instructions. As instructed, it's a little verbose.
The device name starts with "46", and the Mac address is B8D61A885B6C.
As for your question #4, I did such a good job of clearing the MQTT Explorer history, that there is no information now. It shows that I'm connected to my Indigo server, port 1883, I've subscribed to shellies, and shellies-ng, but maybe I need a certificate? I'm afraid I'm clueless - I don't think I did anything to configure it originally. Sorry.
Actually, maybe I figured it out? - I subscribed to shellies/# and shellies-ng/#. Is that correct? - or do I need to do something else? Screenshot attached.
I look forward to your diagnosis.
Bob
Apr 6, 2023 at 7:02:51 PM
MQTT Connector Debug MQTT Connector: logLevel = 10
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1-3494547A2110/relay/0, payload: off
MQTT Connector Debug MQTT Connector Event: type = topicMatch, broker = 142665430
MQTT Connector Debug MQTT Connector Event: Matching complete, is_match = True
MQTT Connector Debug MQTTNG Connector Event: type = topicMatch, broker = 142665430
MQTT Connector Debug MQTTNG Connector Event: Matching complete, is_match = False
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1-3494547A2110/input/0, payload: 0
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1-E8DB84D5020E/relay/0, payload: off
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1-E8DB84D5020E/input/0, payload: 0
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/relay/0, payload: off
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/relay/0/power, payload: 0.00
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/relay/0/energy, payload: 1386
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/relay/1, payload: off
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/relay/1/power, payload: 0.00
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/relay/1/energy, payload: 401
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/input/0, payload: 0
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/input/1, payload: 0
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/temperature, payload: 37.16
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/temperature_f, payload: 98.89
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/overtemperature, payload: 0
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/temperature_status, payload: Normal
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/voltage, payload: 120.08
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1-3494547A2D06/relay/0, payload: off
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1-3494547A2D06/input/0, payload: 0
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1-34945479D1FB/relay/0, payload: off
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1-34945479D1FB/input/0, payload: 0
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1-E8DB84D80CCD/relay/0, payload: off
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1-E8DB84D80CCD/input/0, payload: 0
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1pm-84CCA89F6D1F/relay/0, payload: off
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1pm-84CCA89F6D1F/input/0, payload: 0
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1pm-84CCA89F6D1F/relay/0/power, payload: 0.00
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1pm-84CCA89F6D1F/relay/0/energy, payload: 934737
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1pm-84CCA89F6D1F/temperature, payload: 31.88
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1pm-84CCA89F6D1F/temperature_f, payload: 89.38
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1pm-84CCA89F6D1F/overtemperature, payload: 0
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1pm-84CCA89F6D1F/temperature_status, payload: Normal
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/temperature, payload: 36.86
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/temperature_f, payload: 98.34
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/temperature, payload: 37.04
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/temperature_f, payload: 98.67
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/voltage, payload: 120.15
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies-ng/shellyplus1-B8D61A885B6C/events/rpc, payload: {"src":"shellyplus1-b8d61a885b6c","dst":"shellies-ng/shellyplus1-B8D61A885B6C/events","method":"NotifyStatus","params":{"ts":1680833051.52,"switch:0":{"id":0,"output":false,"source":"WS_in"}}}
MQTT Connector Debug MQTT Connector Event: Matching complete, is_match = False
MQTT Connector Debug MQTTNG Connector Event: Matching complete, is_match = True
Trigger MQTTNG Connector Event
ShellyNGMQTT received "new device 2" off
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies-ng/shellyplus1-B8D61A885B6C/events/rpc, payload: {"src":"shellyplus1-b8d61a885b6c","dst":"shellies-ng/shellyplus1-B8D61A885B6C/events","method":"NotifyStatus","params":{"ts":1680833055.63,"switch:0":{"id":0,"output":true,"source":"WS_in"}}}
ShellyNGMQTT received "new device 2" on
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1pm-84CCA89F6D1F/temperature, payload: 31.60
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1pm-84CCA89F6D1F/temperature_f, payload: 88.88
Trigger 1 fHall Thermostat: heater update 1stFlTemp VAR
Trigger fYrd temp to var
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1pm-84CCA89F6D1F/temperature, payload: 31.44
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shelly1pm-84CCA89F6D1F/temperature_f, payload: 88.58
MQTT Connector Debug Shelly Connector: processReceivedMessage: shellies/shellyswitch25-98CDAC2C67A7/voltage, payload: 120.36
Screenshot 2023-04-06 at 19.40.24.png (67.4 KiB) Viewed 33312 times
Fri Apr 07, 2023 3:48 pm
Perfect.
Yes, those need to be in your MQTTConnector subscriptions, which we have confirmed you have in your screenshots.
