I'm getting repeating event log events
Sun Nov 19, 2023 5:17 am
rainman50 offline
I just installed The Starling Hub and it seems to be working fine. I have 8 Nest thermostats connected. One of the thermostats occasionally repeats events multiple times in a row. Its only this one thermostat that is doing this. I reset it to factory settings and deleted it from the NEST app and then reinstalled it back to the NEST app. It still does the same thing. I'm thinking of replacing it with a new one. Here is a piece of the event log showing the repeating.
Any suggestions?
Schedule trigger "Motion sensor trigger - Hallway West (enable/disable) OFF" (delayed action)
Action Group Scene 107 OFF: Hallway West
Sent INSTEON "PowerLinc Interface" off (scene 107 - Hallway West )
Starling Bridge Received "Thermostat - NEST: East Bedroom (Hub)" humidity update to 50.399993896484375%
Schedule trigger "Living Room Hutch Light off with Hallway West" (delayed action)
Sent INSTEON "MAIN: Living Room: Hutch" off
Trigger Load Master bathroom Humidity into variable
Trigger Humidity: Load Furnace West (Master Bathroom) humidity into Variable
Trigger Humidity: Load Master Bathroom humidity into Variable
Trigger Insteon Thermostat Command received 13
Starling Bridge Received "Thermostat - NEST: Garage North. (Hub)" humidity update to 69%
Starling Bridge Received "Thermostat - NEST: Garage North. (Hub)" temperature update to 70°F
Trigger Furnace turned OFF (Garage North)
Received INSTEON "MAIN: Motion Sensor: Foyer" off (button 1)
Schedule Carriage House Water Heater: set Weekend mode
Meta Device Virtual Device: Weekend mode Device "Virtual Device: Weekend mode" on
Received INSTEON "MAIN: Motion Sensor: Hallway West" on (button 1)
Trigger East Hallway #2: light control - Hallway West ON dim
Action Group Scene 56 ON 25%: Hallway East
Trigger Living Room Hutch Light on with Hallway West
Trigger Motion sensor trigger - Hallway West (enable/disable) DIM
Action Group Scene 107 ON 25%: Hallway West
Sent INSTEON "PowerLinc Interface" on (scene 56 - Scene 56: Hallway East)
Trigger Insteon Thermostat Command received 18
Schedule trigger "Motion sensor trigger - Hallway West (enable/disable) DIM" (delayed action)
Sent INSTEON "PowerLinc Interface" on (scene 107 - Hallway West )
Schedule trigger "East Hallway #2: light control - Hallway West ON dim" (delayed action)
Schedule
Thanks in advance.
Dave
Sun Nov 19, 2023 12:02 pm
Re: I'm getting repeating event log events
Hi Dave,
What have you got your polling time set to in the plugin Config? I have mine set to 5 seconds.
The humidity Value 50.399993896484375 seems a bit odd. On my system it is just showing as an integer percentage. What does it show in the Indigo UI for this thermostat and is it consistent with your other thermostats?
It should only update the stored humidity value in the device state, if it isn't equal to the incoming humidity value. So given that the incoming values are the same, this looks like a bug of some sort?
I could force the incoming humidity to be an integer value which might stop the recurring messages?
Mon Nov 20, 2023 7:55 pm
rainman50 offline
My polling time is 5 seconds.
i looked at all 8 of my NEST thermostats in Indigo and selected it and at the bottom. And this one does read many numbers to the right of the decimal point and the other 7 just has an integer value for humidity. .. that is, no numbers to the right of the integer.
here are some pics. I don't know if these pics worked ok. It just has a file name of a png and i cant see the image in this post.
this pic is from the one that repeats humidity and has a lot of numbers to the right of the decimal point for the humidity value. The interesting point is that the temperature is correct and just has an integer for its value.
Numbers right of Integer 2023-11-20 at 8.36.41 PM.png (57.84 KiB) Viewed 2050 times
This pic is one of the 7 that is OK. It shows just the integer for the humidity and the temperature.
Integer OK 2023-11-20 at 8.36.10 PM.png (55 KiB) Viewed 2050 times
Thanks for looking into this.
Mon Nov 20, 2023 8:01 pm
rainman50 offline
after I posted it then I saw the images.
Also note that when it does repeat in the event log it does occur every 5 seconds. but the value stays the same .
My whole event log is filled with that humidity message occuring every 5 seconds as I showed in my 1st post.
Mon Nov 20, 2023 8:10 pm
rainman50 offline
also another note.
I deleted this thermostat from the Nest app but not from Indigo. When I reinstalled the thermostat into the Nest app it just reappeared again in Indigo.
I should probably delete it from Indigo and reinstall it again in Indigo. Unless you have another idea.
Tue Nov 21, 2023 5:32 am
I will update the plugin to handle this situation. :)
Tue Nov 21, 2023 5:57 am
rainman50 offline
I thank you very much for looking into this. Appreciate it a lot.
Tue Nov 21, 2023 6:17 am
No problem. :)
Pre-release available on Github: Fix for Thermostat Humidity with Large Float Value
Untested, as I am waiting for my Nest Thermostat's battery to charge up.
Tue Nov 21, 2023 7:12 pm
rainman50 offline
Thank you very much. Ill try it out.
Dave
Wed Nov 22, 2023 7:50 am
rainman50 offline
I installed it. So far its working good.
One thing I noticed that it did it for a certain value of Humidity. Like for example 50.5% it was OK. So Ill see how it goes over time.
Thanks a lot.
Sat Dec 09, 2023 7:20 pm
rainman50 offline
Jon,
I do not get any repeating messages after your update. Great job.
Is their anyway of donating?
Tue Dec 12, 2023 5:34 am
Hi Dave,
rainman50 wrote:
... I do not get any repeating messages after your update. Great job. Is their anyway of donating?
Thanks for the confirmation that the update has sorted out the humidity issue.
As I mainly create plugins for my own benefit, I don't accept donations; your appreciation is enough. ;)
