Hue/Saturation/Brightness Errors
Posted: Thu Dec 08, 2016 1:22 pm
I'm not sure if this is a known issue, but in I7 I'm trying to use the "Set Hue/Saturation/Brightness (Hue Lights Controls)" function and after tabbing out of each field I get the same error:
The action still works as it should, it just the UI has the problem with the callback.
- Code: Select all
Hue Lights Error Error in plugin execution UiAction:
File "plugin.py", line 521, in hsbColorFieldUpdated
File "plugin.py", line 429, in calcRgbHexValsFromHsbLevels
ValueError: invalid literal for int() with base 10: ''