I did a search of your logs for that device and I see the messages from your ShellyPlus 1 making it into Indigo:
matching on your MQTTNG trigger to queue the message:
and this is the ShellyNGMQTT device logging that it changed itself to "Off":
This looks like everything is working based on what you sent in the logs... :shock:
Fri Apr 07, 2023 3:59 pm
SMUSEBY offline
I only have one NG device powered. I am able to turn it on and off, but from the GUI (I think that's the term you use for the LAN interface).
In Indigo, I doesn't show as connected, and I am unable to operate it. On the attached screenshot, 46 is connected to power; 12 & 15 similarly failed, but are not powered.(note that the State field is blank - it should show the power icon and on or off).
I have deleted the 46 device, and recreated it at least twice. I've lost track of all the guess-and-check fiddles over the past two weeks. However, since the settings all look ok, I am not doing any more fiddling with it.
If everything looks normal to you, it must be that I'm doing something wrong. My first generation Shellys operate normally, and the only difference that I can think of is the NG settings, which I'm told look correct.
Have you any suggestions?
Screenshot 2023-04-07 at 14.52.48.png (88.3 KiB) Viewed 33282 times
Fri Apr 07, 2023 4:12 pm
If you double-click on that 46 device, you should find it is in a device group with 2 other devices. The other 2 devices will be a Switch and an Input. THOSE devices will have state icons that reflect the state of the input and state of the switch (relay). They will probably named something like "New Device X" and "New Device Y" if you have not named them yourself like I have.
Screen Shot 2023-04-07 at 6.06.10 PM.png (43.5 KiB) Viewed 33274 times
The main device (it appears yours is named 46 ngMQTT) does not have a status state, but it does have custom states if you scroll to the bottom of the device pane.
Screen Shot 2023-04-07 at 6.10.34 PM.png (65.67 KiB) Viewed 33274 times
Fri Apr 07, 2023 4:31 pm
SMUSEBY offline
This is a screenshot of everything in my MQTT folder. (My workflow is to put new devices in this folder, physically install them, configure and rename them, and move them to the room folder. 46 is powered; 23/56 and 50 are first generation, and working normally (although they too are not powered). I've labeled the ancillary NG devices as suggested.
What does it mean that Indigo shows custom states? Cycling the power from the GUI does not change anything in the Custom States window.
Screenshot 2023-04-07 at 15.22.06.png (221.59 KiB) Viewed 33271 times
Fri Apr 07, 2023 4:43 pm
From Indigo, you should be able to turn "46 switch" on and hear the Shelly relay click. The Web UI for that device would also show the relay is on at this point.
If you then turn the output off from the Web UI, then "46 switch" should then show as being off.
Is this not happening for you?
On the main device, "46 ngMQTT", you should see a list of custom states with values that will update. Nothing here would change when you toggle the relay since the relay has its own device, "46 switch", and states
Fri Apr 07, 2023 4:52 pm
SMUSEBY offline
The device clicks when I operate it from the GUI. There is no indication of the change in device state, and I am unable to operate it from Indigo. In Indigo, the Sensor Controls window does not have the turn on/off buttons. It does have a 'send status request' button. When I press the status request button, the log shows:
Apr 7, 2023 at 3:48:45 PM
I haven't tried this previously. Hopefully there is a clue here. (the trigger topic strings for matching are "Match: shellies-ng", and 'Any:'. - no wildcard.
Fri Apr 07, 2023 4:55 pm
SMUSEBY offline
Experimenting by adding the /# stops the reporting to the event log - no other changed noted, and I removed the /# topic.
Fri Apr 07, 2023 5:03 pm
It sounds like you have clicked on the "46 ngMQTT" device - which has no controls. Click on "46 switch" and you should have on/off buttons. This device would be the one to updates it's state when you turn the relay on/off from the web UI.
That is correct. the "Any" acts as the wildcard (#).
Undo that because it its broken. The lack of logging now mean no messages are getting to the plugin. Put that back please.
Fri Apr 07, 2023 5:11 pm
SMUSEBY offline
That was the 'fix' - I'm very embarrassed, but I'm very thankful that all along, I suspected it was cockpit error. At least I got that part right.
What confused me was the 'switch' nomenclature which I thought referred to the configuration that employed a physical wall switch; and something you said that the plug-in, in its current state, did not permit the removal of these "nuisance" devices (my work, not yours).
That was a painful experience, but in the process at least I learned a lot.
Back to work.
Thank you!
Fri Apr 07, 2023 5:13 pm
SMUSEBY offline
Can I assume that 'input' serves the purpose for the physical switch?
Fri Apr 07, 2023 5:19 pm
Yeah "Input" is Shelly's terms for the input into the device, so the physical watch switch. "Switch" is their word for the switched load.
